04-09-2021, 06:05 PM | #1 |
Rep 79
XHP in too high of hear in Sport mode?
Just installed XHP (8hp) and I'm a bit confused. Before when I was in Sport/+ it would stay around 2k rpm when cruising. Now it feels like it's in a gear or two too high. Of course it doesn't feel as punchy around town. Also shifts into 8th at like 50mph. I like everything else. Shifts fast and firm. I'm using latest version, map 3. Asking anyone who's played with it, is there a better map version or a setting? Just use stock shift points?
04-09-2021, 07:03 PM | #2 | |
Rep 2,653
04-09-2021, 07:15 PM | #3 |
Rep 79
In drive. Isn't to the left only manual mode? Or is it changed in XHP? Does it stay in a lower gear for you and stay around 2k rpm when cruising?
04-09-2021, 07:33 PM | #4 | |
Rep 2,653
04-09-2021, 08:11 PM | #5 |
Rep 79
Oh! Crap, that was it. Just tried it and it's awesome! I didn't plan on getting xhp quite yet so I hadn't read up on it enough. I just started tuning my PS2 install and my tuner said I needed xhp like now because I was hitting torque limits. So there is an extra mode now. Wow, cool. The Rev matching down shifts are sweet. Thanks man.
04-09-2021, 08:13 PM | #6 | |
Rep 2,653
04-10-2021, 12:43 PM | #7 | |
Rep 7,606
04-10-2021, 07:55 PM | #8 | |
Rep 79
04-10-2021, 08:08 PM | #9 |
Rep 79
Still not sure that it's normal. Before when I was in drive, sport mode on, it would stay in a lower gear and never go below 2k rpm, so the throttle was always responsive. Now with xhp in same mode it drives like it's not in sport. I'm just gonna have to feel it out more. I've only driven it like 20 minutes.
04-10-2021, 08:18 PM | #10 | ||
Rep 7,606
Moving the shifter to the left increases shift speed and holds gears longer, downshifts earlier, etc. If you dont engage manual mode by moving +/- or pulling a paddle then yes, it continues to be an automatic - S and gear $ is displayed. If you engage manual its M# and the car will NOT shift on its own and you will hit rev limiter. Shifter to the left usually also prevents 8th gear all together unless you change that setting. Once you flash XHP, in order to get maximum shift speed and instant paddle response, you need shifter to the left and sport + mode. You might notice a delay in paddle response if the shifter is to the right, regardless of drive mode. There's a table that demonstrates all this but i cant find it right now. Quote:
04-10-2021, 09:09 PM | #11 | |
Rep 79
Would it be wise to reflash it and drive cycle like you stated? It definitely lugs a lot more in drive/sport mode. And I really have to get in the throttle for it to downshift. I'll upload a screenshot of my adaptations. They look fine for 94k I believe. Not a big deal because now I can just put it to the left for the feeling I'm looking for. Also, I was thinking about trying linear throttle in MHD. Does it mesh we'll with XHP? |
04-11-2021, 12:19 AM | #12 | |
Rep 7,606
Naw, you don't need to reflash and do the drive cycle. It's strange you are getting the bogging you describe. From what i read you do not want to do linear throttle and XHP as they are not really compatible. So i wouldn't do that. If you really wanted to you could go into custom settings and change your shiftpoints so that you dont upshift as early (and downshift sooner), but it really shouldnt be necessary. I have been running XHP stage 3 and MHD stage 2+ E20 for well over a year with no complaints and no type of bogging. |
11-15-2021, 04:24 AM | #13 |
Rep 30
Same here. I have mhd stage 1 without linear throttle option and xhp stage 3 and I'm experiencing the same low revs and lag in throttle response in D sport mode. Very disappointed
11-15-2021, 04:47 AM | #14 | |
Rep 30
Thanks |
11-15-2021, 10:42 AM | #15 | |
Rep 7,606
XHP should not lower your shift points as compared to OEM trans tune so you might have something else going on. |
11-15-2021, 11:15 AM | #16 |
Rep 15,858
I'm wondering if the 'Drivetrain' is still checked, for Sport mode. Many of our models of the period have the Sport mode option of Chassis or Drivetrain, or both.
11-15-2021, 11:50 AM | #17 |
Rep 7,606
Also a possibility. All i know is that XHP should not cause what he has described with default settings on stage 3.
11-28-2021, 03:36 PM | #18 |
Rep 770
I just installed xhp today, the newest version for my trans, I believe 3.5. it has the same function. Stock the car would never go into 7 or 8th gear unless I was at least doing a hundo. Now it goes down to 8th as soon as I stop accelerating, and won't kick back down unless I romp on it hard. It is very unsporty in sport mode. With the shifter to the left, it will keep it in a lower gear. But with the trans in normal mode, drive mode selected as sport, it just goes down to 8th gear like OP states. This does not seem right
11-28-2021, 05:49 PM | #19 | |
1296
Rep 3,533
11-29-2021, 07:04 AM | #21 |
1296
Rep 3,533
I mean, if you go into the settings there is a ton of stuff you can change. that's one of them. I'm not sure how much less vague that is.
11-29-2021, 02:47 PM | #22 | |
Rep 7,606
Which stage did you flash and did you check any of the other options? There are options that could cause exactly what you are describing that are designed more for fuel economy. I run stage 3 with everything default except max RPM (which does not affect how early it shifts) and i have zero issues with how soon/low rpm the upshifts are in normal driving... It does shift relatively early because that's the ideal way to accelerate under low throttle inputs in D/comfort. |
