03-07-2020, 10:14 AM | #1 |
Rep 228
Drives: 2022 G20 330E
use ISTA remotely through VPN ?
hi, did anyone figured out how to use ISTA through VPN network?
using esys without any problem, but can't get ISTA working remotely. |
03-07-2020, 01:49 PM | #3 |
Rep 228
i use hamachi VPN and connect through IP. the pros are that remote pc does not have to have any files such as launchers, psdzdata files or even esys.. just Laptop with internet, Hamachi VPN and enet cable.
07-05-2022, 01:41 AM | #6 |
Rep 3
Hi, I tried but failed, any trick settings? after vpn connection, just input the enet IP found in Client PC to the Host ISTA, and ISTA can read the vehicle?
07-05-2022, 02:46 AM | #8 | |
Rep 3
remote connect esys is very easy, but I can get ista remotely working. I saw the IP direct connection method in the connection option, add the vpn assigned address for the client computer but connection failed. maybe need to set some route or iptable? btw, any one know ista working port?icom mode or enet mode. |
07-05-2022, 03:05 AM | #9 |
Rep 228
1. in ista choose to connect by ediabas
2. change ediabas IP: VPN IP, Interface: ENET, and PORT: 6801 (i use EDIABAS KONFIGURATOR 2.0.0 for that) Success.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
02-14-2023, 03:36 AM | #11 |
Rep 1
My proxy connection is stable. I bought proxies here - https://proxys.io/en. You can test their work, everything should work.
02-23-2023, 04:22 AM | #12 | |
Coding ECU's remotely
445
Rep 1,176
02-25-2023, 07:49 PM | #13 |
Rep 3
Drives: 2017 330i xDrive
Where can I download ista+ ista/p? Anybody have a link?
