03-04-2019, 08:46 AM | #1 |
Rep 48
CEL with injen intake n26 engine
Ran fine yesterday but this morning I started it up and I have a cel. Do these intakes cause cels or could it be an install issue?
03-04-2019, 09:33 AM | #2 |
Rep 3,679
Probably an install issue. An intake should not throw a CEL. Make sure the MAF is secure as good practice, then grab a code reader and see what the codes are.
sspade2464.50 |
03-04-2019, 11:46 AM | #3 |
¯\_(ツ)_/¯
537
Rep 1,000
Mines been running for a year with one. No CEL for me. Are you sure all the bolts are snug? And did you install the vacuum line?
03-04-2019, 12:31 PM | #4 |
Rep 943
Drives: F30 328i Msport
Check that all the clamps are on solid, clean MAF and make sure its in there tight and the vacuum line is securely on there, other than that your CEL is probably something else.
03-04-2019, 11:34 PM | #6 |
Rep 537
What other mods are you running?
I've had my Injen CAI for a number of months with nothing other than 10 hp and some cool sounds.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
03-05-2019, 08:37 AM | #7 |
Rep 3,679
+1 for other mods...
LordRuxpin103.50 |
03-05-2019, 09:33 PM | #9 |
Rep 3,679
Likely the intake. Have you checked to make sure everything, particularly the MAF and vacuum line, are secured properly?
03-06-2019, 05:28 PM | #10 |
Rep 537
Super common error that people install the MAF in the wrong direction, which results in rough idle/run and CEL. Also check the connection to be sure it is seated all the way down.
03-11-2019, 09:58 PM | #11 |
Rep 48
so far no more errors. thanks everyone for all the help. as soon as i get a clear day i will take it apart an double check everything for accuracy then i will turn the tuner up to race mode to see if it gives a cell.
03-13-2019, 09:38 PM | #13 |
Rep 48
error code was boost pressure too high. i changed the tune down to +2 psi and it never came back. i will try it at +4 psi now that it has been on there a while and see if the cel comes back.
