BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > cleaning wheels
      12-26-2019, 11:22 AM   #1
fondoo1287
Drives: F36
cleaning wheels
theres something very satisfying when cleaning your wheels from the inside out.
      12-26-2019, 11:40 AM   #2
Solidjake
\_(ツ)_/
Solidjake's Avatar
Poland
547
Drives: '13 328i Msport 6MT
It most definitely is satisfying... just seeing the end result is worth taking the time to clean the wheels. I try to clean mine once every two weeks depending on the weather.
Adams wheel/tire cleaner, boar hair brush, ez wheel cleaner brush and a 2gallon garden sprayer. Touch up the tires with meguiars endurance tire gel
Apex SM-10/PSS | 400m/X-ice Xi3 | Injen Intake/Exhaust
Stoptech SS Lines | 335 Brakes | Hawk HPS 5.0 | RBF600
Bootmod3 Stg 1 93 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
wdeerfield1998.00
      01-13-2020, 09:56 AM   #3
Desertnate
Drives: BMW 435i
2016 BMW 435i  [0.00]
Very satisfying. Probably one of the great side benefits of swapping wheels between winter/summer is getting a chance to clean the wheels off the car.
      01-13-2020, 12:55 PM   #4
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I clean the inside in the fall, when I rotate. I started using Flash Brown Royal last year, it's amazing stuff.
https://www.amazon.com/Flash-Brown-N...WE8M25EKZGEX26
On the inside I spray with Brown Royal, wipe it a bit with a medium Scotchbrite pad, then rinse. It really makes them look like new.
      01-17-2020, 08:58 AM   #5
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
I clean mine once a week when washing the car. ez wheel clean brush, microfiber mitt and just car wash soap. they dont need much other than that if you stay on top of it.
My winter wheels on the other hand get a good dose of wheel cleaner for a minute or two and then pressure washed down in the spray off bay when the weather is favorable in upstate NY. Weekly trips to vermont leave them plenty dirty.
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      01-17-2020, 09:33 AM   #6
Billfitz
Billfitz's Avatar
On the inside?
      01-17-2020, 10:43 AM   #7
wdeerfield
A family of bimmers
On the inside?
If you are referring to the barrel of the rim. Yes. The split 5 spoke im able to get in there without issue.
      01-17-2020, 11:49 AM   #8
Billfitz
Billfitz's Avatar
I can reach maybe half of the inside of my 395 V spoke wheels. The only way I can fully clean them is to pull the wheel off the car.
      01-17-2020, 01:32 PM   #9
CajunBMW
Drives: BMW 340i, Chrysler Van
I have used this too. Works great. Started using it based on suggestions in this forum.
      01-18-2020, 04:58 PM   #10
rjd598
rjd598's Avatar
Drives: F30 340i
2016 BMW 340i  [0.00]
Why? There's tons of detailing brushes that get into the barrel.
      01-18-2020, 05:51 PM   #11
Billfitz
Billfitz's Avatar
How many can reach behind the spokes?
      01-20-2020, 06:18 PM   #12
Desertnate
Drives: BMW 435i
Do you mean OEM 395 wheels?
Looking at a picture of them they wouldn't be that hard using something like a Speedmaster or EZ Detail wheel brush. With those you can leave the brush straight and get behind the spokes or the brush shaft itself bends and you can bend it to an angle which will get back there better. I've also simply used my finger to get the last little bits I couldn't reach with a brush.
bbs, bbs super rs, bbs wheels
