03-26-2019, 12:38 AM | #1 |
Rep 3,675
Using 100 Octane on a circuit (B58)?
I have the B58 with the MPPSK flash/exhaust and I'm going to take my car on a circuit pretty soon. I was wondering if any of you guys can give me some advice as to whether 100 octane would compliment the compression ratio of the engine or if I'd be wasting my money or possibly damaging the engine. I don't really expect the latter but who knows.
Thanks |
03-26-2019, 01:59 AM | #2 |
Rep 2,499
You wouldn't damage your engine but you probably wouldn't gain any power assuming you're normally filling up with 93. The stock tune is fairly conservative to begin with (even with MPPSK). To see any actual gains, you'd need a tune that could take care of the more aggressive timing of higher octane gasoline.
NYG10692.00 |
03-26-2019, 09:35 AM | #3 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Could help if the engine heats up while running. Will put off knock better then 93 under high heat, high load.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
03-26-2019, 10:51 AM | #4 |
Rep 3,675
Hard for me to say, the last time I ran the car really hard my oil temps didn't jump at all. Only thing that happened was my rotors got warped. Any experience running it in your B58M?
03-26-2019, 12:10 PM | #5 |
Rep 260
You may even lose power. Octane is a property of the fuel to resist combustion. The fuel/air enters the cylinder, is compressed by the piston, and hopefully ignited by the spark plug.
If the octane rating is too low, the heat/pressure inside the cylinder can begin ignition too early. But if the octane rating is too high, what can happen is the opposite, and combustion may not complete. Now, you'll still get combustion and the car will run just fine. But incomplete combustion will reduce horsepower and mileage. Another issue, which I don't know much about, is that getting the higher octane rating is usually done with additives such as ethanol, and your engine may not like them; they could cause deposits or higher combustion temps. Not to boast in front of a bunch of fellow BMW owners, but my other car is a Prius. I know, you're jealous. Anyway, I used to track mileage meticulously, counting gallons pumped and miles traveled. Sure enough, when I tried higher octane gas, mileage decreased. So this really is a thing, but of course, YMMV, depending on your engine setup, ignition timing, and the actual octane of the fuel. |
03-26-2019, 12:28 PM | #7 |
Rep 469
I am using 100 octane all the time and never had any issues. The higher the octane the lower the risk for misfires. The engine tries to "read" the quality and adjust timing to the octane level. I believe it even says so in the manual.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
NYG10692.00 |
03-26-2019, 04:02 PM | #10 | |
3127
Rep 5,264
Its not oil or water you need to watch its the air inlet temperature. The B58 water cooled intercooler might be better but the air 2 air N54/55 would heat soak quickly. This generally required an aftermarket unit. I ran an ECS unit. If you have scanning tool it can be useful to track that temperature to see how you are doing ambient vs inlet. FWIW 100 is cheap insurance for a track day that will prevent an ignition pulls under load. I was getting mine at the pump in Cary NC for $7.10 a gallon at the time. Its an incorrect urban legend that high octane fuel will go unburned & cause issues. Its also an urban legend that it will harm you car. The only thing harmed is your wallet if you buy more octane then you need. For DD & an occasionally hard moonshine back road run NC's normal premium @ 93 octane is fine. If I ever take it to VIR it will go on a 100/93 mix.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 03-26-2019 at 04:10 PM.. |
NYG10692.00 |
03-26-2019, 06:57 PM | #12 |
Rep 3,675
I'm expecting it but they're not as horrible as I had initially expected. Can't wait for the ceramics on my M5C.
03-26-2019, 11:01 PM | #14 |
Rep 190,753
No issues from using higher octane but you wont make any noticeable power unless you change your tune
03-31-2019, 05:22 PM | #16 |
Rep 3,675
