07-13-2019, 03:46 PM | #1 |
Rep 320
Slight vibration under full throttle acceleration
Hello, I have xdrive and under full throttle acceleration I think the rear is slightly vibrating. My steering wheel doesn't vibrate. No matter what speed I drive it only does it during acceleration. What can this be?
Cvjoint ou diff? |
07-23-2019, 04:51 PM | #2 |
Rep 833
Drives: BMW F36, E36, E93
Output shaft? Wheel bearing? Diff? Wheel bolts? Tire? Axle mountings? Drive shaft joint? Drive shaft bearing, take your pick
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
07-27-2019, 08:24 PM | #3 |
Rep 552
If it's under acceleration then it could be the guibo (flex disc) between the propshaft and diff or the centre bearing on the propshaft.
