BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > SOLVED - Mystery Wires
      10-30-2024, 10:25 PM   #1
Haseeb1001
Drives: F30 BMW 328i
Talking SOLVED - Mystery Wires
Hello All,
Trying to find a part number for number 6 on the diagram. Cant find any pointers, trying to locate where the circled cable goes to. Car is a 2013 335i F30 RWD
Thank You
UPDATE-
After some thorough research. Came across this from an old DIY video. Ground wire was behind block, and wiring was called an Engine Trans Module Harness.
Wires2026.50
      10-31-2024, 07:06 AM   #2
Wires
Drives: 2016 340i xDrive
Cannot 100% confirm but that looks like a ground wire with a lug. Maybe bonds ground to the transmission?
      10-31-2024, 07:36 AM   #3
Haseeb1001
Yeah, trying to see where it gets grounded off a part number but weird that it’s greyed out
      10-31-2024, 08:27 AM   #4
B58 parts
B58 parts's Avatar
613
Drives: E53 X5 6mt, F30 340ix 6mt, E36
I've never seen the n55 in person but it looks like that is probably on the back of the engine block. Right on the corner of cylinder 6. Really easy to get to. The b58 has two grounds back there
      10-31-2024, 08:49 AM   #5
Haseeb1001
That’s what i’m thinking, but then the rest of the wires look like they’re in the exact place they should be on the diagram, for example 3 and 2 are sitting on/to the side of the valve cover
      10-31-2024, 09:07 AM   #6
Haseeb1001
12517602819 is a part number off a X5 35i looks like number 6. Called an Engine Trans Module wiring harness, now with this I need to locate that ground!
      10-31-2024, 03:18 PM   #7
LA1Z24
Drives: 2014 435i M Sport
That is the engine ground. It bolts to the rear of the cylinder head, towards the driver side with an M8 bolt. It is the ONLY ground for the engine and transmission. It is incorporated into the engine harness.
f30, n55
