BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Is there a way to reduce the sensitivity of stop-start?
      12-06-2018, 11:31 AM   #1
thescouselander
Drives: 4 Series Gran Coupe
I've noticed on my car that stop-start cuts the engine before I've come to a complete stop - this is very annoying. Is there a way to code the stop-start so it will only cut the engine at a complete stop?
      12-06-2018, 12:28 PM   #2
Cero ceto
Drives: 335d M Sport+
Not too sure about that. I just coded mine out and it was the first job I did when I collected my car as they are not good for the engine or starter motor etc.
F30Andy905.50
      12-06-2018, 12:34 PM   #3
Sasquartch
Drives: 328i Luxury auto
Doesn't sound right, on my 328i you have to come to a complete stop and then after perhaps half a second it then stops
But most people code it out anyway, I hardly ever use it
      12-06-2018, 01:24 PM   #4
thescouselander
Yes, that's what I'd expect but on my car the engine cuts out at 1-2 mph. It's not the only odd thing it does and I reckon it's probably something to do with BMW being more agressive with emissions reduction due the new WLTP tests. I might just code it out as you suggest.
      12-06-2018, 01:56 PM   #5
Mrklaw
Drives: F30 LCI 320i msport
Yeah I assume itís down to fuel efficiency. My wifeís polo says it deliberately cuts the engine just before it stops. No idea why they donít let you permanently turn it off without coding. They still technically get the better figures
      12-06-2018, 01:57 PM   #6
PaulT_M5
England
246
Drives: San Marino Blue F90
It's the coasting feature - it even does it on the new M5!
You can press the button underneath the Start/Stop button every journey, or code it out.
F90 San Marino Blue/Black
      12-07-2018, 12:51 AM   #7
thescouselander
I'm not sure there's any coasting going on. When the engine cuts the car stops dead.
      12-07-2018, 01:56 AM   #8
SkyJawa
SkyJawa's Avatar
England
2236
Drives: 335d
Mine doesn’t cut out till complete standstill, unlike wife’s Octavia with cuts out before stopping and is pretty irritating!
      12-07-2018, 02:28 AM   #9
Skwirrel
Drives: 330d
This happens on my car too, especially if you progressively use less pressure on the brake pedal in the last few metres to get a totally smooth stop.
Just code it out, there is no discernable difference to fuel consumption.
I had it on a manual car previously and it was much more effective controlling the stop or start using the clutch, so you can start the engine before you need to move off or keep it running at a junction or roundabout.
      12-07-2018, 02:39 AM   #10
xenon
xenon's Avatar
England
588
Drives: 2018 A6 Avant S-Line
My A6 cuts out just before stopping too but the whole thing is annoying so, like most, I've coded it off.
Ian
Current: 2018 A6 Avant S-Line MMI+
Previous: 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      12-07-2018, 03:28 AM   #11
TodmordenLad
TodmordenLad's Avatar
Drives: 440i GC LCI with MPPSK
I dont know but I find BMWs stop start awful - obtrusive and clunky. I turn it off as soon as I've started the engine
By contrast, stop start on my wife's new Fiesta is smooth and almost imperceptible. Ford does a lot of things better than BMW tbh, just doesn't have the brand image or make particularly pretty cars
Current: 440i GC LCI with MPPSK. Previously owned: F31 330D M Sport+ with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus a host of MB's, Audis & Volvos too numerous to mention
Kyngofpop660.00
      12-07-2018, 08:17 AM   #12
Wills2
Barge driver
Wills2's Avatar
Drives: G11 740d xdrive
You can just press the brake pedal firmly and it will start up again or apply pressure to the steering wheel and it'll start as well, flicking the gear lever into manual mode also works on my car.
G11 740d xdrive/Z4C, Gone F80 M3/F10 M5/F31 335d/e92 M3 x 2/F10 520d x 2/997 C2S/e46 M3/e46 320d/SL320/Touareg 3.2V6/Audi allroad 2.7TDi
      12-07-2018, 09:06 AM   #13
Oceanic
Drives: Audi S5
Put it into sport mode will also re-start it or prevent it cutting in, code the bastard thing off though.
      12-07-2018, 11:43 AM   #14
Wills2
Barge driver
Wills2's Avatar
Personally I wouldn't code it off, as in heavy traffic I think it's good not to sit there chugging fumes out whilst stationery but there are times that it's annoying.
Kyngofpop660.00
      12-07-2018, 12:41 PM   #15
Hooded
Hooded's Avatar
England
953
Drives: F30 330d M-Sport
Nothing wrong with coding it to default off if you find it annoying, you can still hit the button and turn it on occasionally if you're stuck it gridlock traffic.
      12-07-2018, 05:21 PM   #16
ukbeemerboy
Beemer Heaven
ukbeemerboy's Avatar
Drives: BMW 330d M Sport
Is your car a manual or auto?
Scott
2017 BMW 330d M Sport : 2015 BMW 220d M Sport
2008 Mini Cooper
      12-07-2018, 05:56 PM   #17
APJ
APJ's Avatar
Drives: F36 435d M Sport Plus
You can code it to remember its last position, which it even remembers when you start from cold, gives you more flexibility that way, unless you really hate it and code it out completely like others have suggested.
      12-07-2018, 08:17 PM   #18
adam.b
Drives: F31-335d G01-X3 30d
It is still possible? on F46 service needed to go back to old software to get working and on f30 16plate and f31 18 plate after unplugging comp goes back to default and is ON. They can't overwrite it.
      12-08-2018, 04:09 AM   #19
un1eash
Drives: 320d M Sport
Coded mine to remember last setting. It's useful at time but not when your pulling up to a T junction or crawling in traffic as it cuts in too much.
Mine also only stops when the car has completely come to a stop.
      12-08-2018, 05:17 AM   #20
Wills2
Barge driver
Wills2's Avatar
For you maybe, probably not for the people breathing the emissions of remapped diesel in, I'd rather just press a button if it's not appropriate for the conditions, but with diesel especially one that's been messed with I think it's wrong full stop with stuff they chuck out.
      12-08-2018, 05:31 AM   #21
Rhino at Work
Rhino at Work's Avatar
348
Drives: EB F30 340i Shadow Edition
+1. Mine is coded off via Bimmercode but if I find myself stuck in traffic I just flick the switch into Eco Pro.
Current: EB F30 340i Shadow Edition with even more toys
Previous: EB F30 330d xdrive with lots of toys
      12-08-2018, 06:50 AM   #22
Hooded
Hooded's Avatar
England
953
You don't exactly drive the most eco friendly cars yourself.. if you are that concerned about the environment perhaps you should get off the soap box and buy a more eco friendly zero emissions car
My own car still has the DPF and EGR intact, is legal and passes the emissions test easily with no visible smoke.
The stop start system Is annoying and I don't think it's particularly great for the cars components long term, but as already said if you code it to default off you can still turn it on easily anytime you are stuck in gridlock traffic to stop those nasty emissions, it's not like the feature is being completely disabled so you can't use it, ..and don't forget whenever you put a car in sport mode it's turned off just the same.. are you against driving in sport mode too?
