05-19-2019, 05:46 PM | #112 |
Rep 2
07-07-2019, 09:39 PM | #115 |
Rep 34
Given that there are currently zero (am I wrong?) solutions for the EWG N55, I am working on a cat simulator as my latest weekend hobby project. The basic idea is to emulate the existing O2 sensor output when equipped with a factory cat by training a neural network.
I have been data logging (my original Cat equipped F33) over OBD2 for a couple thousand miles and collected many GB of data: multiple PIDs such as both O2 sensors, engine RPM, accelerator position, throttle position, air flow rate, intake manifold pressure, boost pressure, intake air temp, catalyst temp, etc. Next I move this logged data into a PC where I can do data analysis, build and train a model. The network inputs are all the various PIDs mentioned above, minus the O2 Sensor 2 (downstream) which is the target variable that my network will compute. If I am successful at this approach, then it may be possible to deploy the fully trained model onto a RaspberryPi under the hood. I will need to feed the Pi with all the same PID input signals (or at least the ones my model believes are most relevant) and I could do that a couple ways (ELM based OBD2 transmitter is one way, hard wiring is another). See where this is going? Anyway I wanted to share with the group what I am working on, and solicit any thoughts/ideas about my approach. |
Chicken_Joe606.00 Tchao333.50 |
07-27-2019, 05:13 AM | #117 |
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
get a tune. tune will delete cel. dont mess with catsim. old tech.
07-27-2019, 11:38 PM | #118 |
Rep 128
07-29-2019, 05:23 AM | #119 |
Rep 323
what is the name of the catsim product that passes obd2 reader nys inspection?
03-24-2020, 11:41 PM | #120 | |
Rep 18
03-24-2020, 11:53 PM | #121 |
Rep 18
03-30-2020, 12:12 PM | #122 | |
Rep 7,606
n55david1295.50 |
03-30-2020, 02:54 PM | #123 | ||
1296
Rep 3,533
03-30-2020, 03:19 PM | #124 | |
Rep 262
Drives: 2013 BMW 335i M-Sport
03-31-2020, 08:03 AM | #125 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
I built a plug and play catsim with the ****** product. Passed emissions on my FBO cat-less X3 with the BM3 OTS E30 map with catalytic monitors enabled in the config.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
03-31-2020, 11:49 AM | #126 |
Rep 963
Can you provide more details? also looks like the forum hid the product name. is this A R E.A 74? or something else?
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
04-01-2020, 04:33 PM | #127 |
299
Rep 531
Correct.
04-11-2020, 02:58 AM | #128 |
Rep 18
I installed the ****** catsim on my ewg 335i
Thought I'd bump this thread up, perhaps I might save someone.
I recently bought the ****** CatSim for my 2014 EWG 335i. I installed the CatSim, cleared codes, and did some driving to see if my CEL was cleared for good. Before installing the CatSim all I had was the typical "P0420 catalyst system efficiency below threshold" code you get with a catless downpipe. Once I had completed a drive cycle my CEL came back on and with symptoms... I noticed my car was driving crappy. Rough shifting, rough idle, and sometimes an occasional misfire at high RPM. Seemed very peculiar so I checked the codes and bam, a whole SLEW of codes: P2097, P013A, P2196, and P2195. And all of those codes except P013A came from the front pre-cat O2 sensor, the sensor that the CatSim doesn't even affect! At least so I thought... Very strange. I contacted ****** sent them codes and they were just as dumbfounded. They had me double check that the wiring was done properly and that it was correctly grounded. I doubled checked and everything was fine. Tried another drive cycle and at this point my cars running even worse, still no fix, and same codes being thrown. ****** doesn't have clear answers at this point. I then got deep into th all knowing forums, found this thread, and found from other forum members that the ****** CatSim doesn't work on EWG cars; 2014 and newer. What?!? This was never communicated to me by ****** and it was evident at this point that it wasn't working for my car. Long story short I removed the CatSim and my car immediately went back to normal. I'm no electrical engineer so I couldn't tell you what that CatSim was telling my ECU but it wasn't good. I'm assuming the byproduct of installing the CatSim was incorrect air to fuel ratio resulting in my car running crappy. I could be wrong but thats my suspicion. Coming full circle, if you have an EWG, DO NOT install the ****** CatSim. All in all, ****** has been good to me and they have been willing to work with me. I see a lot of feedback from non-EWG car owners that swear by their CatSim so in no way am I discrediting their product. Just save yourself the headache and don't try and install it on your EWG car. EDIT: ****** = A.R.E.A.7.4 |
05-21-2020, 10:25 PM | #129 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
I’ve made plug and play harnesses and went Into great detail probably waaay more then I should have. I walked away from making these harnesses shit hit the fan with the EPA and they do watch it’s all I’ll say. I was given a stern warning about this and assisting with these harnesses and making cars pass. For emissions just re install the oem dp and then pass And go back. It’s the only way. It’s a dream doing a down pipe on F30’s compared to what I’m in now. S3/rs3 down pipes are a nightmare in comparison. |
It's Oz35.00 |
08-29-2020, 05:42 PM | #130 | |
Rep 49
Drives: 2013 BMW 335i Coupe M Sport
2013 BMW 335i M-Sport Cpe, MHD Stg 2+, FTP Charge Pipe, xHP Stage 3,c*tless dp, PE mod, Rev9 FMIC
