BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
      08-03-2020, 06:06 PM   #3895
GEDDES
newbie
Australia
Drives: 2016 BMW F30 330i
Originally Posted by Firefly1337 View Post
Hey,
here's the newest update for our custom version: v2.0.B0.mod for BMW NBT and v2.0.M0.mod for MINI NBT. They are available on the 1st page.
The biggest change is that this version will run on any device. It does not matter if you have an Andream, Carlinkit, RoadTop or Bimmertech device.
It is based on the latest Bimmertech update featuring their UI (see below).
//Edit: Since it's based on the Bimmertech update, calls on AA should be fixed as well.
I'd like to take the opportunity and thank cossie1 for the update, he really did most of the changes and created many new icons and images.
Also thanks to dkeruza and Feisar328i for their continuous support and muniz_ri and xDHC for test flashing the update
Changelog/Contents:
  • Android Auto Widescreen Fix
  • Android Auto DPI Fix
  • Autolink Mirroring Screen Size Fix
  • Renamed MMI to BMW-MMI/MINI-MMI for Carplay and AA
  • Replaced MMI icon with BMW/MINI icon
  • Replaced car image on integrated PDC/camera screen
  • Changed icons to Blue when highlighted
  • Removed update / key checks
  • BMW/MINI Boot Logo
  • Custom Flash/update screen
Attachment 2380355
The work that has gone into this is huge. Can not wait to get my unit now. This is awesome, thankyou so much to all involved.
      08-03-2020, 06:31 PM   #3896
Besty78
Besty78's Avatar
Drives: Bmw f30 330d
Hey,
Changelog/Contents:
Attachment 2380355
you guys are absolutely awesome , thank you all so much , you all should really go into business together .
would you say the bimmertec mcu is better ?
      08-03-2020, 06:33 PM   #3897
frviana
Drives: F36
MCU Changelog ?
I got the Carlinkit today and installed on my F36 right away and almost everything worked. Upgraded the software with the new 2.0 Custom and it worked , just noticed a bit of pixelation on the outer edge of everything in AA, don't know if this is due to be connecting wireless.
Went to upgrade the MCU and it says: USB Stick with upgrade_mmi.bin update file has not been detected . I could easily change the file name but a few questions before trying upgrading the MCU:
1. My System Version says: MCU Version 10.6.2.0
What would the latest version for Carlinkit be? This forum says MCU 20.06.02, is this the same that I have and It just happen to show wrong version on mine?
2. Can I find anywhere the changelog for the MCU to see the benefits on upgrading?
3. My steering wheel buttons don't do anything on the MCU version it came with . I tried answering a call or hanging up and it didn't work. Would the MCU 20.06.02 fix this?
Thank you everyone for the awesome work!
      08-03-2020, 07:28 PM   #3898
muniz_ri
Drives: BMA 320I
You need to connect to the oem bluetooth connection for the phone button on the steering wheel to work. Also, I wouldn't worry about the mcu. Your version is a recent one.
GEDDES0.00
      08-03-2020, 07:44 PM   #3899
jaypayne05
Drives: 435i Gran Coupe M Package
Hey,
Changelog/Contents:
Attachment 2380355
Do this mod version works on the newer Andream B units??
so i did the Andream B version update and its so much more responsive now when using the IDrive wheel or the steering wheel buttons. before it would lag a lot but now its perfect.
435i M Package, VRSF FMIC, VRSF CP, MHD stage 2+, stock cat
      08-03-2020, 08:42 PM   #3900
frviana
Drives: F36
Thank you. It worked. Everything is working now. Just wondering if I leave both Bluetooth connected, where is my call going to be routed through when I answer the phone in the car. How does it Select?
      08-03-2020, 09:10 PM   #3901
muniz_ri
Drives: BMA 320I
All calls on AA will be routed through the oem bluetooth connection.
      08-03-2020, 09:36 PM   #3902
muniz_ri
Drives: BMA 320I
Originally Posted by cossie1 View Post
Originally Posted by chambo622 View Post
Is there a benefit to doing that?
Nope, the scroll wheel works backwards (up for next and down for back, which is the opposite of how it works in the i-drive) other than that I didn't notice any difference, but I am sure some will want to try it for themselves.
cossie...you now need to get yourself a proper phone, i.e Android, to take advantage of all of your work
      08-03-2020, 11:03 PM   #3903
evilFive
Drives: i3
Thanks for all of the hard work, I like how you even put in a very cool custom splash page. As a bonus for me coming from carlinkit, my echo is gone. It will take some getting used to since the menu button doesn't do the back command like on Carlinkit but I can actually use my phone as a phone now .
      08-03-2020, 11:14 PM   #3904
muniz_ri
Drives: BMA 320I
Just double press the back button. It has the same function as pressing the menu button on the Carlinkit sw.
      08-03-2020, 11:30 PM   #3905
chambo622
Drives: F31 LCI 328i M Sport EBII
Looks like the Bimmertech based fw doesn't have separate volume for navigation? Probably won't miss it that much but was nice to have, maybe they'll add that too.
      08-03-2020, 11:56 PM   #3906
flausatu
Drives: BMW F30
Hey,
Guys, thank so much. Tis is a great work, really awesome. Thank u and keep up this project.
      08-04-2020, 12:10 AM   #3907
623baller
Drives: 2015 F80
Hey,
thanks so much for continuous dev and testing to all of you
does this mean carplay also routing calls through bluetooth or it's still the mmi box?
also , what mcu should one upgrade to? bimmertech's mcu or whatever your original manufacturer's mcu?
      08-04-2020, 12:54 AM   #3908
i3BEV
Drives: BMW i3
Hey,
Can this be safely renamed to GEMINI_PACK.BIN for the newer B units?
      08-04-2020, 01:11 AM   #3909
cjattard
Drives: i8
Oh my this is totally amazing, thank you so much for all of your hard work. I cant wait to get this installed. So does the Bimmertech base image use the OEM BT for the audio on IOS too?
      08-04-2020, 01:14 AM   #3910
SDriver18i
SDriver18i's Avatar
Drives: BMW X1 s18i 2019
Are the first two dip switches set to On and rest to Off for your 6.5" screen?
Yup, nothing works. We tried everything possible. He sent me another unit but I don't want this to happen again.
      08-04-2020, 02:05 AM   #3911
bryce007
Drives: E92 M3, E60 M5, E92 335i
Wow this is amazing work guys! Is there any chance of getting some work on the CIC versions?? I've got a few Andream CIC units in my cars and happy to test flash for anyone or try mods (even if they brick).
      08-04-2020, 02:19 AM   #3912
contracts34
contracts34's Avatar
Drives: BMW 4 Series F33
Hey,
Changelog/Contents:
Attachment 2380355
Thanks again to everyone involved. The work you guys put in to this for the benefit of the rest of us is appreciated beyond words. Most are like me, unable to do such wizardry, I just wish I could somehow help
      08-04-2020, 02:54 AM   #3913
Minims
Drives: F54 Cooper S
Hey,
//Edit2: A word regarding MCU updates: With this update you can only flash the MCU updates by Bimmertech. Flashing the default MCU from Andream/Carlinkit etc is only possible on their firmware. Currently there is no need to do anything (no new features etc), so you can leave everything as is. Also note that Bimmertech transforms the first digits of the MCU version from '20' to '10'.
Changelog/Contents:
Attachment 2380355
I have update my Andream NBT to the MINI version.
It's really good but there is just one missing thing.
With Andream version I can adjust screen size.
On MINI, screen is round on left and right and you can't see everything on the screen with default size.
So you need to adjust. I have setting left to 30.
I can't find how to change this in this custom fw.
Is it possible to add this in the config menu ?
Many Thanks.
      08-04-2020, 02:59 AM   #3914
Furbz
Drives: Possible X5 50i
Just received and installed my unit into my X5 F15.
thought i ordered a Andream unit. Received a Carlinkit unit
here is the latest software on my unit.
seems newer than what is listed on post 1
muniz_ri167.50
      08-04-2020, 02:59 AM   #3915
cerij101
Drives: BMW 520d F11
Just adding my thanks for your hard work on this 👍
      08-04-2020, 03:04 AM   #3916
xDHC
Netherlands
91
Drives: F20 116i
Right so been running v2.0.B0.mod for a while now and next to what was in the change log i can confirm the following (all tested on Android Auto):
- calls route through the BWM idrive now (when also connected to BWM via bluetooth)
- which also means the echo is gone!
- i can use steering wheel phone button to pickup and hangup calls
- AA auto day/night works based on cars headlights
Have to say i am running SW v2.0.B0.mod and bimmertech MCU 10.6.18.21 on andream.
It also added another issue someone pointed out earlier which was not present in the previous custom version:
- when a call comes in on AA i am unable to move focus via commander knob to the middle screen and tilt to top to set focus on either hangup or pickup call. Workaround is steering wheel button but just wanted to point out the issue is there and is not fixable via clearing AA cache.
- minor issue; in AA when a call comes through or you call someone, it says "no bluetooth connection" but everything works. I believe it says this because theres no bluetooth connection active to the MMI and things are being handled by idrive.
x-m4n136.50
muniz_ri167.50
andream, android, android auto, apple, carplay, mmi, retrofit
