BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > is it OK to trickle charge battery straight from rear vs from front?
      07-24-2021, 04:45 AM   #1
gameson
Drives: 2015 BMW 320i N20
i read through google and youtube that BMW recommends trickle charge your car battery from the engine bay (front)
I live in an apartment where if i do it from the front, i may risk getting the charger stolen.
if i do it in the rear, i can place the charger in the trunk and just run wire from trunk to outside, so it protects the charger.
but is it OK to trickle charge battery from the trunk?
Thanks.
      07-24-2021, 07:54 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The battery doesn't care. The main advantage to using the charging posts is access, which is considerably easier than direct to the battery. BMW does state that either the battery post or charging post is OK.
      07-24-2021, 08:32 AM   #3
atzebmw
Drives: Tesla Model 3
Better not...
      07-24-2021, 10:17 AM   #4
Billfitz
Billfitz's Avatar
Who are you going to believe? BMW, or BMW? There being three different battery types is why chargers can selects between Lead Acid, AGM and Lithium Ion.
      07-24-2021, 10:39 AM   #5
tjlees
England
349
Drives: F30 Chav Mobile
I have the same problem.
I charge from the charging post but put the charger and extension lead in the car with leads coming out of back of the bonnet near wipers and back into car.
alternatively optimate solar (duo if lithium) with solar panel on the dash and similar arrangement for leads out of bonnet. brilliant if you have no power socket. the 20w panel is fine for trickle or 40w if you want to recharge from near flat.
you can charge from the rear lighter socket in boot, but sometimes it shuts off the socket so not reliable enough for me.
BTW charge directly charging battery confuses the battery management system as prev said, so not recommended.
      07-26-2021, 08:02 PM   #6
xxxjecxxx2
xxxjecxxx2's Avatar
Drives: F30 335i M Sport
2013 F30 335i  [0.00]
2015 F15 X5  [0.00]
2017 G30 540i  [0.00]
Secure trunk against closing with towel.
Disconnect both battery terminals in trunk.
Hook up trickle charger direction to battery.
      04-10-2023, 02:25 AM   #7
Amina2511
My baby Austin yellow M3 F80
Amina2511's Avatar
Drives: Bmw x5m package,bmw m3 F80
A few people told me to do that also .disconnect terminals and charge battery directly .not the using the hood method ..
      04-10-2023, 07:28 AM   #8
Billfitz
Billfitz's Avatar
How many of those people are electrical engineers?
      04-10-2023, 03:01 PM   #9
NealfromNZ
NealfromNZ's Avatar
New Zealand
522
Drives: 2016 F80 M3
If using the rear make sure that the battery external vent is still in place and hasn’t been removed by a previous owner or servicing company when running an acid battery.
Otherwise you have a the potential of an battery gas explosion with some battery chargers that spark when connected.
Usual procedure should also be used to connect charging terminals first before turning on charger
Here’s a guideline, although much of this doesn’t apply as your not taking the battery out to bench charge.
https://www.safework.sa.gov.au/workp...acid-batteries
      04-10-2023, 09:55 PM   #10
Billfitz
Billfitz's Avatar
We don't have lead acid batteries. Ours are AGM, which allows them to be inside the car rather than under the hood.
      04-11-2023, 02:33 PM   #11
NealfromNZ
NealfromNZ's Avatar
New Zealand
522
Drives: 2016 F80 M3
Have a look at the function of the venting valve on AGM batteries. Still a risk and they have gone up.
