04-03-2018, 02:01 PM | #463 |
Rep 40,635
05-07-2018, 09:50 PM | #465 |
Rep 40,635
PM sent.
05-11-2018, 03:10 PM | #467 |
Rep 40,635
PM sent.
06-09-2018, 08:04 AM | #468 |
Rep 16
Hi ,shauwn
First thanks for e-sys en ptzdata finally get it connected to the car dit not code yet i strugled with the home made cable all conections where correct and now connection posible finally i change the obd connector it was a old one and dit not connect wel on the cars obd poort wen i read and save fa and read and save svt do i have then all back up files wen someting gows wrong ? and how to back UP if sometings gows wrong Can you send me link voor İsta-D , Ediabas , tool 32 i |
06-09-2018, 09:36 AM | #469 | |
Rep 40,635
As for backups, they are worthless. If you wnat to reset ECU, simply VO Code it. PM sent.
autosyonal9.00 |
06-11-2018, 06:28 PM | #470 |
Rep 16
Shawn
you are 100% right, had I known before, I would have bought a ready cable but I could not wait 1 week delivery time so I thought I have everything in the house just a resistor of 510 ohm to buy soldering and ready. Not so no connection got checked all 10 times apparently my old obd plug was not good and gave bad contact to the obd gate of the car bad luck |
06-11-2018, 06:32 PM | #471 | |
Rep 40,635
06-24-2018, 03:49 AM | #472 |
Rep 4
Shawn can you please help?
I have tool32 and ENET cable. Fault is cc-Id 108 on a 2014 435i. Could you let me know what job to load and which options to clear this. Thank you. |
06-24-2018, 08:29 AM | #473 | |
Rep 40,635
Launch C:\EDIABAS\Bin\TOOL32.EXE Hit F3 Load C:\EDIABAS\Ecu\F01.PRG In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL Hit F5 "Results" window should show "JOB_STATUS = OKAY" Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
06-27-2018, 11:12 AM | #475 |
Rep 40,635
PM sent.
08-10-2018, 09:31 PM | #477 |
Rep 40,635
08-20-2018, 03:52 PM | #479 |
Rep 40,635
PM sent.
09-30-2018, 08:04 AM | #481 |
Rep 40,635
PM sent.
10-26-2018, 09:31 AM | #482 |
Rep 1
Hi,
I know that this topis was discuss few times, nether the less can we make a summary of retrofit pdc in f10 ? 1. im my e sys i have "." instead folder names - why ? 2. what functions i should acivated in esys to enable rear camera ? i have install emulator and camera. Can i ask for instruction step by step ? Last edited by duszmic; 10-26-2018 at 09:37 AM.. |
12-17-2018, 08:57 AM | #484 |
Rep 40,635
(...) means the PSdZData is Trimmed. Trimmed PSdZData means either E-Sys has Incorrect Target Connection, or you do not use E-Sys Launcher to open E-Sys, or you use E-Sys Launcher PREMIUM but select wrong car Series or this particular ECU CAFD is not mapped in E-Sys Launcher's CAFD Mapping Database, or you have insufficient Java Memory in order for E-Sys Launcher to map it.
