BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > USA side marker coding to Euro cars
      03-03-2022, 04:46 PM   #1
Daveyvtec
Drives: BMW F30 318 M Sport
Hi all,
In BimmerCode there’s an option for US side markers which I switched on. There’s another option to have the wing mirror lights switched on but there isn’t an option for both.
Does anyone know how to get both on at the same time? Is there an option I’m missing or maybe is it something that’s done through expert mode??
Cheers
      03-16-2022, 07:36 AM   #2
Daveyvtec
Originally Posted by Daveyvtec View Post
Hi all,
Cheers
Anyone ever see this?? Any ideas?? Thanks
      03-16-2022, 01:34 PM   #3
TheNine90
Drives: bmw
I have seen on bimmercode there are three options: mirror turn signals, separate turn signals, turn signals.
Have you tried separate lights option?
If you tried it can you tell me which specific light is being activated?
      03-16-2022, 02:22 PM   #4
TheNine90
Drives: bmw
Make sure you backup the existing files or export them. You can also note down the original values before you change them.
Try this in expert mode. Use the search function in the top bar . Use custom values to edit the bytes.
1.First Set US sidemarkers to turn signals option.
2.Enter expert mode and check the following if they are set correctly:
MAPPING_SIDEMARKER_L_OUTPUT ==> fra_v_l (0D)
MAPPING_SIDEMARKER_L_FUNCTION ==> standlicht (01)
MAPPING_SIDEMARKER_R_OUTPUT ==> fra_v_r (0E)
MAPPING_SIDEMARKER_R_FUNCTION ==> standlicht (01)
3.Now change these values
For Left Mirror turn signal:
MAPPING_UNIVERSAL_3_OUTPUT ==> 10
MAPPING_UNIVERSAL_3_FUNCTION ==> 01
The rest of MAPPING_UNIVERSAL_3 should match MAPPING_SIDEMARKER_L
For Right Mirror turn signal:
MAPPING_UNIVERSAL_4_OUTPUT ==> 11
MAPPING_UNIVERSAL_4_FUNCTION ==> 01
The rest of MAPPING_UNIVERSAL_4 should match MAPPING_SIDEMARKER_R
4.Code the values.
5.Check the lights if they are functioning as required.
      03-16-2022, 06:17 PM   #5
Daveyvtec
4.Code the values.
Thanks for that man. I'll give it a go and see how I get on. Really appreciate the input, thanks again!
      04-10-2022, 06:33 PM   #6
cortes90
cortes90's Avatar
Spain
Drives: BMW F30 320d
Te funciono, me interesaría ponerlo gracias y un saludo
coding, lights, side markers
