10-24-2020, 07:18 PM | #1 |
Rep 691
Bolted 3.15 Open Differential
Selling a bolted 3.15 open differential. This is direct fitment for an F30 335i automatic. This is ideal for someone wanting to install an LSD as you won't have to machine and drill/tap the ring gear. This would allow you to spec the unit for automatic or manual transmission cars. This will work for automatic cars if you'd like to run it as as an open diff (not sure why you would though). LSD options are available from Wavetrac, Quaife, Drexler among others. Another lower cost option would be to use the Racing Diff conversion. The diff housing, gear set, pinion bearing and diff cover are brand new. The open diff unit and output bearing/races are used in good condition. Will ship at buyers expense. Asking $500 picked up in West LA Last edited by bimmer ///man; 12-14-2020 at 01:42 PM.. |
