04-03-2020, 01:29 PM | #23 | |
Rep 1,105
I'm currently running E30 with a custom tune and have zero issues with IAT's |
04-03-2020, 01:45 PM | #25 | |
Rep 7,597
1. FBO - intercooler (appropriately sized), downpipe, charge pipe, consider TIC also at this point. 2. PS2, also get the inlet (or another turbo option, if desired) 3. Consider an intake, although may not be required (more benefit with upgraded turbo). 4. Stock exhaust should be fine, but similar to intake, might be some small gains once you are on PS2 with higher boost (better flowing exhaust). 5. Stage 2 HPFP to leave yourself some room for fueling if you want to go to higher Emix. Stock LPFP should be fine. No PI or meth "needed". Both add complexity to the setup. 6. DV, such as GFB or turbosmart 7. Custom tune 8. LSD if you want to put down the power. Along with good, sticky tires. 9. Clutch if you are not 8AT. XHP flash if you are 8AT. |
04-03-2020, 02:37 PM | #26 | ||
Rep 196
04-03-2020, 05:13 PM | #27 | |
Rep 7,597
TMAP is another good point. I think you need that if you are going to 21+ psi. |
04-04-2020, 08:56 AM | #28 |
Rep 816
Drives: 2021 BMW X3 M
Bigboost 3.3 kit. Throw a fat PTE 6262 on it. Less torque, more whp. Less stress on the bottom end. More spooly noises too.
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD 2021 BMW X3M |
04-04-2020, 03:43 PM | #29 |
Rep 196
04-04-2020, 05:07 PM | #30 |
Rep 816
If I remember correctly its about $3000 for the kit. Everyone on here is big on the PS2 upgrade. While that's great I feel a bigger turbo would be so much better. You want to remove some of the torque, so less cylinder pressure, less heat, less torque, happy bottom end. Not to mention it would pull hard well into the redline and not fall off.
04-04-2020, 06:09 PM | #31 | |
Rep 7,597
If its a daily where you want it to be responsive and not have to rev it out all the time, you want something like a PS2. The PS2 generally speaking has the longest track record for reliability as well. Torque is what makes the car "feel" fast usually, while HP wins races. Personally, i would much rather sacrifice some HP to get the torque and responsiveness. But it's personal preference. |
