10-10-2016, 05:38 PM | #67 | |
Rep 3,320
Yes a 2015 are made from mid summer 2014 to beginning of summer 2015 so more then likely it would still work for you, and yes questions but to fit a 10.2'' you have to cut into the dash to make it fit so its not completely reverable also coding will be different entries since the display resolution will be different and most likely will need to be added to tho possible logs another way. basically 8.8 works clean and easy , 10.2'' may get messy!!!! lol |
10-10-2016, 05:41 PM | #68 | |
Z4 35is
59
Rep 270
"more then likely it would still work" Is there a chance it wont work? |
10-10-2016, 05:42 PM | #69 | |
Rep 565
The LCI model doesn't have this, plus it is noticeably lighter than the pre-LCI one. I guess they changed the manufacturer and/or technology, resulting in a different color representation that you can notice only when looking from specific angles. |
10-10-2016, 06:19 PM | #70 |
Rep 3,320
No it will work , I just didn't know your production date month as there are a few exceptions thats the only reason I said more then likely, but your car is within the range of dates so you're good
10-10-2016, 06:48 PM | #71 | |
Z4 35is
59
Rep 270
Now its all about finding the deal on screen. I read about pre-LCI having blue tint and low brightness. And LCI not voltage compatible. Do you know if those are true? |
10-10-2016, 09:21 PM | #72 | |
Z4 35is
59
Rep 270
10-10-2016, 09:25 PM | #73 | ||
Rep 379
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
10-10-2016, 09:42 PM | #74 | |
Z4 35is
59
Rep 270
Only question is compatibility. everyone on that thread is using HU_NBT. |
10-10-2016, 09:44 PM | #75 |
Rep 379
Yup ... it won't power on without coding under hu_nbt
10-10-2016, 09:48 PM | #76 |
Z4 35is
59
Rep 270
10-10-2016, 09:51 PM | #77 |
Rep 379
Yes 8.8 resolution looks terrible so i had to set it to10.25... i bought this from
car-part.com
10-10-2016, 09:58 PM | #78 |
Rep 3,320
It will work if your willing to cut about 1+/- inch on either side of your dash board away where the screen goes, and possibly the back of the dash as I'm not sure the shape of the rear bezel of the 10.25 display . I would be 100% sure you want the extra 1.45" at the expense of potentially destroying the dash... just food for thought not saying its the worst idea. it is pretty cool
taranfx59.00 |
10-10-2016, 10:10 PM | #79 | |
Z4 35is
59
Rep 270
He managed to do it without cutting anything visible from dash. Looks neat. Are you sure this works for HU_ENTRYNAV? If it does I'll go that route. |
10-17-2016, 02:10 PM | #80 |
Rep 418
So today I got the coding done and everything works perfectly except they couldn't get dvd in motion to work. They said it's incompatible on my system. It's a major bummer....
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
10-17-2016, 04:13 PM | #81 | |
Rep 3,320
10-17-2016, 04:45 PM | #82 | |
Rep 263
taranfx59.00 |
10-18-2016, 02:23 AM | #83 |
Z4 35is
59
Rep 270
10-18-2016, 04:00 AM | #84 |
Rep 70
Drives: BMW 430d M-Sport
Hello, can I fit screen from F20 on my F30? There is some difference in back housing, but will it fit physically?
Thank you |
10-18-2016, 04:04 AM | #85 |
Rep 3,320
The F30 back is different and the f22 may not fit correctly since the f22s back stick out much further. If you have a f22 screen and want to trade back plates I have a f30 screen in my f22 and would like to trade the plates ! let me know
10-18-2016, 06:48 AM | #86 | |
Rep 565
If you have an 8.8" screen, noone will probably notice anything and just think you have professional nav . The only problem is if they update your car's software, which will revert any custom coding and the screen will be blank until coded again. |
10-18-2016, 06:54 AM | #87 |
Rep 565
You can buy a Multimedia Interface (MMI) which has composite and/or HDMI inputs and connect anything you wish. If you google it, you'll find many options.
10-18-2016, 02:25 PM | #88 |
Rep 418
