03-04-2020, 09:37 AM | #1 |
Rep 70
EPS Coding
Hello,
I recently purchased a used EPS rack and do not have the knowledge to code it. I’ve looked around for ista/esys downloads to code the used EPS, but I can’t seem to find any. Is it worth paying someone to remote code it or is it something I can do myself? Or does anyone have the download and info on how to do it? Thanks |
03-04-2020, 09:53 AM | #2 |
New BMW owner
137
Rep 621
Drives: BMW 316d, BMW F40 116d
I can help you.
Pm please. |
03-26-2020, 11:01 AM | #4 | |
Rep 92
03-26-2020, 05:27 PM | #5 |
Rep 70
Sort of... when I plugged in the donor rack everything worked right away without any coding. It even knew the end stops. The only thing that doesn't work is servotronic (steering feel change between drive modes). I have repair FSC code for the donor car but I can't seem to get any luck with it working.
03-29-2020, 07:18 PM | #6 | |
Rep 92
04-01-2020, 10:53 AM | #7 |
Rep 92
04-03-2020, 08:20 PM | #8 | ||
Rep 70
I could also use an explanation on how to code it please. |
04-04-2020, 03:53 AM | #9 |
Rep 2,302
The same like any other ecu...
Load and activate the VO Read Ecu Mark the EPS Detect CAF for SWE Choose the CAFD with the highest numbers or the bottom one or just any one CAFD and hit OK Hit the button "Code" |
04-08-2020, 07:33 AM | #10 | |
Rep 92
Will give it a try and report back! |
04-08-2020, 07:39 AM | #11 | |
Rep 92
...and how exactly, do I perform that initialisation? Cheers |
04-08-2020, 09:49 AM | #12 |
Rep 92
04-08-2020, 12:27 PM | #13 | |
Rep 92
It successfully reads and shows ACSM AMPT ASD ... EGS ...but no EPS?!? |
04-08-2020, 01:01 PM | #14 |
Rep 92
Here is the screen print
04-08-2020, 01:24 PM | #16 |
Rep 92
04-08-2020, 09:54 PM | #19 |
Rep 70
04-09-2020, 04:57 AM | #20 | |
Rep 92
Can you share what you did to do that coding? Did you have to Read SVT too? Was EPS missing like mine was? |
04-09-2020, 04:59 AM | #21 | |
Rep 92
I tried the ReadSVT and it did bring up the EPS... however, the "Detect CAF for SWE" setting was disabled. See screenshot. |
