07-30-2021, 11:07 AM | #23 | |
Rep 3,943
07-30-2021, 01:02 PM | #24 |
Rep 923
Ha! It works great though. I filled all the holes on my e46, filled the tires up with Helium, and was able to float across a river.
I was thinking of rtv or superglue...for about a second. I got home not having seen the hole thinking I'd plug it and was amazed at what I'd driven on.
07-30-2021, 03:45 PM | #25 | |
Rep 500
07-30-2021, 03:54 PM | #26 | |
Rep 4,871
All of this is done with the tire on the car. |
07-30-2021, 04:42 PM | #27 |
Rep 2,808
Drives: F33 430 and F39 M35i
Before I bought my own plug kit, my daughter's car had a flat. I put her spare on and brought the flat in to a local shop. They charged me $19. They took the tire off the wheel, plugged it and remounted the tire then balanced the wheel. This was over 2 years ago when she started driving.
Me, I just plug and go nowadays. My last flat was two years ago (on a runflat even) and the plug is still going strong. I'm probably going to get new tires soon. When her tires wear, I'm getting her run flats. |
Billfitz8217.50 |
07-30-2021, 05:10 PM | #28 | |
Rep 500
07-30-2021, 07:19 PM | #29 | |
Rep 2,193
07-30-2021, 09:20 PM | #30 |
Rep 16,054
I'm not aware of any requirement for patch plugs. Back in the days before steel belts we used what we called mushroom plugs like these: https://www.amazon.com/Stop-Go-3075-...01AWHTBA&psc=1
The gun that we used had a barrel about 1/4 inch diameter, which you could insert through bias ply tires, made easier because the plugs were soaked with glue that acted as a lubricant, but when steel belted radials came along you couldn't insert them. Now I use a Dynaplug kit, which has a much smaller diameter for pushing it through steel belts. https://www.amazon.com/Dynaplug-Ultr...a-422860306228 |
07-31-2021, 03:32 AM | #31 |
Rep 15,858
That is just viewed as a temporary/emergency repair here in the UK. A patch/plug inserted from the inside, after an inspection of the sidewall condition, is the approved repair.
07-31-2021, 11:38 AM | #33 | |
Rep 15,858
http://www.dexel.co.uk/blog/right-wr...unctured-tyre/ |
07-31-2021, 11:45 AM | #34 |
¯\_(ツ)_/¯
945
Rep 1,762
Try this at 2am on a sunday heading to work
@dmaxdmax
07-31-2021, 12:07 PM | #35 | |
Rep 16,054
07-31-2021, 02:50 PM | #36 |
Rep 15,858
07-31-2021, 05:33 PM | #37 |
Rep 814
Town Fair does. Plug and patch. A proper repair.
