08-04-2019, 01:47 AM | #1 |
Rep 132
16’ 340i xdrive beeping and smoke?
Hey guys I recently got a new to me 340i xdrive and I was in the car talking to my girl with the engine running and outta no where it’s started beeping like crazy, RPMs went to 1500 and there was white smoke coming from the exhaust... I just shut off the car and turned it back on and everything went away has anyone had this or similar happen? Thank you.
P.s the heater was on idk if it’ll make a difference |
08-04-2019, 02:28 AM | #2 | |
Rep 10,473
08-04-2019, 03:12 AM | #3 |
Rep 132
dude it was so strange like my car just started beeping/ siren while the car sounded like it was accelerating and then when I shut it off I see all this thick white smoke coming out the exhaust.. I drove it around to see if anything else happened but the car appeared to be fine. I’m still under warranty but idk what I would tell them
08-04-2019, 11:18 AM | #4 | |
Rep 302
08-04-2019, 01:16 PM | #6 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
Why the hell are you running the heater??
08-04-2019, 03:18 PM | #7 |
Rep 833
Drives: BMW F36, E36, E93
The ony way to find out, unless u got a crystal ball
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
08-04-2019, 03:37 PM | #8 |
Rep 132
08-04-2019, 03:39 PM | #9 |
Rep 132
08-04-2019, 04:11 PM | #10 |
Rep 833
Then get yourself an OBD cable and read the error codes. Anyway a good investent for longer journeys where things can go wrong.
Such Fun
08-04-2019, 04:14 PM | #11 |
Rep 833
What does it matter? The car should be able to cope with that anyway.
Such Fun
08-04-2019, 04:16 PM | #12 |
Rep 132
08-23-2019, 01:57 AM | #15 | |
Rep 833
Recently I had the intake hose off and could have a look into the turbo. I could see a thin line of oil going into the turbo. I am wondering where this is coming from and if this is related to your problem.
Such Fun
08-23-2019, 09:50 AM | #16 | ||
Rep 132
08-23-2019, 12:32 PM | #17 |
Rep 5,997
Yeah I feel like it was about an hour. Car would shudder and rpm fluctuating up around 1500 rpm with a loud shrieking sound from maybe the turbo. Turned it off and turned it back on and everything is normal but white smoke came out of the tail pipe then cleared up. No check engine light or error codes stored. Not sure if I should bring it back and have them idle for an hour or look into the turbo not sure if they will do that. They may go do something else and not turn it off which could damage something. Surprised it doesn't consume oil and only happens when idling for extensive periods but not revving and fixes itself after turning it off. Did the fix of replacing gaskets and spark plugs fix it? I've had spark plugs replaced as part of routine maintenance but I'm used to spark plugs lasting longer maybe it's different with direct injection turbo engines? Now that I think back it may have been beeping as well.
08-23-2019, 01:07 PM | #18 | |
Rep 132
EDIT: they haven’t done the work yet tech told me to keep the loaner til like Tuesday so I’m still waiting man |
08-23-2019, 01:53 PM | #19 | ||
Rep 5,997
08-23-2019, 02:05 PM | #20 |
Rep 132
np fam and it’s the g20 which I don’t like lmfao but whatever it’s a new car 😂😂 by the way how many miles do you have? And any other issues have you had?
08-23-2019, 02:49 PM | #21 | |
Rep 5,997
08-23-2019, 05:33 PM | #22 | |
Rep 132
