BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > AC Schnitzer sports damper offer - FREE FITTING
Vorsteiner
      11-29-2018, 05:17 AM   #45
nastynick83
Drives: 330xd M-sport
For anyone on the fence about this - go and test drive the car! I was genuinely impressed by the difference the dampers made.
My 330xd is booked in on Tues 11th Dec to have them fitted
Lorcan1482.00
      11-30-2018, 05:17 PM   #46
devil84
Drives: F36 430D X Drive
Another review here guys
https://f30.bimmerpost.com/forums/sh....php?t=1461853
I missed the chance of test drive at Deutsch Tech to work.
Will i regret losing the adaptive suspension ?
      12-03-2018, 04:26 AM   #47
flashollie
Drives: F31 2017 335d black
I worry about losing the adaptive but figure having one good setting is better than a poor comfort and sports setting.
I've just thought, will this affect the heavier steering you get with the sports mode? I do like that its not great but better than the regular light steering.
      12-03-2018, 04:52 AM   #48
Lorcan
Lorcan's Avatar
Drives: AC Schnitzer
Everything else connected to the mode button still works as usual: steering weight, throttle response, gear change points etc.
You won't miss the adaptive. The car works better without it.
Lorcan Parnell
AC Schnitzer UK, 01485 542000
www.ac-schnitzer.co.uk lorcan@ac-schnitzer.co.uk
      12-03-2018, 07:22 AM   #49
Watsey
Drives: F31 330D sDrive M Sport
I already have Ohlins on my car but I can 'back' Lorcan in terms of moving to a good passive suspension setup rather than BMW adaptive which doesn't do anything particularly well. I don't miss adaptive suspension at all - passive dampers are far more predictable.
Driving modes now work as follows :
Stick left : sports gearbox mode.
DTC : manual control in any gearbox mode
One press on the driving mode button : Sport (which is set on my car to only change the chassis, so just weightier steering)
Two presses : Sports+ : weightier steering plus DTC on
Paddles or gearshift : manual override at any point : temporary in Comfort and permanent in Sports+ or with stick left
This gives a wide range of options to pick from depending on the roads and conditions.
Current : F31 330sD, DMS remap, Ohlins Road & Track, Millway Motorsports top mounts, SuperPro poly bushes, Quaife LSD, Stoptech BBK with Pagid RS4-2 pads, Birds ARBs.
      12-03-2018, 07:25 AM   #50
devil84
Lorcan
Is it a cost or technical issue that you don't do a adaptive option like Blistein
Or is it because you genuinely believe passive option is better.
As above debating whether I should lost an option that I paid for
      12-03-2018, 08:17 AM   #51
Lorcan
Lorcan's Avatar
Originally Posted by devil84 View Post
Lorcan
AC Schnitzer evaluated an adaptive setup in their testing but concluded that the passive setup worked better overall. BMW even concluded the same recently while developing the M2 Competition, which has passive dampers. When you change the damping rates adaptively without changing the spring you ultimately end up with two compromised settings instead of one good one.
Lorcan Parnell
McBeemer179.00
      12-04-2018, 05:52 AM   #52
Lorcan
Lorcan's Avatar
@devil84 your inbox is full
Lorcan Parnell
      12-04-2018, 05:56 AM   #53
Lorcan
Lorcan's Avatar
Our demo car is now at Stourbridge Automotive in errr...Stourbridge for the rest of the week and is available for test drives.
Speak to the lovely Neil or Kay there to book your appointment.
https://www.stourbridgeautomotive.co.uk/
Next week it's at Revolution Performance in Gateshead - wy aye, nay bother etc.
Lorcan Parnell
      12-04-2018, 06:20 AM   #54
Lorcan
Lorcan's Avatar
Lorcan Parnell
      12-05-2018, 06:44 AM   #55
flashollie
I'm currently sat at Stourbridge Automotive having the dampers fitted to my 335d that has / had adaptive.
I have just been out in the ACS demo car with the springs and dampers.
In short it's a bloody revelation!
it is loads more comfortable. This car is on continental sport contact 6 tyres and mine is still on run flats but the difference is remarkable.
there is greater feeling through the steering pot holes are dealt with without feeling your teeth bashing together.
when you accelerate the car stays flat and brake dive is much reduced.
through the bends the car is more poised and stable and you can feel what the front and back are doing so much more.
this is still not a rwd car but you can feel a hint of oversteer much more than in the standard set up. the body roll is much reduced and you have no sudden unexpected lurches as the suspension catches up with its self.
its much much more confidence inspiring.
this car feels much more like a lighter weight version of my old E61 530d but with more grip up front so you can add power a little earlier and feel the back just starting to push but nothing as severe as the E61.
so all in all its more comfortable more informative more confident predictable and more fun to drive.
the comfort is remarkable way better than the standard but remember this is on non fun flat tyres
if you have £1500 to spare do this you won't regret it.
Lorcan1482.00
spansar16.00
      12-05-2018, 07:40 AM   #56
devil84
Bloody hell mate. Compelling review.
      12-05-2018, 08:44 AM   #57
nastynick83
I couldn't get over just how much more comfortable it was. I noticed it immediately just driving at 15mph.
I think the expectation is that changing the dampers would stiffen things up and make it less comfortable. But they work to take the impact of the bumps away.
Can't wait to have mine fitted on Tuesday
      12-05-2018, 10:54 AM   #58
flashollie
having driven mine now after quick efficient fitting at the excellent Stourbridge automotive I can tell I'm on run flats but the improvement is still very significant.
the comfort is better not as good as on the contis but all other points I made still apply.
I'd add the springs don't make a quarter of the impact that the dampers do. but then they are a 5th of the price......taxi !
      12-05-2018, 12:01 PM   #59
flashollie
and to just add the tuning box fitted is good too. it doesn't feel hugely more powerful but you can tell it's there.
what is very noticeable is the smoother power delivery and power is always there no delay. if you want mega bhp look elsewhere but for a more refined power delivery it works.
Just don't think I can justify nearly 3k though.
      12-05-2018, 02:31 PM   #60
devil84
What tuning box did you go for?
ACS?
      12-05-2018, 02:43 PM   #61
flashollie
sorry I wasn't clear. I meant the ACS tuning box fitted the ACS demo car not mine. mine is still standard 335d engine.
my car is a year old so the warranty appeals of the ACS but 3k is a lot.
      12-09-2018, 06:47 AM   #62
McBeemer
McBeemer's Avatar
Scotland
179
Drives: 335d Xd MSport Touring
Anyone else had the dampers fitted I am hoping to go to Revolution next week for a test drive . I have the springs only just now
Current: 2017 F31 335d M Sport - Estoril Blue, Adaptive Suspension, ACS Springs, Black Grill, HK Sound & some other bits'n'pieces
Gone: 2015 F31 320d M Sport Xdrive Auto
      12-09-2018, 06:48 AM   #63
devil84
Let us know what you think. I am in same boat as you.
X drive on adaptive with ACS springs.
McBeemer179.00
      12-10-2018, 04:02 AM   #64
Lorcan
Lorcan's Avatar
The car will be at Revolution from lunchtime today
Lorcan Parnell
McBeemer179.00
      12-10-2018, 04:26 AM   #65
Tengocity
Tengocity's Avatar
Scotland
4593
Drives: M4 CP/330e/Boxster S
I can't believe folk are still on the fence about this.... no one has done this, or even tried the demo car and felt it's anything but a revelation!
Current: 2018 M4 CP daily driver, 2016 F30 330e company motor, Porsche Boxster S (987) weekend toy
Gone...F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
      12-10-2018, 06:51 AM   #66
McBeemer
McBeemer's Avatar
Scotland
179
I'm not on the fence, as I am absolutely going to change dampers.
Just wanted extra reassurance of which route to go, although I am 99% certain to be going ACS
