06-06-2019, 02:24 PM | #1 |
Rep 22
Joyeauto Apple Carplay Retrofit
Hi everyone,
There are threads dedicated to other brands of the Apple Carplay retrofit solutions out there, so I thought I'd create one for Joyeauto to see if folks could chime in on their experiences with it as it seems to be one of the most budget friendly options. I have a 2016 428i xdrive GC and here's what would be great to have: 1) Not having to switch back and forth from iDrive to CarPlay 2) Using the OEM microphone to answer calls - kind of put off by having to install another wired mic 3) Ability to play music through CarPlay (would a wired option be better for sound quality?) 3) Siri is not a requirement as I don't use it much 4) No preference on wired vs wireless solution - as long as everything works! 5) iOS 13 compatibility? Can those of you who have installed the Joyeauto system provide your thoughts/comments? I hate having to use my phone's google maps and standing the iphone in the cup holders! I very much appreciate and thank you all in advance!!! |
06-06-2019, 05:55 PM | #3 |
Rep 1,667
Drives: 2014 428i and 2018 X5
iOS 13 compatibility should be a non issue as CarPlay is all done on the phone...nothing the MMI box has to do but render the video the phone sends it.
06-07-2019, 03:02 PM | #5 |
Rep 439
it seems like unique-ad is just the uk reseller of joyeauto. the iOS side of the firmware is pretty standard, the hardware side of the firmware is pretty much jouyauto, if not all joyeauto. how much of a difference can there really be? also my math may be a bit off, but unique is almost double the cost of joyeauto?
06-17-2019, 10:23 AM | #7 | |
Rep 766
I have the wired version from Unique AD (for the NBT nav) - which uses the car's mic. I haven't tried the new wireless versions but guessing audio would be better via USB plus the phone would be arrive charged to my destination... Unique AD does not sell it anymore as they have gone fully wireless - I think my wired version was from some people called "Carlinkit"... when buying just make sure they will share firmware updates... Unique AD has been responsive and have shared new files when I asked. |
06-17-2019, 11:13 AM | #8 |
Rep 1,667
Curious what files they gave you... what issues did they fix?
06-17-2019, 11:27 AM | #9 |
Rep 22
All, thank you for your responses. I actually bought the full NBT EVO ID6 upgrade from Nelson at Bimmertech. I didn't have to buy the new screen or idrive controls because what I had was sufficient so it was a bit cheaper. I plan to keep this car long term and wanted something as close to OEM as possible, with the new idrive system. Should ship and be delivered this week I believe. If anyone is interested, happy to create a new thread or reply to an existing one with my experience with the install. This will be my first DIY (besides some minor coding stuff via BimmerCode).
06-17-2019, 01:27 PM | #10 |
Rep 766
What was the delta in price if you don't mind me asking? Last summer the delta for me would have been like £1k
06-17-2019, 01:28 PM | #11 | |
Rep 22
06-29-2019, 08:21 AM | #14 |
Rep 212
CleanKM Has provided insight about Joyeauto solution.
https://f30.bimmerpost.com/forums/sh...1597999&page=7 |
06-30-2019, 01:20 PM | #16 | |
SQUEAKY
104
Rep 322
BLUF: I *still* love it and don't regret buying it. I miss the size of the AVIN screen since I had to go back to my 8.8" from the 10.25". I tried to Frankenstein the screen also to use the carplay unit just as a video input, but the AVIN MCU can't decode the input property to display well. Might be a Hz problem, and if I have more time later on, I might give it another whirl. The unit's stability itself is rock solid. The only issues I've had is with the iOS 13 Dev beta that I have and my phone getting hot in the sun. All iOS 12 devices have been working without any issues. Either way, feel free to shoot over any questions, I'll be more then happy to help out. |
theblues86.50 |
06-30-2019, 07:36 PM | #17 | |
Rep 212
Have you tried to play audio via iDrive OEM USB and use wireless Carplay at the same time? I know Bluetooth does the job, but I was hoping one of the users here reports back about the results? |
06-30-2019, 09:41 PM | #18 | ||
SQUEAKY
104
Rep 322
Plugged cable to armrest USB, was able to control through carplay and have audio out through dock. However, you lose 1) Siri audio 2) Waze/Google/whatever guidance instructions and 3) the steering wheel scroll is screwy because since you're through the NBT USB, you can pick what song you want/go next and back, but the scroll also controls the carplay interface. Personally, my AUX is fine for me and I don't have any problems with it. I run mine with full Joyeauto/aux. The only downside is that callers can sometimes hear themselves when we are on the phone. |
theblues86.50 |
06-30-2019, 09:57 PM | #19 | |
Rep 212
It is just as a backup plan should AUX audio quality is not acceptable to play over OEM or Bluetooth. I suspect the issue with the phone calls would be optimizing Carplay mic (location, sound level, etc.) but I could be wrong. |
06-30-2019, 11:11 PM | #20 | ||
SQUEAKY
104
Rep 322
I've been thinking about that, but the problem is that i think it is always in full-duplex audio or the system isn't smart enough to decode/noise cancel the transmission out. So since the other person's voice is transmitted through all 4 speakers, no matter where you put it, the audio will be transmitted. Ofcourse keeping in mind the mic is located somewhere that you can actually use it. The other thing i have to look into is to see if i can somehow modify some wiring in order to use the OEM mics. I thought about putting the carplay one where the OEM driver's is, but the space as alittle tight when i popped it out and frankly i was in alittle bit of a rush at that time. If anyone has any experience in splicing/modifying the OEM mic's, i'd be interested in hearing it. |
theblues86.50 |
07-01-2019, 04:18 AM | #21 |
Rep 14
hey CleanKM - since you've offered to help, can you please show me where you've routed the mic? and also - this unit has it's own usb cable, right? where did you mount that?
I've seen some youtube clips where they mount the usb by the driver's or passenger's knee, I really don't feel comfortable with that setup. |
