01-30-2020, 05:31 PM | #2356 |
Rep 45
So the only solution for the Audio Bug is to install the 3.6.3 over 3.8.0 ?
It sucks to get in the Volume Settings and touch the volume bar to get the real sound. Otherwise its silent |
01-30-2020, 08:37 PM | #2357 | |
Rep 11
Your questions got me thinking and spent a few hours reading posts. I now realize I purchased a unit from a LS vendor. Two last questions: Do I still have an option to control things with the iDrive with this unit? If not, is there a way to determine which vendor sells GS units? I'll buy another unit if I have to. |
01-31-2020, 12:09 AM | #2358 | |||
Rep 1,048
Software should work anyways. So your unit does not receive or decode CAN Messages at all, like you said its a issue in direction of MCU. You could also check the harness again if there is any issue, maybe a reseat will help. When you are firm wir electronics you can also measure if there is at least some power at the CAN cables (about 2.5 to 4 Volts) If you don`t know, then please someone do that who has the skill. Apart from that then your seller comes in charge to either replace your unit or (faulty?) send you a MCU file again. please note, when they ask for pictures send them only screenshots when their original software version was installed, otherwhise most of them stop support. Quote:
They even didn`t knew about 3.8.3 , their latest is 3.8.0 However, since the Corona virus issue, they will start working maybe on 10th february, so it probably will take some time until we see some a new version. Kri |
01-31-2020, 01:35 AM | #2359 |
Rep 11
Dear friends,
Finding where I could take +12v from this connector that you see in the first pic, I mess it up and now I have no power in that cable anymore, so the controls of the radio like the volume knob and radio station buttons and also AC panel does not respond. I checked the cable before, and I got 12v from the third one on the right, but now I got no power at all so the front panel won't turn up, any ideas? Anything I could do? All the fuses seem to be fine and the car has been resting for 12 hours or so. Thanks in advance!! Last edited by delarosa13; 01-31-2020 at 01:52 AM.. |
01-31-2020, 05:07 AM | #2360 | |
Rep 399
01-31-2020, 06:13 AM | #2362 | |
Rep 45
01-31-2020, 01:42 PM | #2363 |
Rep 17
Hi guys .. on my HU the idrive buttons doesnt work One day and in another day they work.. i have the rádio for BMW e90 with no screen(yes i cut the tablier xP)
Another question, the volume on BT call has bad volume, any solution to this? If i increase the volume this is ok but after the call the volume on the música explode my head LOL.. Can u please help me? |
02-01-2020, 01:41 AM | #2364 |
Rep 5
Hi
I have bought the last year an Android 9.0 Unit by Navifly. Everything was working, but since two weeks I have this Problem: when I start the car, the OEM side stays with the BMW Connect logo but it doesn't continue. After about three minutes it restarts and the same problem again. That's a "loop". If I change to the Android side, everything works fine, except the iDrive, wich only allows "lateral" movements. I just can only listen to the radio, because that is what I was listening to when the problem appeared. I have reset the unit by pressing the back button, but nothing changes. Can anyone help me? Thanks! |
02-01-2020, 04:18 AM | #2366 | |
Rep 67
You have problem with your headunit on OEM side.
Has nothing to do with the android screen. Quote:
02-01-2020, 04:41 AM | #2367 |
Rep 32
02-01-2020, 05:35 AM | #2368 |
Rep 5
02-01-2020, 05:39 AM | #2369 |
Rep 5
02-01-2020, 05:57 AM | #2370 |
Rep 399
02-01-2020, 06:44 AM | #2371 |
Rep 5
02-01-2020, 07:37 AM | #2372 |
Rep 79
I did factory reset, installed 3.6.3 over 3.8.0, then upgraded to 3.8.3, did another factory reset, no sound bug anymore. So I'm now at 3.8.3.
02-01-2020, 10:19 AM | #2373 |
Rep 120
#Aliexpress € 242,27 35%di SCONTO | Android 10.0 Auto Multimedia Player Radio Gps per Bmw F30 F31 F34 F32 F33 F36 M3 F80 M4 F82 Originale sistema di Nbt
https://a.aliexpress.com/_UaP3H The new Android 10! |
02-01-2020, 10:47 AM | #2374 | |
Rep 45
I asked my vendor he told me that i just write an email to the engineer of their company. I did it now with a video maybe they do an other update again |
02-01-2020, 11:09 AM | #2375 |
Rep 79
Yes,you must install all apps again but you can make a backup or something
02-01-2020, 11:15 AM | #2376 | |
Rep 1,048
Kri |
