07-16-2018, 05:58 AM | #23 | ||
Rep 63
I'm choosing between Awe & mppsk Is the power gain noticeable? |
07-16-2018, 09:17 AM | #25 |
Rep 1,170
Most say the power is noticeable but to be honest I didn't notice a huge difference. The few dyno's we have don't lie and they say about 35 HP, 40 torque increase and time slips show two tenths of a second faster 0-60 times. I consider adding MPPSK the best thing I've ever done to a car.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
07-18-2018, 06:45 AM | #26 | |
Rep 63
Beek707.00 |
07-18-2018, 08:01 AM | #27 |
Rep 259
Drives: 16' AW 340i xDrive
OP........... BMW Service Center or Dealership maybe?
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
07-20-2018, 08:06 PM | #28 | |
Rep 189
Now I don't have to have the valves open when BMW thinks they should open. |
07-21-2018, 07:26 PM | #29 | |
Rep 1,457
Once were all flashed and settled with your Pure Stage 2, we should meet up with HitmanHearns
2024 X3 M40i
2014 BMW M5 |
07-22-2018, 01:01 PM | #30 |
Rep 487
07-23-2018, 06:47 PM | #31 | |
Rep 63
08-08-2018, 12:25 PM | #32 |
Retired Car Nut
42
Rep 55
I had the same problem with exhaust valves staying open
I have a 2017 340i with the MPPSK installed. I am assuming that you have the MPPSK installed as well, if not, then all bets are off!
I experienced the very thing you are describing in your original post. Here are the circumstances around my experience. What you are seeing is not normal for the car (once again, assuming MPPSK). On my car, the normal operation for the exhaust valves is they remain closed during the first couple of minutes after a cold start and when I am operating the car in Comfort or Eco-Pro mode (HA, I never use Eco mode!). Anyway once the car is "warm" if the mode is Sport or Sport+ the exhaust valves are open. During my 20,000 mile service the dealer updated the "firmware" in the car and when I picked the car up I had the symptoms you described. When I would start the car, the valves would be closed, but after it was warm (60 seconds or so) the exhaust valves would open no matter what driving mode I selected. They were always open as you describe if I am understanding you correctly. The Shop Forman knew of a bulletin for this behavior, but the recommended procedures in the bulletin did not correct the problem. They immediately opened a PUMA case and got Germany involved. It took them a couple of days, but the engineers in Germany accessed the car remotely and found the problem. They wound up writing new code for my car to get things operating normally. So, what you are seeing is not normal, and like you, while many people would love to have the valves open all the time, that is not the way it is supposed to work. And like you, I wanted it fixed! And it can be fixed. Hope this helps. |
Panda340i16.00 |
08-14-2018, 06:13 AM | #33 | |
Rep 63
Thank you so much! |
07-29-2019, 08:58 PM | #35 | |
Rep 331
Drives: M140i F20 LCI-2
I thought of pulling fuses 146 and 147 in the boot when the flap is open so it would then stay open permanently ... but this would also disable Parking Assistant, so I have stuck with Carly so far. If, like me, you use an Android device to connect to the Carly Adapter and want to ensure no connectivity issues (particularly with Android 9 Pie), go to Settings >> System >> Advanced >> Developer options >> Bluetooth AVRCP version >> change from 1.4 to 1.6. If you cannot see Developer options, Google how to open this feature for your device. __________________________________________________ ___________
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. Last edited by DrGadget; 08-16-2019 at 08:11 PM.. |
07-30-2019, 09:03 AM | #36 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
Bit off topic but how did fix the squeak?
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
07-30-2019, 11:13 AM | #37 | |
Rep 295
You can WD-40 it or a couple drops of motor oil. I find that after a few months I gotta do the same thing again. Im running afe exhaust at the moment. Not sure how much this differs to others |
DrifterX514.00 |
02-18-2020, 04:07 PM | #39 | |
Rep 1,641
Beek707.00 |
