BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Photo Threads for F34 - 3 GT
      12-08-2019, 07:39 AM   #397
jubu
jubu's Avatar
Drives: F34 328i xDrive GT
Originally Posted by aleki75 View Post
Looks sharp! Could you list what products did you use and did you have to do anything else (i.e. Programming) upon installation.
First, an update. For some reason one of the Low Beams just stopped working; it's for sure a bulb defect because I've checked the connections and the other LED and the halogens all work in that plug. So I'll be returning it and ordering a different set that was rated much higher on Amazon that I noted below.
I have not yet done any coding since I haven't had time to find where I put my wifi OBD unit, but will probably be doing the checks and bulb types when I do find it. No OBD errors after a 30-40 minute drive with the lights and fogs on, except for the burnt out low beam that seems to be a broken bulb and not a coding issue. Can't say if there's any flickering from warm checks, however--anyone know if warm checks without coding would result in errors? I haven't seen any--yet.
Here are the bulbs I used (a mix of eBay and Amazon purchases based on the various threads and blogs I've read):
Low Beams
Originally purchased these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
As I mentioned above, one of the bulbs stopped working so I've ordered these which have far better reviews anyway:
Fog Lamps
Park Lamps and DRLs
https://www.ebay.com/itm/2x-Canbus-H...72.m2749.l2649
(this links to the "amber" set but I have the white) https://www.ebay.com/itm/PWY24W-SAMS...72.m2749.l2649
Reverse Lamps
https://www.ebay.com/itm/4-X-Super-W...72.m2749.l2649
      12-08-2019, 08:13 AM   #398
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
There are three separate reasons for coding. One is to eliminate warnings of burnt out bulbs because the system doesn't detect the LED as being a bulb. The next is to prevent the lamps from blinking every few minutes. You won't know it's happening because you can't see the lights when you're driving. Everyone else will. The last is to change the voltage supplied to the bulbs from a pulsed DC to a constant DC by coding them 'is LED'. If you don't it will cause hyper flashing with some LEDs.
It's above and to the left of your left knee. If it was a snake it would have bit you every time you got into the car.
admranger2984.50
      12-08-2019, 08:19 AM   #399
jubu
jubu's Avatar
Thanks for explaining--I'll be coding for sure then. As for what I meant when I didn't have time to find my OBD unit, I meant the actual wifi OBD unit I purchased online to do the coding via app; sometimes being too organized works against you and you actually have a harder time finding where you kept things.
      12-08-2019, 08:26 AM   #400
Billfitz
Billfitz's Avatar
I keep mine in the small compartment on the lower left of the dashboard. That way I know where it is when I need it, which just happens to be less than a foot away from the port.
      12-08-2019, 01:43 PM   #401
jubu
jubu's Avatar
Good idea—I think I'll do just that. I found the unit earlier and did the coding; was incredibly easy. Now I just need to receive the new low beams and code them as well.
      12-08-2019, 07:12 PM   #402
Billfitz
Billfitz's Avatar
You don't need to wait to code them. Halogens will work fine even if coded for LED. They just won't register a blown bulb should that occur.
      12-15-2019, 08:02 PM   #403
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
I see this hyper flashing with the retrofitted oil field semi trucks. They ignorantly drive down the highways with their headlights looking like they belong in a disco.
They also provide another service to the highway community by either turning in front of you so you have to slam on your brakes or pulling out in front of you so you have to slam on your brakes. Keeps you sharp and on your toes (unless you don't brake in time and get decapitated like a local did a year or so ago...).
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      12-16-2019, 03:46 PM   #404
KCee
Drives: BMW 328 GT XDrive 2016
Originally Posted by Gran_Turismo View Post
Just installed a CF diffuser.
Wow that looks great! I picked up a CPO 2016 328i GT Xdrive back in May that's Glacier silver and I feel like it could use something to sharpen up the look a bit. That's odd for me as I drove a 2006 Acura TL for the last 13 years and never wanted to change its look.
      01-08-2020, 06:43 PM   #405
Letrip
Drives: 3GT 335d X drive, 120d XDrive
Smile Just had it remapped
335d X drive remap to 364bhp on the dyno 620ish torque
KRS_SN13500.00
      01-09-2020, 08:58 AM   #406
jubu
jubu's Avatar
      01-09-2020, 10:07 AM   #407
KRS_SN
KRS_SN's Avatar
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
wow! wish i could remap my 335d but as under warranty im holding back. Who did the remap(assuming you are in the UK,) can you share the pros snd cons yoh felt from your personal experience. Is your suspension stock or modded.
      01-09-2020, 01:21 PM   #408
Letrip
remap
sure, yes in the UK, went to BW chiptune in Hayes. Sterling job, still very smooth and boy does it pick up quick and fly.
I tried a DTUK box for a while, had a few issues of going into limp mode, it was mainly so I could remove it for dealer servicing. It became a pain when the N57 put one of its plug in point at the back if the engine near the bulkhead.
Jason at BW really knows what he's doing with BMW's after a lot of research and recommendations i chose him and have not been disappointed. Absolutely no issues so far. I'll post some 0-60s etc. bit later but expecting very close to 4secs...
KRS_SN13500.00
      01-09-2020, 01:22 PM   #409
Letrip
everything else is stock
      01-09-2020, 02:12 PM   #410
KRS_SN
KRS_SN's Avatar
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
0-60 around 4s that would be insane. Keep us updated.
Letrip12.00
      01-23-2020, 10:59 AM   #411
jwiez
Drives: F34 335xi GT
Originally Posted by jwiez View Post
Hi Guys,
Updated the wheels on my MY2016 F34 Mineral Gray to Replica 666m Staggered 19" Machine Faced Wheels (from Will @ WinRmods, who was awesome), and wrapped them in Conti DWS06 245/40/19, 275/35/19
Really changed the look of the car. No offset issues, lug nuts worked no problem, and no clearance issues.
I've also got tints in the car (35 in back and 35 in front), and M Sport Steering Wheel goes on in a couple weeks. Slowly but surely...
Hi All,
Almost a year later, and added some more subtle mods to the car...
DINAN Stage 1 Tuner & Freeflow Exhaust
Carbon Rear Wing
Black M Grills
All work done @ BMW in NJ, and very pleased with them.
Think it's the perfect dad-sleeper car.
Any questions, let me know !
JMW
      01-23-2020, 03:11 PM   #412
WhiteCollarMetalHead
WhiteCollarMetalHead's Avatar
33
Drives: 2015 335i GT xDrive
Link to the bumber trim pieces around the fog lights?
      01-24-2020, 08:31 AM   #413
jwiez
If your talking about my last photo, it's a stock trim piece...
https://www.getbmwparts.com/oem-part...ng-51117293796
      01-24-2020, 11:34 AM   #414
Gran_Turismo
Drives: 328i GT M Sport
Some recent photos of her. My buddy just got a nice f80 also.
      01-30-2020, 02:37 PM   #415
33
Yours looks like it matched the grlle or is darker than the rest of the trim in the foglight area. I though it might have been aftermarket.
      02-02-2020, 06:10 AM   #416
Letrip
New Dragy and first 0-60 post
new dragy and just posted 4.29 verified to 60. Didn't use launch control either. very pleased
      02-03-2020, 05:06 PM   #417
Fbmw34
Drives: f34
Wow, very impressive numbers!!!
      02-18-2020, 02:58 PM   #418
pdxdbo
pdxdbo's Avatar
331
Drives: G20 330i xDrive M-Sport
Talking
Recently picked up this 328i GT, first order of business was 20% Xpel film all around. Next up will be black out grill, debadge, and swap out the halogen bulbs with XPE Golds. I'm genuinely surprised for how well optioned this car was that it lacks HIDs.
