03-02-2020, 01:07 PM | #287 |
Rep 18
03-02-2020, 01:18 PM | #288 |
Rep 18
03-02-2020, 01:40 PM | #289 |
Rep 2,302
03-02-2020, 05:27 PM | #290 | |
Rep 2,302
https://mega.nz/#!oxw1mA7A!sytyI_4S0...Yh4fnw35KKfqmI There are also newer psdzdata full but that's not important. |
03-02-2020, 11:40 PM | #291 | |
Rep 18
Once installed, shall I try to flash the ecu again or just try the cafd detect? |
03-03-2020, 03:29 AM | #292 |
Rep 2,302
03-03-2020, 10:15 AM | #294 | |
Rep 18
I used 3.27.1 of esys but the istep options were greyed out. The same for esys 3.28.1. I had to use esys 3.33.4 outside of launcher premium which allowed me to create the necessary files. I then switched back to esys 3.28.1 to finalise the flash process. Anyway I cannot use esys 3.28.1 to detect cafd as the option is greyed out. So I used esys 3.33.4 and the option is available. When click on 'detect cafd', I get the same error I reported earlier. Please help! What am I doing wrong? Last edited by Harj; 03-03-2020 at 10:33 AM.. |
03-03-2020, 10:53 AM | #295 |
Rep 2,302
OK, I will soon have no more ideas.
But try the following. Connect your car as F25 and then try "detect caf for swe". If that works please do nothing further. I will then tell you how to proceed. |
03-03-2020, 10:59 AM | #296 | |
Rep 18
Hi pal. Tried that also. Got the same error message. Am I better off getting a new rdc module? If so, would the latest rdc module work? I found on realoem that module 36106881433 superseeds 227. Should this then work with 227 tpms? |
03-03-2020, 01:26 PM | #297 | |
Rep 2,302
A new control unit would probably work right away, but that's not cheap. Maybe we can try one more. You send me your FA / VO and the SVT_IST file and I can try out a few things on my computer. |
03-03-2020, 01:59 PM | #298 | |
Rep 18
03-04-2020, 12:55 PM | #299 |
Rep 18
Mate you are a complete superstar!!!
Fixed my issue with my retrofit. Hey all, if anyone tells you that you cannot inject a CAFD file into the RDC ecu, well they dont know what they are talking about. My friend here just did that for me and now I have a 2nd hand RDC ecu working in my F31 2013. |
atzebmw588.00 |
03-23-2020, 01:16 AM | #300 |
Rep 94
After reading all the pages, I'm afraid I have to ask one thing prior to the other things:
I have 528i F10 LCI manufactured on 04/2014, does it mean my car has TPMS antenna incorporated within the DSC? FYI, mine came with FTMS and would love to see TPMS embedded on my F10 LCI. If so, all I have to do is purchase wheel sensors + some coding, is that right? Thanks =================== Edit: Okay according to other forums, F10 needs an RDC control unit placed on the rear bumper. I already listed all the mandatory parts (thanks to RealOEM) on eBay. Now I have to ask about the wiring: https://www.newtis.info/tisv2/a/en/f...trol3/EDN6yk6i The diagram says cable #2 should be connected to rear fuse box, cable #4 for grounding purpose, and #1 & #3 to CAN low and high respectively. How do I exactly do the wiring for #1 and #3? Where is the position of CAN low and high where I can connect the cable to? Thanks ================================== Edit #2 Because I don't have reverse camera or power backdoor options, I think there are no CAN bus cable around the trunk. It means I have to pull #1 and #3 cables through the rear seat and connect it to the nearest CAN bus available. Hope I'm wrong Regarding the coding, bit confused for some parts. Correct me if I'm wrong, so for the coding parts, I merely need to VO code 2VB through E-sys, check RDC's CAFD and select "Detect for SWE", select the latest number, and that's all? Or do I have to code for the other things? Last edited by Johnkwick; 03-30-2020 at 02:57 AM.. |
03-30-2020, 04:22 AM | #301 | |
Rep 2,302
Here you see some possibilities: https://www.newtis.info/tisv2/a/en/f...tem/1VnYGPQJdw All these ecus have the 2 can wires you need. You open the insulation of the cable and just connect the wires with the same colors from the RDC. It would be best to solder or with wire connectors. If you're ready with the installation you have to insert the 2VB into your VO and code the RDC like you described. But then you also have to code the ecus HU_NBT (or similar), Kombi and ICM. |
Johnkwick24.00 |
03-30-2020, 10:10 PM | #302 | |
Rep 94
According to the diagram, the nearest one is from rear air conditioning, however I'm not so sure where can I find the wires. This guy from bimmerfest retrofitted automatic trunk lid and he could found 2 CAN wires on the rear passenger seat area (https://www.bimmerfest.com/forums/at...1&d=1439337828), I assumed it was there because he have reverse camera installed. Looks like I have to pay a visit to a local workshop So for coding, please tell me whether those are correct or not for F10 LCI: Code:
#Fire up E-Sys #VO Coding Code 2VB into VO #RDC 1. Make sure RDC is listed 2. Click "Detect CAF for SWE" 3. Select corresponding CAFD 4. Done For below parts, I took it from https://f30.bimmerpost.com/forums/showpost.php?p=20518744&postcount=27 with slight adjustments #ICMQL IcmKod_B_S2VBA = verbaut #DSC C_Funktion_RDCi_l = nicht_aktiv C_Funktion_RPA_e = nicht_aktiv C_RPA_Extra = nicht_aktiv #HU_NBT RDC = aktiv RDC_DRUCK_TEMP = druck_und_temperatur RDC_FORTSCHRITTSANZEIGE = nicht_aktiv REIFENUEBERWACHUNG_RDC_RPA = rdc RPA = nicht_aktiv #KOMBI ST_TYR_RDC_ALIVE = aktiv ST_TYR_RDC_TIMEOUT = aktiv KOMBI DSC_MIT_RPA = ohne_RPA For this purpose, can I use PSZdata lite instead of full version? I read somewhere you may use full version if only you're about to flash your ECU with ISTA-P. For coding with E-sys and diagnostics with ISTA-D/Rheingold, PSZdata lite is already sufficient, is that correct? Thanks Last edited by Johnkwick; 03-30-2020 at 10:29 PM.. |
03-31-2020, 03:56 AM | #303 | |
Rep 2,302
https://www.newtis.info/tisv2/a/en/f...55-2v/Bx3FuHaU The codings are not complete and a little too complicated. Edit your VO, insert the 2VB and save it. Here is a description of how to change the VO AND write it into the car: https://blog.uobdii.com/bmw-vo-codin...nd-enet-cable/ After that... #RDC 1. Make sure RDC is listed 2. Mark the RDC ecu and Click "Detect CAF for SWE" 3. Select corresponding CAFD or the newest with the highest numbers or just the bottom one 4. Done 5. Mark the RDC ecu and click the button "Code" Mark the ICM and click the button "Code" Mark the Kombi and click the button "Code" Mark the HU_NBT and click the button "Code" Mark the DSC and click the button "Code" That's it You only need the psdzdata Lite for this. |
Johnkwick24.00 |
03-31-2020, 11:36 AM | #304 | |
Rep 94
Many thanks for the explanation, so all I need is click "code" and I don't have to change item by item from nich_aktiv to aktiv and vice versa? I never thought it'd be that simple I'll keep you updated with the progress, all corresponding parts are still on its way and I expect some significant delay due to the Corona outbreak. Again, thank you for your help! Take a good care of your health, don't forget to wash your hands often and maintain physical distancing from others |
03-31-2020, 12:01 PM | #305 | ||
Rep 2,302
The program automatically knows where to set the right values at which place. A small problem is that all previous codings (single items) will be deleted. Quote:
You also stay healthy. |
04-02-2020, 05:49 AM | #306 | |
Rep 6
i repurchased another new set and i am still getting the same errors 4806B8- tyre pressure monitor- front left wheel electronics no reception 4806DA- tyre pressure monitor- wheel electronics, no reception, front right 4806F0- tyre pressure monitor- wheel electronics, no reception, rear left 4809EB- tyre pressure monitor- wheel electronics, no reception, position unknown been searching around for a solution and i stumbled upon this TSB https://static.nhtsa.gov/odi/tsbs/20...51098-9999.pdf apparently my fbd3 antenna(located at the rear parcel shelf) could be defective. could this be the reason ? i always assumed that the antenna for RDCi is located within the dsc mk100. should i replace the module? or try a third set of tpms sensors. |
04-02-2020, 08:47 AM | #307 | |
Rep 2,302
I have never heard that it worked so easily for someone simply by installing and coding the sensors. I think it's a little bit more complicated. I would look at the remote control Module (part number) to see if it is the right one to receive the Signal from the tire pressure sensors. |
