      09-24-2021, 04:40 PM   #15973
JPierce63
Drives: 2014 328i
Thanks Shawn,
If I need to calibrate my 328i (N20)'s DME, injectors, etc.. and read trouble codes, etc.. Is E-SYS what I should be using?
Jeff
      09-24-2021, 04:43 PM   #15974
shawnsheridan
shawnsheridan's Avatar
Originally Posted by JPierce63 View Post
Thanks Shawn,
Jeff
No. E-Sys is for Coding and Programming. For Diagnosis, you need ISTA+.
      09-24-2021, 07:00 PM   #15975
omarsaudi
Drives: BMW F30
Thanks a lot
      09-25-2021, 09:28 AM   #15976
Ruse
Drives: BMW F34 335d 2015
Hi all
any link for Download SWID Reader
i'm appreciate
Tks
      09-25-2021, 09:35 AM   #15977
shawnsheridan
Originally Posted by Ruse View Post
Hi all
i'm appreciate
Tks
PM sent.
      09-25-2021, 11:15 AM   #15978
JPierce63
Drives: 2014 328i
Thanks Shawn. I am struggling to find any active ISTA download info here in the bimmerpost community. Can it be found here? Do you have a link to ISTA +?
      09-25-2021, 11:21 AM   #15979
shawnsheridan
PM sent.
      09-29-2021, 01:07 PM   #15980
Darth Vader
Darth Vader's Avatar
Drives: 2019 BMW X5 40i
Hi Shawn, could you send me the link to download the latest E-Sys Pro & psdzdata please?
      09-29-2021, 01:09 PM   #15981
shawnsheridan
PM sent.
      09-30-2021, 08:27 AM   #15982
barni320
Drives: BMW 428i F32
Hi,
Can you tell me what's the difference between coding on running engine or ignition? Most of the people recommend to do it on ignition. Are there any contraindications, that coding on running engine can brick something?
      09-30-2021, 09:58 AM   #15983
shawnsheridan
Originally Posted by barni320 View Post
Hi,
If you Code with only Ignition on, the car battery may not provide adequate Voltage to ECU(s)
Coding with Engine running ensures all ECU have adequate Voltage, and so long as you do NOT code DME / DDE (Engine ECU) with Engine running, then you have nothing to worry about.
      09-30-2021, 08:10 PM   #15984
barni320
OK, thanks for answer, that's what I was thinking about. I was aware of suddenly lost of power, because of low battery.
But I can't understand why people recommend to do it on ignition only 🤔. The same case when we talking about esys or bimmercode, even manufacturer of bimmercode says in manual that should be use on ignition. Confusing.
      10-02-2021, 10:58 AM   #15985
jmrluke
Drives: f30 318da
Thanks for the link! Appreciated!
      10-02-2021, 10:59 AM   #15986
shawnsheridan
Your Receive PM function is disabled. PM me when working.
      10-04-2021, 05:01 PM   #15987
CarlosIsDead
CarlosIsDead's Avatar
Drives: 2016 BMW M3
Originally Posted by RT330e View Post
How many posts to enable PM?
Requirement is:
"In order to use the PM system and be a full fledged member of this community, you will have to make [COLOR="Blue"]4 post replies and wait 1 hour[/COLOR] for your account to be upgraded."
Sent you a pm shawn!
      10-07-2021, 04:40 PM   #15988
Kmanshek
Drives: F36 435xi GC
Please
      10-07-2021, 04:41 PM   #15989
shawnsheridan
PM sent.
      10-07-2021, 04:53 PM   #15990
Kmanshek
Thank you so much
      10-07-2021, 05:02 PM   #15991
Kmanshek
Hi Shawn, where i can find the latest cheat code for F36. i want to see if i can change the setting from 6.5" to 8.8" screen, it was because i bought a aftermarket 10.25" screen. and i would like to change the screen setting.
thank you so much
      10-07-2021, 05:14 PM   #15992
shawnsheridan
thank you so much
Cheat Sheets replaced long ago by Launcher Built-In Cheat Codes, but screen size coding would not be something covered by either.
You want to change from 6.5" to 8.8" to install a 10.25" screen?
      10-13-2021, 01:03 PM   #15993
kliff251
Drives: BMW 320d
Привет, Шон, не могли бы вы прислать мне ссылку для загрузки последней версии E-Sys Pro и psdzdata?
      10-13-2021, 02:15 PM   #15994
shawnsheridan
PM sent.
