BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Eibach Pro-kit and 435i with Adaptive - how's it look? how's it ride?
proTUNING Freaks
      06-08-2019, 07:46 PM   #23
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
I'll see what I can do today. The sun is still high in the sky so the shadows will be a little whacky. Plus it's like 90+ outside so...
Originally Posted by CRAMAZIN View Post
Hey OP, has the springs settle more? Can you give us an updated pic?
Thanks,
      06-08-2019, 09:08 PM   #24
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Front end is 5-1/8 inches off the ground (front fender well lowest level)
Read end is 6-5/8 inches off the ground (rear fender well lowest level)
Front finger is 5/8 inches
Rear 2 fingers is 1-1/2 inches
      06-08-2019, 10:27 PM   #25
G80S58
Drives: G80 Xdrive, X3 M40i LCI
awesome dude thanks!
The front looks amazing, I wish the rear was just a little lower.
      06-08-2019, 10:56 PM   #26
FaRKle!
What are the hub to fender measurements? That's one of the most consistent measurements to use when comparing ride heights.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      06-09-2019, 11:43 AM   #27
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Agreed. I do and I don't. *Maybe* Eibach was thinking about luggage, people, fuel in the back. I notice cars with the comparable HR springs have a similar, slightly higher back end.
Event stock the 435i sits a little higher in back... odd or engineering or both.
      06-09-2019, 11:44 AM   #28
exE36M3
BMW CCA Member
exE36M3's Avatar
488
I can grab my ruler for that later today.
      06-10-2019, 06:45 PM   #29
G80S58
forgot to ask, do you have spacers on?
      06-10-2019, 09:41 PM   #30
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Yes. I am running Amazon "Eurotech Werkshop" spacers ($86 for a set of 4, and came with extended bolts.). 12mm front and 15mm rear.
And the hub (middle of BMW logo cross-hairs) to fender distance...
FRONT: 13-1/8"
REAR: 14"
FaRKle!4006.50
      06-10-2019, 10:31 PM   #31
G80S58
FRONT: 13-1/8"
REAR: 14"
thanks, are the wheels flush with the fenders with those spacer specs?
      06-10-2019, 10:53 PM   #32
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Yes the 12mm and 15mm are pretty darn close to flush with the fender well when viewed from the side and top.
      06-11-2019, 09:12 AM   #33
G80S58
awesome thank you again! and what size are the wheels/tires?
      06-11-2019, 02:30 PM   #34
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Stock 18s... so 225/45-18 front and 255/50-18 rear.
      10-13-2019, 12:35 AM   #35
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
My 435i xDrive with the Eibach pro-kit, 15mm spacers in the front and 20mm in the back. Stock 18" 441M wheels which I believe are ET34.
      10-13-2019, 11:37 PM   #36
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Thanks @psyki! Looking good!
      02-12-2020, 09:35 AM   #37
thatBimmerBloke
thatBimmerBloke's Avatar
Drives: None
That looks really good, is it the pro kit with B8 shocks and Eibach springs, part number E10-20-031-18-22? Definitely looks lower than the claimed 20mm/10mm front/rear lowering.
      02-12-2020, 11:15 AM   #38
psyki
E36fiend
2014 X5  [0.00]
Thanks! No it's the stock adaptive struts, hence this thread. Here's what it looks like now with 20" 437 reps:
      02-12-2020, 11:21 AM   #39
thatBimmerBloke
Drives: None
Thanks, my bad. I'm curious how the springs pair with B8 shocks/struts. Apparently the drop is lesser. Can't find anyone who has the complete kit (B8 shocks + Eibach springs) installed on F32.
