04-01-2020, 08:24 PM | #1 |
Rep 157
Drives: 2008 135i
Adaptive headlight error
Is it possible to code out an adaptive headlight warning error? And if so what is required?
04-03-2020, 01:50 AM | #2 |
Rep 780
04-05-2020, 03:47 AM | #4 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
It depends on what is causing the error. You can check the codes with ISTA. Did you replace adaptive lights with non adaptive or something?
04-05-2020, 09:35 AM | #5 |
Rep 359
Yeah the left headlight on mine is none genuine, all functions but error in dash that doesn’t clear so it annoys me, doesn’t fuss me having them so happy with “de-activate” but nobody seems to know the option!
04-05-2020, 12:14 PM | #6 |
Rep 2,302
04-05-2020, 02:54 PM | #7 | |
Rep 780
04-07-2020, 05:35 PM | #9 |
Rep 15
Hi .
Sorry to adding here , but i tried to code adaptive lights on my bmw f30 , i read somewhere that halogen light also was working after someone code it , cannot find this post anymore , so question to you guys , is it possible or not ? i already tried but couldnt find step 4 file just no exist , changed all other but it doesnt work ... anyone know bit more about that ? missing file FEM_BODY 3073 KL_ENABLE_RE KL_Ein KL_Aus Enables cornering lights - Part 4 Thanks for your help |
04-07-2020, 10:10 PM | #10 | |
Rep 780
04-08-2020, 03:34 PM | #11 |
Rep 15
dont know what you mean ?
I thought adaptive headlights mean cornering lights which are using fog lights ? I think my headlights dont have that option as it was standard model , and i upgraded them for some chinese wirh rings .... Is adaptive hardware mean when you start the car they are moving up and down ??? Cos that what they are doing , dont remember do the old one had it or not .. |
04-08-2020, 03:42 PM | #12 | |
Rep 15
I did tried to code cornering lights , sorry name it wrongly - and sorry for writing as I'm Polish and English is not my primary language FEM_BODY 3073 C_CLC_ENA F030enable F030disable Enables cornering lights - Part 1 FEM_BODY 3073 C_BLC_ENA aktiv nicht_aktiv Enables cornering lights - Part 2 FEM_BODY 3066 KL_ENABLE_LI KL_Ein KL_Aus Enables cornering lights - Part 3 FEM_BODY 3073 KL_ENABLE_RE KL_Ein KL_Aus Enables cornering lights - Part 4 FEM_BODY 3062 MAPPING_abbiegel_L_output nsw_l Off Enables cornering lights - Part 5 FEM_BODY 3062 MAPPING_abbiegel_R_output nsw_r Off Enables cornering lights - Part 6 Done all steps to code it apart of step 4 as cant find this file doesnt exist KL_ENABLE_RE Any ideas ?? Also what is coding for follow me home lights - mean headlight with stay on for some amount of seconds after you lock the car or switch off engine ...? Thanks in advance for your help Last edited by bmwf30lucas; 04-08-2020 at 04:40 PM.. |
04-08-2020, 05:05 PM | #13 | |
Rep 2,302
Then use the search in it. If you use another program, search in FEM_BODY 3066 KL_ENABLE_RE To use follow me home you have to pull the high beam lever after ignition off. Your car should have it as standard and no coding is required. |
04-08-2020, 06:21 PM | #14 | |
Rep 15
will try tomorrow Regarding to the follow home light , is there anything to set up the time ?? Thanks |
04-09-2020, 03:40 AM | #15 |
Rep 2,302
04-12-2020, 03:38 AM | #16 |
Rep 359
Just an update, first time coding the car today, managed to read the VO file, remove the 524 option and then manage to check, and code that to the FEM body module and I for the first time in 3 years and error free dash where I can now see my trip computer, all headlights work as they should etc. Thanks for all the help on this it was hugely appreciated and saved me time and money!
04-12-2020, 05:49 AM | #17 | |
Rep 332
This would disable the levelling control. The other settings are OK except for one typo that persists in being quoted every time this topic comes up. FEM_BODY 3066 KL_ENABLE_LI KL_Ein - is correct FEM_BODY 3066 KL_ENABLE_RE KL_Ein - 3066 is the correct section setting, NOT 3073 OK, I see that atzebmw has already responded on this one. |
04-12-2020, 06:09 PM | #18 | |
Rep 15
cjn - thanks - I found it using search engine , already change it but still not work ... Should it work at a day time as well when i switch day time lights and turn steering wheel full ??? yes i have two wheels to enable adjusting level and brightens will change it back tomorrow I did also change few other things , done all at one time , was able to connect to Hu-CIC now , thanks to shawnsheridan for his help , but now got an issue with indicators ,don't really know when it happen as i wasn't drive a car till today , and done many changes till now , issue with indicator , both sides , if I press once not at full position just flick , it should indicate 3 times , but for some reason doing only once now , it may be the issue with C_BLC_ENA ???,I will change it back to disable and see then ... Thanks to everyone for a help I'm really appreciated Last edited by bmwf30lucas; 04-12-2020 at 06:16 PM.. |
04-13-2020, 01:39 PM | #19 | |
Rep 15
So today i had another attempt to code cornering lights . Changed C_BLC_ENA to disable as adjusting was not working , after change work fine . But cornering lights still not working , below few pictures from the changes what i have done ... all seems to be correct - C_CLC_ENA - dont know what was before but now when i chage it to F030 enable , code it and read again , showing all F015 F030 ....... enable .. should it be like that ? can anyone confirm ?? Also indicators stop working as in post above and no changes .... Does anyone have a cheat sheet to code one touch side indicators to blink 1 , 3 or 5 times ... ??? Please help Last edited by bmwf30lucas; 04-13-2020 at 02:20 PM.. |
04-13-2020, 02:40 PM | #20 |
Rep 15
Hi .
Update to the post above The cornering light working fine - there was no issue with them , but they not working at day time Issue with indicators still here , dont have a clue why it change settings , so if flicked once flashing only once not 3 times ... do anyone have a cheat sheet to code it ??? Thanks |
04-13-2020, 04:00 PM | #21 | |
Rep 332
As for the single flash, that is strange. There is a setting for the number of flashes, which used to allow this to be set to any reasonable number, say 5 instead of 3. FEM_BODY / 3060 / BLINKZYKLEN_ANZAHL_TIPP set the value to one less than the desired number of flashes However a fairly recent i-Level update left the setting still there but ignored any change, leaving it fixed at 3. No idea why you're only getting one, unless your BLINK... value has been set to zero. |
04-13-2020, 04:34 PM | #22 | |
Rep 15
I do not want to change indicators to 1 flick but back to 3, as for no reason somehow it start flash just once .... I think i change something during changes I've done in FEMBODY ... 3060lcemaster - changed indicators to flash twice when locking car, and after check it now it comes as UNKNOWN - think type it wrongly and that could be the issue as I did only that change will change it tomorrow as was check all offline in saved file, all settings and found just that wrong .. Also regarding to cornering lights there was no issue , only issue was that I was checking at day time, and that's why I was thinking it's not working night time working as it should Also have you got a cheat sheet , some extended one with all adjustments as the one I've got , have 12 pages and I feel a lot of settings are not included in there ... Thanks for help |
