06-30-2018, 06:32 AM | #1 |
Rep 2,495
JB4 + BT Arriving soon, any tips?
Hi all, I've finally ordered a JB4 with Bluetooth that arrives on Monday.
My 440i has got he MPPSK so just looking for some good tips. I always run a high octane fuel in the UK - think it's similar to the US 92/93. In the UK it's 100RON. Any installation or config tips will be greatly appreciated
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
06-30-2018, 02:00 PM | #2 | |
Rep 189
If you didn't order the FF and EWG wires, order them and install them first. Then check out my Map 6 settings over there. Lots of people have had better success with them vs. the standard maps and settings. |
moff1362.50 |
07-03-2018, 12:54 PM | #3 | ||
Rep 2,495
I installed it today with Bluetooth and everything is working fine. Seems to provide more cracks and bangs from my MPPSK too. On map 1 at the moment and will have a play with map 2 this weekend before logging some runs. Loathed to try map 6 until I have more confidence and you guys see my logs on N54Tech. Initial 3 mile drive on map 1 was good but not so smooth for power delivery albeit more.
07-04-2018, 06:23 AM | #4 | |
Rep 2,495
I’ve logged to hard pulls but can’t seem to register for N54Tech as it ask for an anti spam question and I’ve no idea what it is - tried BMS but it fails. Map 1 and 2 seem good so far, but I do get a hesitancy before full power hits and I fly off down the road. Except for that no issues in either map, even with hard 4th gear pulls all the way to the red line. Questions - will your settings for maps 6 reduce the hesitancy? What does map 5 do? Thanks
07-04-2018, 06:29 AM | #5 |
Rep 2,495
First pic - Map 1 run from 4th to redline
2nd pic - Map 2 run from 4th to redline
07-04-2018, 10:52 AM | #6 | |
Rep 189
Can you attach your raw CSV files so I can review in more detail? What fuel are you using? Yes, Map 6 should reduce the hesitation, if dialed in properly. Map 5 is just a more aggressive version of Map 3, and requires very high octane. Last edited by Bullitt1841; 07-04-2018 at 10:59 AM.. |
moff1362.50 |
07-05-2018, 11:02 AM | #7 |
Rep 2,495
Can't seem to attach CSV files on here which is annoying??
Any ideas?
07-06-2018, 02:29 AM | #9 |
Rep 2,495
Done! THANKS!
07-07-2018, 01:49 PM | #10 |
Rep 189
It looks like you have plenty of octane, I just don't like how lean you are running. This is pretty typical for a non-MPPSK or M_40 car. If it was me, I would be careful and not run anything higher than Map 1, but that's just me.
Your AFR gets better at the end of the Map 1 log, but only because your DME BT lowers and you have throttle closure at the end, lowering boost and temporarily richening AFR. Can you take some Map 0 logs to see what your AFR is supposed to look like with the stock flash? |
07-09-2018, 09:17 AM | #11 | |
Rep 2,495
07-09-2018, 09:18 AM | #12 |
Rep 2,495
Currently my MPPSK exhaust valves stuck open too - bloody annoying
07-10-2018, 04:57 AM | #13 |
Rep 462
07-11-2018, 02:27 AM | #14 |
Rep 189
