05-11-2021, 07:35 PM | #1 |
Rep 176
BMW B48 Engine Rebuild DIY with Forged Pistons and Rods
Engine Rebuild S1 E1 DIY -
BMW F30 330e Hybrid B48 Location – Trinidad 🇹🇹 Details: • Removal of engine covers • Removal of plugs and coils • Removal of injector wires • Retest compression • Borescope - visual inspection • Removal of charge pipe • Removal of intake pipe • Jack up, place on ramp and remove shields • Drain oil • Disconnect HV, 12V battery and auxiliary battery • Drain coolant both high and low temperature • Remove coolant bottles • Remove battery holder, control unit and holder • Removal of AC compressor bolts and jack • Removal of water hoses • Unbolt downpipe • Removal of control sensors O2 Like, share, follow to support: https://www.instagram.com/bm3shahsmachineshop/ https://www.facebook.com/BM3ShahsMachineShop/ Thanks Authorized BM3, xHP & F80Paul Dealer Special Thanks to @trinivlogs Like, share, follow to support them: Instagram: @TriniVlogs (https://www.instagram.com/trinivlogs/) Facebook: @TriniVlogs (https://www.facebook.com/TriniVlogs/) YouTube: Trini Vlogs (https://www.youtube.com/channel/UCCj...NjlXCodugL6I5w) Last edited by SRHosein; 06-06-2021 at 12:40 AM.. |
05-12-2021, 09:46 AM | #2 |
Rep 73
Nice!!! This'll be sweet to watch.
I have a B46 and I really want to put a pure400 stage 2 in it and upgrade the pistons, rods, and crank shaft and boost it to high heaven. Looking forward to the premier!
2017 BMW 330ix MSport Estoril Blue - B46, ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bm3 Stage 2. FI Exhaust, xHP Stage 3 OTS Transmission tune. CSFRace heat exchanger. Performance M Brake kit. AFE Carbon Fiber D.A.S.
https://www.instagram.com/bfourtysick/ |
SRHosein194.00 |
05-12-2021, 01:23 PM | #3 |
Rep 176
I have not seen any crank shaft upgrade but was told our stock crank shaft should hold some serious power.
05-12-2021, 02:04 PM | #4 | ||
Rep 73
Although, being modular, I have read that the B46 in the F series has the SAME CRANK as what is in the B58, just missing two pistons. In which case, yeah, they can handle SERIOUS power. Even better, the B48 is closed deck. Hello boost!
VipinLJ1941.50 |
05-15-2021, 10:02 AM | #6 |
Rep 176
Engine Rebuild S1 E2 DIY is up!
BMW F30 330e Hybrid B48 Location – Trinidad 🇹🇹 Details: • Removal of starter • Unbolting of transmission oil cooler • Removal of hood shocks and support • Removal of downpipe bracket • Support engine with cherry picker • Removal of engine mounts • Removal of engine/transmission bolts • Disconnection of transmission jack and cable to remove • Disconnection of all additional cables, coolant hoses, ect • Shift oil cooler and AC compressor to the side • Removal of engine • Mounting engine to engine stand • Removal of engine cover by crank pully and coolant lines • Turn engine and lock in TDC Thanks for watching and subscribe to say updated |
05-21-2021, 01:45 AM | #7 |
Rep 176
Engine Rebuild S1 E3 DIY is up!
BMW F30 330e Hybrid B48 Location – Trinidad Details: • Removal of HPFP • Removal of connectors and engine harness • Removal of fuel rail • Removal of injectors • Removal of intake and exhaust actuators • Removal of cylinder head cover • Removal of timing chain tensioner and guide • Turn engine and lock on TDC • Removal of timing chain and secure • Removal of oil lines on turbo • Removal of cylinder head • Initial inspection of cylinder head and block Thanks for watching and subscribe to say updated |
05-22-2021, 10:11 AM | #8 |
Rep 176
BMW B48 Engine Rebuild DIY S1 E4 is up!
Hopefully this helps the BMW community Details: • Removal of sound insulation at the bottom of engine • Disconnect connector for oil level sensor • Removal of oil sump • Removal of oil pump • Removal of windage tray • Main bearing cap removal and inspection • Clearance test on main bearing • Reinstall main bearing • Removal of pistons • Inspection of pistons and cylinder walls |
05-27-2021, 06:19 PM | #9 |
Rep 176
BMW B48 Engine Rebuild DIY S1 E5 is up!
Hopefully this helps the BMW community Details: • Inspection of old piston to wall clearance and old ring gaps • Inspection of block • Assemble new pistons and rods • Inspection of new piston to wall clearance and new ring gaps • Inspection rod bearing clearance • Installation of piston rings • Installation of new rod bearings on new rods |
05-29-2021, 11:52 AM | #10 |
Rep 176
BMW F30 330e B48 Hybrid Engine Rebuild DIY S1 E6 is up!
Hopefully this helps the BMW community Details: • Set piston rings • Lubrication of pistons, cylinder walls, rod bearing, rod journal, piston ring compressor tool • Installation of pistons • Installation of oil pump • Installation of windage tray • Cleaning oil sump • Installation of oil sump • Cleaning of cylinder head • Installation of new head gasket • Installation of cylinder head |
06-02-2021, 10:06 AM | #11 |
Rep 176
BMW F30 330e B48 Hybrid Engine Rebuild DIY S1 E7 is up!
Hopefully this helps the BMW community Details: • Installation of timing chain • Installation of timing guide • Installation of timing chain tensioner • Lubrication of camshaft • Rotation of engine • Installation of cylinder head cover • Installation of intake and exhaust actuators • Installation of HPFP • Installation of sound insulation at the bottom of engine • Installation of connectors and engine harness • Installation of oil lines for turbo • Transmission clean input shaft cleaned and greased • Lower engine into engine bay using cherry picker • Installation of transmission connector and wiring at the back of engine • Installation of AC compressor • Installation of Transmission Oil cooler • Installation of engine • Installation of engine mounts |
jtalweezy37.50 |
06-05-2021, 12:22 PM | #12 |
Rep 176
BMW F30 330e B48 Hybrid Engine Rebuild DIY S1 E8 is up!
Hopefully this helps the BMW community Details: • Installing ECU, coolant hoses/bottles, wiring were done prior • Installation of oil and coolant • Installation of 12V auxiliary battery, 12V battery in trunk and HV battery • Coolant Bleed Procedure • Injector Test • Installation of injectors and fuel rail • Compression test • Installation of plugs and coil packs • Connection of coil packs and injectors • First start up • Review fault codes and rectification • Inspection for oil or coolant leaks • Inspection of oil and coolant level • Test drive |
jtalweezy37.50 |
