10-22-2018, 06:36 PM | #133 | |
Rep 537
REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_R_output = nsl_r Thanks so much to the OP for the awesome post. Was able to get this mod done in about 15 minutes including the coding and restart.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
11-20-2018, 10:59 AM | #134 |
Rep 13
Thank you for the excellent instruction. I have 2014 328xi (f30 US) and after DIY and coding, still mine is not working. I do not see rear fog light icon on dashboard. Is my firmware too old ? I have still factory firmware.
11-21-2018, 05:19 PM | #135 |
Rep 18
Thanks so much for this post.
Just like another fan posted, I was able to remove the tabbed rear fog light switch plate without having to take the entire switch unit out. Just used a plastic putty knife to carefully ease out the switch plate from the bottom portion. It popped right out. Once I carefully carved down the "preventative tabs" as pictured in this post, I just pushed the switch cover back in and it that was it for the switch mechanics. For coding, I used the terrific Bimmercode app and followed N26Ghost's code update and bam! it works great! 1. rear fog indicator on the instrument panel - OK 2. rear fog lamps on with engine and full lights switched on - OK Confirmed for this 2019 F31 build so I hope it works for others as well. We'll probably never know why this was deactivated in the US market, but I'm sure that this option (when used properly with low-visibility driving situations) could save lives. Great post! |
11-24-2018, 09:48 PM | #136 |
Rep 204
Drives: 2016 428i GC Alpine White
Here's another write up on this, as with kassey22000 this author didn't remove the entire switch assembly (not mine but on my list to try next):
https://www.normalexception.net/BMW-...rear-foglight/
2016 428i GC
11-27-2018, 05:46 PM | #137 |
Rep 2,808
Drives: F33 430 and F39 M35i
Just did this on an ‘18 F33. Works. Thanks.
I just pried and wiggled the button out without taking the switch out. I did the switch thing in my ‘06 using Lego pieces and parts of a pen. The cutting the tabs off was easier. |
11-27-2018, 08:45 PM | #138 |
Rep 2,193
Probably due to some archaic NHTSA law, but do we need more people driving around with auxiliary lights on as a fashion statement vs. utility? In countries that are allowed to have & taught to use rear fog lights, the light is on the side of the driver = left rear for USA. You don't need both rear fogs on - it could confuse other drivers.
03-22-2019, 11:47 PM | #139 |
Rep 243
REM -> Mapping_Nebelschlussl_L_output: nsl_l
REM -> Mapping_Nebelschlussl_R_output: nsl_r FEM_BODY -> 3060 NSL_Verbaut: verbaut Values above worked and now I have rear fog lights, non-LCI F30. I think best method to remove the button is by using a thin plastic pry tool and gently push it out as opposed to taking out the whole assembly. |
03-23-2019, 12:02 AM | #140 |
Rep 243
What are you using to code? I've used ESys on my laptop and if you follow the OP's guide it should work.. did you modify and insert back the rear fog light button correctly?
10-22-2019, 03:07 PM | #141 |
Rep 21
Hi,
I’m having some issues coding rear fog lights on a 2013 f31 328i. The car has current/ factory I-level, f020-13-03-50? So was never updated. It’s a Canadian car, came without rear fog lights and had lci tail light units fitted without fog lights when purchased. It was recently imported into the Netherlands and since fog lights are required by MOT, pre-lci euro tail light units were fitted and suitable light switch. I could find the variables to code into the REM module, but not in the FEM module to say fog lights are ‘Verbaut’. I did however find the option under LCE_BEL_LIN_VAR to say the light switch also has the rear fog lights (BEL_FLC_NSW_NSL). The rear fog light switch does nothing. I used ISTA to activate the rear fog lights, and it works from the REM, but not from FEM. Both modules have the option to activate the rear fog lights, but only work from the REM. I’m assuming this should also work from FEM, and something is still missing in the FEM coding. I’ve used e-sys 3.27.1 with 4.19.21 lite psdzdata which is the latest I think. Can this be a problem with the old I level of the car? Thank you all for any help. Much appreciated ! |
11-01-2019, 08:00 AM | #142 |
Great Teacher
1076
Rep 1,303
Drives: 06 e91 325ix
According to the cheat sheet, only thing in fem body is NSL Verbaut. Just did it a couple weeks ago in my Sept ‘14 build date F31.
01-09-2020, 04:04 PM | #143 |
Rep 919
Drives: F30 328d Sport Line
Excellent writeup, OP!
I was able to get the physical button to work, however when I attempted to code via BimmerCode I could not find all of the options listed in the first post. For those of you who successfully coded this with BimmerCode, which parameters did you change, exactly? |
01-09-2020, 04:06 PM | #144 |
Great Teacher
1076
Rep 1,303
It’s in two different modules, only the first is in fembody, check the cheat sheet for 2-6? Which are in a different module. R.E.M. I think.
If you don’t want to deal with eSYS, try BMWAi program. It’s eSYS without a launcher/token. I use it for most things that don’t require adding custom values. |
haagm58809.50 |
01-09-2020, 06:54 PM | #145 | |
Rep 919
01-10-2020, 12:35 PM | #148 |
Rep 919
On the second attempt, I was able to get it to work! What threw me off is the second to last code step in the original post; the instructed option is not available in BimmerCode (see below), however choosing the first option (nsl_r) enabled the right rear fog.
Onizukachan1076.00 |
02-21-2020, 08:05 PM | #150 | |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
The part of the tail light that lights up brighter is what BMW calls the "brake force display" and lights up brighter when the car uses its built-in accelerometer to sense a hard braking force. When the headlight switch is modified, and the car is coded properly, these inner tail lights serve a dual purpose as both the brake force display when braking and as a rear fog light when you press rear fog light switch. You really need to read this entire thread.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
02-21-2020, 10:37 PM | #151 |
Luxury at the redline :)
9103
Rep 7,563
02-22-2020, 08:19 PM | #152 | ||
Rep 32
dont worry about my reasons, i just asked if anyone knew which values were the reverse lights. im not trying to see better. i live in cali and the rear fog lights are useless even for people behind me. but a nice surprise for tailgaters? now thats worth it. so thanks for your wonderful insight and valuable opinion. Quote:
thank you that worked. watch out tailgaters and people at red lights that think i left my car in reverse lol |
Poochie9103.00 |
09-15-2020, 06:19 PM | #153 |
Rep 90
Drives: 2013 BMW 328i
Has anyone found just the rear fog light button for sale online? I'm interested in doing this mod, but I would rather just buy the button instead of spending so much money on the whole control system.
09-15-2020, 07:58 PM | #154 |
Rep 919
Negative. I have only seen the entire controller. I once saw a sticker for sale, if I find the link I'll send it to you. I went the super DIY route and wrote the signal on it with a paint pen...it's not perfect but it reminds me of the DIY experience when I see it.
