BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F3X Suspension sub-components DIY Series
      12-20-2019, 11:07 AM   #45
FaRKle!
Drives: '17 328d Sport Wagon
Originally Posted by pkiledj View Post
@FaRKle!
I found these monoballs for the xdrive with a quick google search. Know anything about them?
https://www.splparts.com/products/fr...3x-xdrive.html
https://www.splparts.com/products/ad...3x-xdrive.html
I don't have any first hand experience with those, but in general SPL makes nice stuff. I know a lot of their stuff has been recommended for track use only (not sealed well enough for the dust/dirt/grime of daily driving) so you may want to check for that. I wouldn't run un-sealed monoballs on a daily driver.
Their caster adjustable tension strut bushing uses the same method of adjustment as KMAC's monoball (PN 193916-7J for xDrive). KMAC's is very well sealed.
pkiledj35.50
      12-20-2019, 11:24 AM   #46
haagm58
haagm58's Avatar
Drives: F30 328d Sport Line
Subscribed! This is the exact thread I've been looking for. Thank you for the videos and reviews!
      12-20-2019, 11:33 AM   #47
haagm58
haagm58's Avatar
Where can we purchase the strut bars for an F30? They aren't listed on their site.
      12-20-2019, 11:58 AM   #48
BMW DIY Guy
Drives: 2014 435i
2014 BMW 435i  [0.00]
shoot them an email.. I really like their stuff
Check out my BMW DIY Channel on YouTube! F32, F80, E39, E46, E53, and E83 projects from Active Autowerke, TuningTechFS, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** ** Facebook BMW DIY Guy **
'Furiosa' F32 Build Thread
haagm58740.00
      12-20-2019, 12:38 PM   #49
haagm58
haagm58's Avatar
Will do, thank you.
      01-13-2020, 03:01 PM   #50
BMW DIY Guy
Drives: 2014 435i
Updated with the last video of the series for front control arm bushings!
      01-19-2020, 07:24 PM   #51
BMW DIY Guy
Drives: 2014 435i
Any opinions about a potential last change of the F82 control arms?
      04-29-2020, 09:37 AM   #52
BMW DIY Guy
Drives: 2014 435i
Still thinking F8X control arms, but would have to change that and alignment again.. not sure its worth it at this point.
haagm58740.00
      06-09-2020, 09:01 PM   #53
BMW DIY Guy
Drives: 2014 435i
My summary index video is up for all of the suspension changes, with cards to each of the DIY videos of the build out.
      08-18-2020, 04:16 PM   #54
ScubaSteve
Drives: 2013 335i xDrive M Sport
DIY GUY, thanks for the quick reply earlier today. I ended up driving over to my local dealership to get a price for the front control arms, yep, def not going thru them for that! $450 CAN ouch! I figure with exchange these will come out to about $250 CAN from FCP Euro. Right after that I headed over to my local tire shop that I sometime get to swap over my seasonal tires and do any alignments. They pulled the car in the shop and did a quick free 10 min assessment and was very surprised to hear that they said the front end appeared to be fine. Nice and tight were his words exactly lol. Thinking I was prepared to order new control arms he said the bushings looked fine and didn't think that was the problem. Just to recap, driving home this past weekend on a long road trip my steering was so loose and sloppy and my traction control light kept coming on and shutting off my cruise control. It happens in anything greater than a gentle turn at speeds of around 110-120 km/hr. They booked me in for next week and say they will hook up a scanner and drive around and that they can see real time data from the car and if it is throwing any codes. So until then, I'll just have to wait and drive the car carefully.
pkiledj35.50
      09-01-2020, 04:21 PM   #55
weehe126
Drives: 2016 340i
General question on dropping the rear subframe, why do you need to remove the bolts for the spring mount arms? I didn't have to do that for my E90, just removed the subframe bolts with the diff supported and lower enough to add the inserts.
      09-19-2020, 05:38 PM   #56
weehe126
Drives: 2016 340i
Well I disconnected the lower shock mount bolt to be safe. Seems the shock is probably maxed out just by lifting the rear, so dropping the subframe a few inches would have put unneeded stress on it.
