BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > DIY 6.5 to 8.8 L7 display retrofit swap for 2014+ f2x f3x
      06-19-2019, 06:21 PM   #375
MarkoSK
Drives: BMW G20 330eX
Originally Posted by kelly66 View Post
Agreed. I think I read in one of the posts that we can also Bimmercode to correct the resolution via OBD2 dongle when moving from 6.5 to 8.8" so that it doesn't look stretched. Is it correct or should we only use the ENET cable and eSys?
Bimmertech is charging $99 to correct the resolution/stretch for their Vividscreen upgrade. So, can I do the same for the OEM swap to code "8.8_1280x480" and "breites_display"?
I guess if I buy and OBD2 WIFI/BT dongle and buy the Bimmercode App I can do it myself at a lower cost.
Yes, you can use BimmerCode to code the OEM screen (and also BimmerTech's VividScreen), the two values are common for both screens.
The only difference is that the OEM screen won't work unless you do the coding, whereas VividScreen will work, but will be stretched.
      06-20-2019, 08:32 AM   #376
kelly66
Drives: BMW 320d
I looked up some videos of Vividscreen and found the installation process a little complicated. Now I am having second thoughts on the upgrade since it also compromises on the warranty.
Sorry this is OT. I am contemplating something different...I have an old IPAD 2 running IOS 9.3.5 (and I hardly use it these days) and felt that I can make good use of it. Just thought I'll bounce the idea with you.
* Position the IPAD in of these 2 places (bottom is preferred since it does not cover the idrive. I'll use a car charger to charge it if reqd.
* Buy an OBD2 BT dongle Keep this dongle always connected at other times and buy an app like Dashcommand to get all the dashboard like stats on the IPAD, which I can glance at when I drive. (actually, I wanted something colourful and jazzy inside the car and that's why I was think of 8.8" upgrade but just the screen would not add colour unless I go for rear camera, navigation, etc.)
* If required, I can also buy one of these wifi rear cameras (not need to go through wiring trouble) and see it on my IPAD but I will have to open the camera app on my ipad each time I backup. Not the best way, but I can keep it on always if I want to see the road behind even while going forward.
https://www.aliexpress.com/item/APP-...AbTest=ae803_4
* Also buy the Bimmercode app and use the same dongle to do some coding on my F30 (just a bonus).
Of course, above can be done even by those of you who have the larger screen.
Not sure if anyone in the forum has tried this.
      08-31-2019, 07:35 PM   #377
NiNo_F30
Drives: 2014 BMW 328i Sport F30
What if....?
Hey,
What if I get the correct screen, but my F30 328i wasn't manufactured until 9/2013, but according to the VIN it's actually a 2014 model BMW? Can the screen still be replaced, coded and work without getting a whole new kit setup?
      09-02-2019, 08:08 AM   #378
MarkoSK
Originally Posted by NiNo_F30 View Post
Hey,
If your iDrive main menu looks like in the picture labeled as "NBT / NBT Evo ID 4", then you should be able to retrofit a larger screen:
https://www.bimmer-tech.net/blog/ite...cic-nbt-nbtevo
      10-09-2019, 07:06 PM   #379
caio123
Drives: 320i
Could you provide the part code of the previous (6,5") and the after screen (8.8") ?
My screen is 6,5" and the part code is 9292247 02 6, it will work with the 8.8" with the following part code: 9292248 02 9 ? (looks like both are made by alpine).
Thanks.
      10-31-2019, 02:59 AM   #380
Kris_s
Kris_s's Avatar
Drives: BMW F31 320d Xdrive
Hi guys,
regarding to all what has been written i have an issue with my screen.
I have EVO id4 from 11/16 B140 HW 2.3 and recently i bought 8.8 screen with part no 6 822 626 which is not working - NO SIGNAL problem.
I've tried to code my HU with apix2, mmi, and 24 without success.
Can anybody help my with this?
      11-01-2019, 03:44 PM   #381
MarkoSK
Thanks.
9292248 should work, given your car was made after 3Q/2014 and you have the HU_ENTRYNAV head unit. PM me your VIN and I can check it for you.
      11-01-2019, 03:48 PM   #382
MarkoSK
Originally Posted by Kris_s View Post
Hi guys,
Does your iDrive main menu have tiles or lines of text?
      11-04-2019, 12:18 AM   #383
Kris_s
Kris_s's Avatar
My Idrive is now text, because accidentally i flashed it to id5
      11-04-2019, 02:11 PM   #384
MarkoSK
ID5 is not text, but ID4 is, so I'm not getting what your head unit is and what software you flashed?
      11-04-2019, 02:32 PM   #385
Kris_s
Kris_s's Avatar
I bought used unit evo id4 ++, and when I was flashing it in my car with Psdzdata v.4.11.20, it became id5 software unintentional...
      11-08-2019, 02:42 PM   #386
MarkoSK
Can you flash it back to factory state (ID4)?
      11-11-2019, 09:29 AM   #387
Joeypdx
Drives: 2018 330
I bought the 65506822626 part (from a 2017 M4), coded as follows:
CID_DISPLAY_SIZE = 8.8
CID_DISPLAY_RES = 1280x480
DISPLAY_VARIANTE = breites_display
And works perfectly. I could setup split screen.
One thing is the backup camera image is still small - is there a way to code it to run full screen? I'm searching the forums for that but if there is anyone that has let me know.
Great looking upgrade over the standard low rent 6.5" screen.
      11-12-2019, 05:58 PM   #388
caio123
Drives: 320i
PM Sent, thanks a lot.
      11-13-2019, 03:33 AM   #389
Kris_s
Kris_s's Avatar
I was trying but without success. I even made a post about it:
https://f30.bimmerpost.com/forums/sh....php?t=1666255
      11-15-2019, 04:09 PM   #390
jcdub
jcdub's Avatar
Ireland
202
Drives: 330e M Sport
2017 NBT buisness
Ive a 2017 unit in my car with a 6.6 screen and I'd like to update it to a 8.8 screen. I was told a screen with a PN: 6822626 would work with coding. Any advice?
Thanks
[/B]2017 330e M Performance, MG Flasher Stage 2, RM Motors DP, xHP Stage 3, Armaspeed CIA
      11-16-2019, 03:49 PM   #391
MarkoSK
Thanks
Look here:
Does your iDrive main menu look as in the picture labeled 'NBT / NBT Evo ID 4' or 'NBT Evo ID6'?
      11-18-2019, 02:15 PM   #392
jcdub
jcdub's Avatar
Ireland
202
Look here:
Hi,
My car has the NBT / NBT Evo ID 4 display. I think I have NBT Buisness nav..
      11-18-2019, 04:48 PM   #393
MarkoSK
Hi,
Screen 6822626 is for the newer head unit (HU_ENTRYNAV2), it won't work in your car. You have HU_ENTRYNAV, which works with either of these two screens. Coding is required.
      11-18-2019, 06:59 PM   #394
jcdub
jcdub's Avatar
Ireland
202
Thanks for the reply. I'll have a look at the other screens. Is it worth going Android or stick with an original 8.8 screen?
      12-04-2019, 03:32 AM   #395
MarkoSK
It depends what you want - Android offers more features, however, according to reviews in these forums, some Android units lack quality, so choose wisely.
      12-16-2019, 04:26 PM   #396
foncsila
Drives: Bmw F31 318xDrive
I may have figured out the problem with the blue tint. I have an F34 without nav and I've tried both the pre-LCI and LCI screen:
Pre-LCI screen (part no. 9292248):
Attachment 1497353
LCI screen (part no. 9387453):
Attachment 1497354
As you can see:
- both screens work ,
- the pre-LCI screen has a blue tint whereas the LCI one doesn't
EDIT: As a side note - my F34 with a 6.5" screen had the DISPLAY_SIZE_RESOLUTION value set to "10.25_1280x480" by default... and the 6.5" screen worked okay . The 8.8" screen also works okay without having to change this setting, so all you really need to change is EXBOX > DISPLAY_VARIANTE -> "breites_display"
Just upgraded my screen. 6"5 to 8"8, worked without problems. At the beginning I thought something is wrong, because I became a black screen, but after coding it, everything worked perfectly. The only thing that I did in another way, was changing the display size resolution to 8"8_1280x480. It's also important that you buy the right screen, pre-Lci or the Lci one.
