BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Where to turn display off?? Can't find it anymore.
      07-01-2019, 12:31 PM   #1
natesi
Drives: F30
I use to have an option to turn my display off, which I had configured as one of my "hotkeys". However, BimmerCode wiped all my configured "shortcuts" -- and now I cannot find this setting in the menu, either. I wonder, if when BimmerCode coded, it removed the option from the menu, altogether? Or maybe I just can't find it.
Can someone confirm where this setting is? I'm guessing it was under "control display".
I know some newer versions of i-drive have options available that older versions don't. So, if it matters my car is a 2016.
Thanks all.
      07-01-2019, 12:42 PM   #2
SteveinArizona
Drives: BMW 530e
if you mean the display in the middle of the control panel, use the button on the turn signal stalk.
      07-01-2019, 12:45 PM   #3
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
If your taking about the nav iDrive screen. I think if you keep moving right ....there be an option for split screen and at the bottom there is one for screen off... I think
tex26702408.00
natesi204.00
      07-01-2019, 12:47 PM   #4
Dev_inlife
Dev_inlife's Avatar
Drives: 2013 BMW 528i xDrive
If I'm not mistake the option should be from the "Option" button from your iDrive controller. Just select that scroll down to the bottom and "Turn Off Display" should be there.
CHALLENGE is the pathway to Progress and Engagement in our lives...
natesi204.00
      07-01-2019, 01:10 PM   #5
natesi
Drives: F30
Awesome; thanks guys -- that was it!
      07-01-2019, 01:43 PM   #6
bimmer456
Drives: 340i
Yup was going to use that suggestion press option and the turn off display.
natesi204.00
      07-01-2019, 01:58 PM   #7
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
You can used one of the "Programable Memory Button" 1 - 8 to save a shortcut to the sceen-off menu.
I did, it works flawless..
natesi204.00
xthirdx48.00
      07-02-2019, 10:20 PM   #8
SilkySmoooth
Drives: '13 335i MSPORT Estoril Blue
You are a genius. Thank you. I would love to turn this off at night quickly
Poochie9103.00
