12-26-2020, 10:43 AM | #1 |
bt5000
Rep 45
BMW AH3 N55 335i F30 512 WHP 526 lb-fts 1/4 mile 10.917 sec
How to modify AH3 N55 335i F30 to have 512 WHP 526 lb-fts 1/4 mile 10.917 sec?
Please give an idea: HPFP, LPFP, PI, bootmod3 custom tune, e20,e85, upgrade turbo, meth Car installing Dorch stage 2 + pure turbo stage + E20 or Pure turbo stage + fuel it lpfp stage 2 + PI + E20 achieve my target? or I need to run full e85 and meth injection (I think it's not practical for daily use) Please advice. |
12-26-2020, 07:29 PM | #2 |
Rep 1,051
Budget ?
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
01-26-2021, 09:15 AM | #5 |
Rep 461
You can do it for 6k if you can diy some of the install.
What wehee126 said for mods. Though a lpfp may not be needed for those power levels unless you choose PI over hpfp. Also will need a tune like MHD/BM3/JB4 and a race intercooler. If you don't have easy access to e85 you will need meth. Last edited by 435gc; 01-26-2021 at 09:24 AM.. |
01-26-2021, 01:27 PM | #6 | |
Rep 7,555
While you are upgrading the turbo you probably also want to do turbo inlet and DV like turbosmart. Stock intake and exhaust are fine. |
01-27-2021, 02:01 PM | #8 |
Rep 7,555
There are no specific issues so long as your tune is made for it (if you run OTS tunes you rely on fuel trims to compensate). But if OP has access to ethanol and upgrades the HPFP, that is a simpler solution for additional octane and fueling.
01-27-2021, 07:29 PM | #9 |
Rep 1,051
I'd say go speedtech turbo kit. You'll need supporting mods of course but you'll get there little by little and supports 100% oem fitment for everything. You will need to upgrade fueling to take advantage of the turbo, but the hard part would be done for you.
https://speedtech.com/pages/bmw-n55
01-28-2021, 07:50 AM | #11 |
Rep 235
Yeah Im on custom tune.
02-01-2021, 10:27 AM | #12 |
bt5000
Rep 45
How much to go speed tech? https://speedtech.com/products/bmw-n...8474-turbo-kit + anything else?
Tags |
activehybrid 3, e20, e85, hpfp, lpfp, port injection, turbo |
