07-15-2020, 01:19 AM | #1 |
Rep 13
BM3 Transmission Flash vs. xHP Transmission Flash
I just ordered BM3 for my 2016 340i and I'm on the fence about getting the xHP transmission flash to go along with it, is the included BM3 transmission flash comparable?
07-15-2020, 01:50 PM | #2 |
Rep 458
The BM3 transmission flash is only for the S55/N55 and not for the B58. You definitely want to get xHP especially once you go BM3 Stg 2 or above.
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
07-15-2020, 01:52 PM | #3 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
07-15-2020, 02:11 PM | #4 |
Rep 458
I'd still personally go with xHP since the BM3 tcu flash only removes TQ limiters. xHP is a comprehensive tcu flash that allows you to adjust launch control and control shift points in addition to a bunch of other features. Once you go xHP stg 3 it's pretty hard to go back to anything else.
07-15-2020, 03:35 PM | #5 |
Rep 1,239
07-15-2020, 11:24 PM | #6 |
Rep 13
Well it looks like its xHP for me then, and if 2016 B58 made you think I had an N55/S55 then you need to give your head a shake lol.
I'm deployed right now just north of Iceland so I've haven't been able to install and play with the BM3 tune yet, if so I probably would have figured out that the trans flash is only for the n55/s55. |
02-19-2022, 01:08 PM | #7 |
Rep 17
02-21-2022, 06:57 PM | #9 | |
Rep 4,876
02-22-2022, 10:58 PM | #10 | |
Rep 101
02-23-2022, 01:22 PM | #11 | |
Rep 4,876
software tells you when you try to select a map, but not sure if it's listed on the website. |
02-23-2022, 10:43 PM | #12 |
Rep 180
XHP Stage 1 is basically stock, it only removes torque limiter and adds the gear you are in while in drive mode. XHP Stage 2 and 3 change a lot more as they increase line pressures, change shifting points and are more aggressive overall when upshifting and downshifting.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
