03-22-2016, 10:38 AM | #111 |
Rep 115,980
03-22-2016, 12:28 PM | #112 |
Rep 275
03-22-2016, 03:35 PM | #113 | |
Rep 4,323
PPK may have raised it to 155, which is what I had before, but if Enzo can confirm, it should be gone now...
03-22-2016, 08:09 PM | #114 |
Rep 245
This might be a dumb question, but I currently have the Dinan stage 2 with Dinan CAI and MPE.
If I wanted to upgrade the turbo to the Pure Stage 2, which components would I need? Can I run this Pure Stage 2 turbo with the Dinan stage 2? Or would I need to remove that and get a JB4? |
03-22-2016, 08:18 PM | #115 | |
Gettin It Figured Out
1820
Rep 2,669
Depends how far you want to take it... - ER Charge Pipe - GFB DV+ (upgraded Diverter Valve) - Maybe Intercooler - Possibly upgraded plugs - Possibly PDU's PI Kit - Possibly Upgraded LPFP You'll have to ditch Dinan and either go JB4, Flash Tune or Flash Tune with JB4 as a boost controller. .
03-24-2016, 03:16 AM | #116 | |||
Rep 1,575
I read that the zf8 is the same as the one in the rs7, sure it might need some beefing up but the rs7 parts are available, right? |
03-24-2016, 10:33 AM | #117 | |
Rep 275
The ZF8 transmission has a large range. 8HP45-50 in most N55 models is made to handle 400 ft lbs of torque and maintain great gas mileage. the 8HP75, most likely in the RS7 has beefed up valving, internals etc. Upgrading the 8HP in the BMW lineup is something we are working on. Unfortunately it's not as simple as slapping some parts together and getting GTR like performance. |
03-24-2016, 11:09 AM | #118 |
Rep 258
Do you offer just a speed delimiter, or does it only come with the flash tune?
2015 Jet Black F32 435i RWD Coupe - MPPK | MPE | JB4 | M4 437m Wheels | BMS Intake | Wagner Tuning Downpipe | Black Stepped FMIC | Evolution Raceworks Chargepipe | Machnt Schnell Air Scoops | BMS Sport Oil Cooler Thermostat delete | H&R Sport Springs | Best 1/4 et: 12.1s
03-24-2016, 11:16 AM | #119 |
Rep 893
My car is xdrive and came with all seasons so was limited to 130mph, I can confirm that the the Enzo tune removes the speed limiter
2019 SG M5C
2015 SO M3 6MT 2015 BSM M235xi |
03-24-2016, 02:43 PM | #120 |
Rep 4,323
You sort of answered your question - drivetrain, parts, etc.
03-24-2016, 07:28 PM | #121 |
Rep 1,575
Ok so your primary concern is the transmission, seeing as the parts are readily available I can't imagine it would cost that much to beef up the trans or swap out stronger axles, they already sell upgraded axles for these cars.
03-24-2016, 10:30 PM | #123 | ||
Rep 1,575
Looking forward to seeing what you guys come out with. |
03-25-2016, 11:11 AM | #124 |
Rep 76
Maybe slightly off topic here but would anybody happen to know a reputable tuner who can bench flash/tune a FBO-ish pure stage 2 turbo car in the NYC/north NJ area (not Enzo, somebody who'd work on a 2013 pwg car) ?
I did a quick search around in the forums, seems like GSR+Mission are on the West Coast, Eurocharged is in Texas, ACF is in Illinois, and that seemed about it. |
03-25-2016, 11:17 AM | #125 | |
1820
Rep 2,669
ACF is out of Brazil, they make "House Calls" here in the U.S... .
05-03-2016, 10:46 AM | #127 |
Rep 48
Question for the forum. I'm planning on doing the Pure Stage 2 turbo upgrade as well as the Port injection upgrade. Since I'm not doing them both at the same time 6-12months apart. What would you recommend doing first?
]2013 F30 M SportMods; DocRace Topmount Turbo, Stage 3 Fuel pump,Fuel it Port injection with 500 injectors, Jb4 stage 2, MHD tune, Challenge downpipe, KSport Air ride, Borla Atak. Evolution Racewerks FMIC & charge pipe, M Factory LSD, H&R front & rear swaybar, Turner Front Strut brace, 19" Avant Garde 359 , Carbon fiber hood, spoiler,diffuser & side mirrors, side skirts, white front splitter.
05-03-2016, 01:37 PM | #128 | |
Rep 1,782
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
05-03-2016, 01:54 PM | #129 | ||
Rep 893
Upgrade the turbo first.
2019 SG M5C
05-04-2016, 09:42 AM | #130 | |
Rep 1,349
Drives: BMW F80 M3
12-27-2016, 04:00 AM | #131 |
Rep 1
2012 F20 M135i N55 pneumatic wastegate, pressure value of more than 1.3bar will automatically pressure relief , I am not using pure stage 2, if I use pure stage 2 can solve the problem? or loaded JB4 can be resolved?
Thank you all |
12-27-2016, 11:23 AM | #132 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Type 1 in the box and hit save after installing your t map and you will now be able to exceed 21psi without dme freaking out.
FBO-PS1 and stuff
