09-14-2016, 02:44 AM | #23 | |
Rep 931
in my case the error goes out when WOT.
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
09-14-2016, 01:40 PM | #24 |
Rep 113
Mine came up pulling out of a parking lot driving slowly and did not go away with full throttle or jb4 code clearing. Carly brought up these errors
Central Gateway / zentrales Gateway: - Fault: :Synchronization failed - Code: CD0487 <---------------------------> Fuel pump / Kraftstoffpumpe: - ECU OK, no fault code <---------------------------> Getriebesteuerung /Transmission: - Fault: sorry, unknown DTC fault - Code: CF16E2 <---------------------------> Tire pressure control / Reifendruck Kontrolle: - ECU OK, no fault code <---------------------------> Speech recognition / Spracherkennungs-system: - ECU OK, no fault code <---------------------------> Headphones / Kopfhoerer Schnittstelle: - Fault: sorry, unknown DTC fault - Code: D78C02 - Fault: sorry, unknown DTC fault - Code: 220440 <---------------------------> ABS + DSC: - ECU OK, no fault code <---------------------------> Gear switch / Gangschalter: - ECU OK, no fault code <---------------------------> Instrument cluster / Kombiinstrument: - Fault: :Error message - Code: E12C1A - Fault: :System time is set back - Code: B7F668 - Fault: :Error message - Code: E114BE I was able to clear the codes with Carly and we'll see if they come back. Carly is a must buy if your not an inpa guy! |
09-15-2016, 01:52 AM | #25 |
Rep 931
Remove JB4 clear code FUNCTION
No error found in the Engine ECU The others are normal
09-15-2016, 02:10 AM | #26 |
Rep 1,290
Do you mean I can safely install the JB4, and if the error codes appear, remove the JB4 will just clear these codes ?
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
09-15-2016, 02:56 AM | #27 |
Rep 931
No
first of all, install JB4 but remove the function "clear DME codes" in the JB4 utility program. This in order to check the car and the "feeling" with the JB4
09-15-2016, 03:12 AM | #28 |
Rep 1,290
Hmm I ordered without the cable but with the bluetooth, not sure i'll be able to do that.
09-15-2016, 03:31 AM | #29 | |
Rep 931
Intall JB4 on the laptop and connect on virtual com port via BT also check the IOS/Android utility Ah..... Remember to record the sound of your akra !
09-15-2016, 03:33 AM | #30 |
Rep 1,290
Thanks a lot for your help
Will record the Akra in coming two days, even though video rarely does justice to real sound, I do happen to have a good quality microphone.
09-15-2016, 07:20 AM | #31 |
Rep 276
09-15-2016, 07:43 AM | #32 |
Rep 931
Your sound is PERFECT !!!!!
Any news about your issue on your map ? BR-PERFORMANCE
09-17-2016, 03:33 PM | #38 |
Rep 276
Car runs perfectly now. Even faster than before. Bruno from BR created 15 flash files and the car has been tested all this time untill everything was perfect.
You should consider going to BR, they developed the perfect flash for our cars now. :-) |
09-18-2016, 01:24 AM | #41 |
Rep 1,290
JB4 is for next weekend, I'll be away most of next week
09-18-2016, 02:29 AM | #42 |
Rep 931
Great JOB !!!
09-19-2016, 01:44 AM | #44 | |
Rep 931
It's impossible for me Lyon or Marseille : needs a lot of days
