07-30-2021, 12:07 PM | #1 |
Rep 13
Steering weight inconsistent
Hi, I have a weird issue with my steering where it feels light/normal (which I prefer) when the weather is hot but gets noticeably heavier once it is colder outside, this applies to all driving modes. Can anyone shed some light on this please it’s driving me insane. It’s a 2015 F30 335i w/ Adaptive Suspension. It’s worth mentioning that a friend of mine has the exact same car but without adaptive suspension and his steering feels so much better (feels like mine does in hot weather) regardless of the temperature outside. TIA
07-30-2021, 12:39 PM | #2 |
Rep 127
Effort is speed sensitive, light for slow like parking. More effort required in sport than comfort setting. I've never noticed weather effecting steering effort or weight as you call it. If you are comparing to a comparably equipped vehicle, might need a tech to check it out.
07-30-2021, 12:53 PM | #3 | |
Rep 13
07-31-2021, 12:50 PM | #4 |
Rep 127
Well, car has 5 weeks left on warranty, so I'll be visiting the dealer.
What I've always hated about the camera, and apparently this is normal, it remains on after you start driving forward for maybe 20ft. Ridiculous. |
07-31-2021, 01:29 PM | #5 |
Rep 10,351
The camera behaves the same on my wife's Mercedes
"Drive more, worry less. "
07-31-2021, 01:46 PM | #6 |
Rep 768
You can set the speed at which it turns off with E-Sys. Set it to 1mph and it should go off as soon as you move forward.
07-31-2021, 02:06 PM | #7 | |
Rep 5,393
Don't just focus on steering rack. Check play in control arm bushings. Make sure that big upper control arm bushing hasn't leaked out its fluid. Would feel that in steering and could possibly be effected by temperature. Hope this helps! |
08-01-2021, 08:18 AM | #8 | ||
///M ♥ Recycled Dinosaurs
3197
Rep 1,775
Drives: BMW M4, BMW X5 45e
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery) |
08-02-2021, 02:18 AM | #9 | |
Rep 13
08-02-2021, 03:30 AM | #10 | |
Rep 13
08-02-2021, 05:19 AM | #11 | |
Rep 595
They can make a big difference. Some tires are "softer" than others, changing the feel. Tire psi changes the feel too. In addition, everyone seems to hate runflats, but when you remove them the steering gets: Lighter Less precise (especially on center) And becomes less responsive to small/medium inputs. Furthermore, Bmw often changes part numbers for the steering rack in the F30. Your cars may look identical, but it's quite possible they have different steering racks. Some model years the F30 had 3 or 4 different racks, depending on build date. Lastly, BMW loves to adjust/refine the EPS steering through software updates. If you two are not on the same software version for the steering, that'll be a difference too. Booking your car in for an software update may help alleviate your issues, if you cannot find any mechanical problems. Having said all of this, I do notice slightly lighter steering at higher temperatures and a bit more firmness when cooler. Hot bushings lose durometer (get softer). In cooler weather, all of that rubber gets stiffer, producing a stiffer ride and steering weight. That alone may explain some of the difference. |
08-02-2021, 05:37 AM | #12 | ||
Rep 5,393
Control arm bushings have a much bigger effect on steering than people realize. It's still a long shot but worth keeping on your checklist as you attempt to diagnose your problem. Good luck! |
08-02-2021, 10:16 AM | #13 |
Rep 133
Honestly, after reading a few of the other posts in here, it occurs to me that your problem is most likely just related to the changing tire pressures. In the heat the tire pressure gets much higher which is likely what is giving you increased performance in the summer. In the winter, your base line tire pressure won't warm up to get as high as in the summer, resulting in a heavier, more dead tire feel.
I'd just check your tire pressures after a day of driving that you were satisfied with the wheel feel. Then in the winter when you think it feels heavy, check your pressures again. Add in an extra 2-3 psi in the winter and take it back out in the summer and you'll probably be happier. |
08-02-2021, 12:06 PM | #14 | |
Rep 13
08-02-2021, 12:42 PM | #15 |
Rep 133
To put it simply - absolutely, even 1-2 psi CAN give a noticeable difference, depending on the tires and alignment etc. IMO it is worth at least checking the pressures to see if there is a significant correlation.
seems to me to be much more likely than some actual mechanical problem that is exacerbated by temperature. |
