01-17-2017, 05:54 PM | #1 |
Rep 136
I drive 5 update
Hi
Just wondering if anyone knew if BMW will push an update to existing idrive 5 owners to bring in the new 'active tile' design that's been shown on all the latest 4series LCI info? Would be pretty frustrating if the current version becomes out dated after just 6 months of existence! Sam |
01-18-2017, 02:24 AM | #2 |
Rep 130
Probably not.
Like you, I have missed out on ID5 by a month, even though the hardware is the same (except for the ATM, communications module), no official update from BMW is available. I can most definitely assure you this will be the case for ID5->ID6 |
01-18-2017, 04:10 PM | #3 |
Rep 136
Ahh I've actually got Idrive 5, but the latest images of the new LCI releases look slightly different; rather than have all 6 tiles on one screen it looks like the new version has two screens of 3 tiles? Hopefully it should just be an update?
01-19-2017, 01:34 AM | #4 |
Rep 8,364
There is ID5, ID6 lite, and ID6. OTA or otherwise updates will not be pushed. Can be done through E-sys.
01-19-2017, 10:28 AM | #5 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
ID4 NBT EVO HW2.3 ECE Version (Flashed to 59.4 ID5.0, FDL coded to ID6: Installed onto 2016 328i xDrive) Fully working minus Telematics. GPS will not work via ATM module, GPS is using external antenna. ID4 NBT EVO HW2.1 NA Version (Flashed to 59.4 ID5.0, FDL Coded to ID6: Cannot code Navigation. CarPlay, Voice Control, Satellite Radio all work. ID5 NBT EVO NA Version (Native ID5.0, FDL coded to ID6) 2017 F25 X3 28i NA Spec
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 01-19-2017 at 10:34 AM.. |
AndrewC198910931.00 kcsmithcyril0.00 |
01-19-2017, 12:00 PM | #6 |
Rep 255
I believe in the 4 series refresh they just snowed that it is getting idrive 5. After that is released I'm hopeful there will be some more ease to port that over to the 3 series.
2011 X5 xDrive 50i - retired
2016 340i xDrive - retired 2020 M4 Coupe |
01-19-2017, 12:36 PM | #7 |
Rep 1,976
According to the pictures from the unveiling, it is iDrive 6.0 which can easily be coded if the vehicle is on iDrive 5.0.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
mdai245104.00 AndrewC198910931.00 |
01-19-2017, 01:03 PM | #8 |
Rep 488
01-19-2017, 01:09 PM | #9 |
Rep 1,976
You have NBT1 ID4, one of the very early builds since yours is a Active Hybrid 3.
01-19-2017, 01:22 PM | #10 |
Rep 8,364
01-19-2017, 06:20 PM | #11 | |
Rep 488
01-19-2017, 06:38 PM | #12 | |
Rep 8,364
01-19-2017, 07:01 PM | #13 |
Rep 4,553
I heard that NBT_EVO units with ID5+ have 2GB RAM where early EVO hardware had 1GB RAM.
Possibly one of the others who have dug into this more deeply can confirm/deny.
2023 840GC | 2021 740i | 2019 X3
01-25-2017, 11:26 AM | #14 |
electrified
32
Rep 127
What the hell, wasn't iDrive 5 just released and now they are releasing a newer iDrive? My was built in september last year and comes with the iDrive 5 with 6 tiles, can the car be coded to the new iDrive with active tiles?
01-25-2017, 01:19 PM | #15 | |
Rep 8,364
OPTIONS id4_plus_plus = 00 id5 = 01 id5_plus_plus = 02 id6_light = 03 id6 = 04 |
2kaccordocoupe1272.00 david51537.50 |
01-25-2017, 01:22 PM | #16 |
Rep 1,976
Yep, I have tested this one several vehicles and it does work as long your ID5 build is from July 2016 onwards.
01-25-2017, 02:26 PM | #17 | |
electrified
32
Rep 127
Does this give me any more options or will i loose some options when doing this? Or is this simply just the GUI? |
01-26-2017, 09:34 AM | #18 |
Rep 1,976
It pretty much just changes the home screen with the tiles showing a live preview of each menu option. Everything else is the same.
01-26-2017, 04:18 PM | #20 |
Rep 8,364
mikkenoone27.00 |
01-28-2017, 07:58 AM | #21 |
Rep 342
If the difference between ID5 and ID6 is only the home screen...but the hardware is the same... I don't understand why BMW doesn't update ID5 cars to ID6 when upgrading the I-Level at the dealers....
If you have ID5 from factory....upgrading to ID6 is only a matter of changing an option on e-sys and all will work? All BMW Online, eCall, ConnectedDrive Services etc will continue to work? Thanks. |
01-28-2017, 12:44 PM | #22 | |
Rep 8,364
