BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Used steering rack.
      12-07-2018, 01:46 AM   #1
adpack82
Scotland
Drives: F30 330D M sport
Used steering rack.
My steering rack needs replacing. I can probabaly buy several used racks for the price of a new one from BMW.
My question is; while it's a straight forward mechanical fit, how difficult is it to code the new (used) rack to the car? That's assuming it is possible.
Also, while I'm at it, can I change to vss?
2014 330d.
Thanks
      12-07-2018, 03:12 AM   #2
Watsey
Drives: F31 330D sDrive M Sport
AFAIK this is a dealer-fit process (or at least someone who is BMW technician qualified), with a substantial software download from BMW Germany to code the new rack into the car.
I very much doubt that BMW would even consider upgrading the rack to VSS.
But every day is a school day and I'm happy to be proven wrong.
Current : F31 330sD, DMS remap, Ohlins Road & Track, Millway Motorsports top mounts, SuperPro poly bushes, Quaife LSD, Stoptech BBK with Pagid RS4-2 pads, Birds ARBs.
      12-07-2018, 03:48 AM   #3
adpack82
Scotland
Would that include fitting a rack of the same spec as I have now, or just for vss retrofit?
I know that it'll need coding to the car, but I have esys and ista-p.
      12-07-2018, 04:11 AM   #4
Watsey
My car has had two replacement steering racks (no VSS) and both had to be coded into the car. Talking with the service manager it did seem to be a time-consuming process. Multiple ECUs have to be coded, including the rack and the AT.
      12-07-2018, 04:45 AM   #5
NISFAN
NISFAN's Avatar
Drives: The best kind of F30 :)
I guess it depends on what items you want to replace.
The rack itself has a whopping great motor on it, then there is a load cell and steering angle sensor on the input shaft (from steering wheel). Other than that it is a mechanical device. Perhaps you can separate the part you need to replace ( the mechanical rack itself ?!?!?) without needing to code? As for coding, if replacing like for like (be careful here as there are many rack part numbers) I'm sure it is less coding and more calibration it requires.
I'd be tempted to give it a go myself
......provided the 'new' rack is sound.
      12-07-2018, 05:32 AM   #6
Daftasabrush
Fool
Daftasabrush's Avatar
England
1695
Drives: F31 340i
You could also look into getting your existing rack re-manufactured which may be cheaper and likely to also provide a warranty of some sort.
      12-07-2018, 06:14 AM   #7
sspade
sspade's Avatar
Drives: F30
2014 BMW 328i  [5.00]
Keep us posted on your decision...
If you buy a VSS rack, dont see why the dealer/indy wouldnt fit and code it the exact same as a non VSS rack...
Thats my plan as well if my rack fails.
BMW 328i FBO, Bootmod3 Stage 1 [see garage for build]
      12-07-2018, 06:42 AM   #8
Hooded
Hooded's Avatar
England
955
Drives: F30 330d M-Sport
What's the fault on your current rack?
      12-07-2018, 06:52 AM   #9
adpack82
Scotland
I did think about trying to replace the mechanical parts only; It's worth a go at least.
I had a look on real oem, so I know which rack I need. Of should that be racks, as my exact part number has been superseded about 10 times! 😁
      12-07-2018, 06:53 AM   #10
adpack82
Scotland
I spoke to someone who had it done. He payed 600. Used racks are around 300 on ebay.
      12-07-2018, 06:56 AM   #11
adpack82
Scotland
Knocking, which was lessened but not fixed with the thrust piece repair kit. Also vague, notchy steering that needs constant correction. Loads of dead spots etc.
Before anyone suggests it - I've had 3, four wheel alignments done. 2 by dealer, one by indi, tried 2 sets of wheels, one set with run flats, the other with Ps4's
      12-07-2018, 07:07 AM   #12
Watsey
The knocking is due to a tolerance fault, but you know that as you've tried the thrust repair approach.
The characteristics of the racks in the current model range are basically quite shit. Electrical assistance rather than hydraulic ruins the responsiveness and kills the feel, bump steer is automatically 'corrected' but very badly (you end up fighting the steering), and the racks are quite slow in the non-M versions.
The second-worse decision by BMW, IMO, behind the standard fitment of RFTs. I understand the theoretical efficiency gains but the execution is poor.
      12-07-2018, 07:36 AM   #13
adpack82
Scotland
Yes, very poor. Sadly, I don't have the luxury of getting used to it either, as I drive several different cars a day. I jump back in my car at the end of the day and it feels great... Until I drive 100yds.
      12-07-2018, 10:42 AM   #14
Hooded
Hooded's Avatar
England
955
I would probably go with that over one off eBay. A second hand rack off eBay might not be a lot better than the one currently on the car.
      12-07-2018, 11:38 AM   #15
sspade
sspade's Avatar
Drives: F30
I understand and agree but if getting remanufactured... why would it matter?
Also... buying a used one off eBay and sending it out for repair allows you to still drive your car until you have a brand new rack ready to go in... thats a huge plus and leaves the car down for only a day max versus weeks potentially...
      12-07-2018, 11:52 AM   #16
Crazy_1201
Drives: E90 320d
It is doable:
https://f30.bimmerpost.com/forums/sh...5#post21853485
Coding:
Expert Mode-Coding Read FA Activate FA Read SVT Select EPS ECU Detect CAFD for SWE Choose CAFD Click Code
sspade1418.50
      12-07-2018, 12:37 PM   #17
Hooded
Hooded's Avatar
England
955
300 + 600 if buying of eBay instead of just 600 for remanufacture?
I guess I'm thinking as someone who owns more than 1 car though!
      12-07-2018, 12:51 PM   #18
sspade
sspade's Avatar
Drives: F30
£300 + £600 if buying of eBay instead of just £600 for remanufacture?
Fair enough. We are just talking out options... all good!
      12-07-2018, 04:09 PM   #19
adpack82
Scotland
Originally Posted by Crazy_1201 View Post
It is doable:
Coding:
Thanks. That's the kind of think I'm looking for. 👍
      12-07-2018, 04:15 PM   #20
adpack82
Scotland
We have two cars; however, they both get used daily by my wife and I.
I understand its a gamble buying a used rack. Worst case scenario is buying a rack and then having to get it refurbed. Thay is still a hell of a lot cheaper than buying a new one! Plus, I out the "new" rack on my car and try it out if it's not quite right then it's my original rack that's away getting re-manufactured, while I still have a car to use.
