BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
      08-04-2020, 01:35 PM   #3961
xDHC
Netherlands
91
Drives: F20 116i
Tested over the course of 1 hour today, 100% calls go over idrive now and not mmi on latest custom firmware on AA. I even see call history in idrive.
Do note, i use latest bimmertech mcu.
      08-04-2020, 01:41 PM   #3962
cerij101
Drives: BMW 520d F11
Originally Posted by bowen159 View Post
Hi,
Just wanted to what a great job youíve done!
One thing Iíve noticed today after installing the custom firmware v2 to my Mini, the volume for the navigation is low. When I go to increase it when the Navigation is talking, it increases everything including the radio via the Tunein app. This then makes the radio too loud.
Iíve tried setting the volume to ĎLoudí in Google Maps settings but is doesnít appear to do anything.
Any ideas?
Think I may hold off updating if that's the case
      08-04-2020, 01:46 PM   #3963
muniz_ri
Drives: BMA 320I
My experience has been the same. Everything works great. I also love being able to use the phone button on the steering wheel and also the auto launch feature and having AA ready to go when I get into my car.
      08-04-2020, 01:51 PM   #3964
jjra
Drives: E90 > F48
Hi all,
Congratulation to people involved in the development of the new custom V2, wich is a fantastic job. It works fine, and now the auto day/night mode works again in AA, and of course, the new autostart AA feature is great.
Originally Posted by mako2388 View Post
Was able to update the to 1.0.2 with a different USB drive and got the MCU updated too. Still don't have the widescreen though
mako2388 , I had issues with the new widescreen layout in a Samsung S8, I can't see it. The solution was the resolution of the phone screen, if it is set to 720 the old widescreen is shown, but if you select 1080 or more, the new widescreen layout appears. Check your phone resolution display if possible and try it.
      08-04-2020, 02:08 PM   #3965
mako2388
Drives: X3 f25 2016
Originally Posted by cossie1 View Post
Sorry my mistake.
It was v2.1.0.8.multiusb.gpe.b that they fixed it in not the B version
Ah OK. I'm sure I'll get it eventually. I'm happy things are working, was having serious issues the first few days it was installed (cursor issues) but everything works now at least!
      08-04-2020, 02:17 PM   #3966
mako2388
Drives: X3 f25 2016
Originally Posted by jjra View Post
Hi all,
Ah I will give that a shot. I have a oneplus 7 pro which has like a "smart" setting where it switches the res by what you are doing. I can set it to high and see if that changes anything. Thanks for the suggestion!
      08-04-2020, 03:09 PM   #3967
cerij101
Is the OP7 Pro wired or wireless AA?
      08-04-2020, 03:46 PM   #3968
corduroy
Drives: '16 X5 xDrive40e (F15)
Wow, great work!
I can confirm that my phone calls don't go through the MMI. I'm using the Road Top (early) MMI for NBT with wireless AA. It will show that I'm on a phone call (as pictured) but it's not using bluetooth to control the call. BT doesn't show connected to the MMI.
edit: photos
      08-04-2020, 04:07 PM   #3969
Kyokushin
Kyokushin's Avatar
Poland
Drives: F32 428i, E92 325Xi
Can anyone play with Carplay and BT? Maybe there is also way to configure it with Apple to use BT for calls.
      08-04-2020, 04:17 PM   #3970
bowen159
Drives: Mini
Iíve found a work round for this after a couple of hours of messing.
Firstly, when not connected to the mmi, load Google Maps and in Settings, find Navigation settings. In there, set the sound level to loud.
The next thing I did was in the MMI Audio setting, select the EQ. Reduce all the frequencies to around -5. I found that if you do them all equally, it sounds the same but reduces the volume for all sound volume streamed ie Tune in radio, Spotify, BBC Sounds, etc but doesnít reduce the Navigation announcements therefore making the Navigation louder than the radio.
Been out for a drive and itís now the same volume levels I had on the stock navigation announcements with the radio!
One bug Iíve noticed. If you have the volume set to say 50% on the I-drive and you reset the MMI (hold the menu button down), it resets the volume to almost mute in the mmi but itís still 50% through the I-drive. To get round this, you have to set the volume to 0 on the I-drive and then complete a reset in the mmi. This sets both to the same levels.
      08-04-2020, 04:25 PM   #3971
Kyokushin
Kyokushin's Avatar
Poland
I am curious the case - what will happen?
1) connect by USB to the OEM port in car. It should then use something called Bluetooth through USB. It is always engaging when i am using spotify by bmw apps (NBT not evo)
By this way i can hear all sounds from the cellphone as navigation on mobile, spotify or just usb music from OEM speakers, and as a 'source' i am picking the 'usb'. I noticed it is engaging only on iPhone.
2) after step 1 (set source as "BT via USB" (dont remember exact name)) connect to the carplay
What i would like to achieve - to transfer all phones audio via OEM USB - after that maybe it will also transfer calls via usb/bt?
      08-04-2020, 04:30 PM   #3972
cerij101
OK, thanks for the heads up.
      08-04-2020, 04:36 PM   #3973
frviana
Drives: F36
Originally Posted by Dracon View Post
Anyone have a good suggestion on an alternative vendor than Andream for the hardware?
I bought an Andream unit 6 weeks ago direct from their website store and it's been a bit of a pain in the rear ever since. Their shipping company lost the package in the US (no movement in over 3 weeks) and the guys over at Andream have basically washed their hands of the situation saying there's nothing they can do about it because they can't track the package.
I'd probably caution others from purchasing direct from their web store as well or just use another version.
The whole reason for going with Andream was that it appeared to be better supported especially among a lot of the custom firmware work going on but now it's looking like that's less important now.
I bought Carlinkit from Aliexpress, its their store on Aliexpress. I picked DHL and payed the premium for shipping and it was delivered to my door 4 days after I placed the order (order was placed on Friday and I received it on Monday which was a holiday). I was extremely happy. Installed on the same day and everything worked. It came with a couple plastic tools to remove the dash and a very nice large microfiber cloth too. Very nice touch. They shipped the same day I put the order.
      08-04-2020, 05:21 PM   #3974
chabzer
Drives: F30 318d
With Carplay the bimmertech MCU doesn't seem to do anything except make the scroll wheel work backwards.
As for getting it fixed, if Andream, Carplay, RoadTop or Bimmertech bring out an update that fixes this, then there will be a new custom update soon afterwards
But as above we don't have the SDK for the units (we have tried our best to get this, I have even emailed sunplus directly trying to get it), but none of the vendors are willing to share it and none of them seem interested (or even seem to have any idea of how) to fix it themselves.
The scroll wheel stopped working ?
      08-04-2020, 05:22 PM   #3975
muniz_ri
Drives: BMA 320I
I bought a Carlinkit from this seller: https://www.ebay.com/itm/18438643988...m=184386439888
He is U.S. based so the unit arrived in about 2-3 days.
Andream may now be shipping their new unit exclusively which isn't compatible with the custom firmware.
      08-04-2020, 05:49 PM   #3976
xDHC
Netherlands
91
Drives: F20 116i
No its the scroll wheel on the steering wheel that works backwards ONLY in the middle screen of android auto. It works perfectly fine everywhere else (which i noticed) and is a minor problem.
      08-04-2020, 05:56 PM   #3977
chabzer
Drives: F30 318d
ok thanks for that info
good job for the update !
do you guys know how to fix the issue on Waze , default output always set to Carlpay, can't choose BMW ... tried multiple things nothing worked..
      08-04-2020, 06:29 PM   #3978
cossie1
Drives: 2015 F82 M4
The scroll wheel is backwards for everything in carplay with the bimmertech mcu.
The 20.6.2 mcu from andream / carlinkit works fine and the scroll wheel works the correct way in carplay.
      08-04-2020, 06:50 PM   #3979
propernorf
propernorf's Avatar
Drives: 16' M5 F10
Hello, there guys grat work you doing here. I have a question regarding the customer version. Will it work with The newer andream unites or is it not compatible;e.
      08-04-2020, 07:37 PM   #3980
Besty78
Besty78's Avatar
Drives: Bmw f30 330d
absolutely awesome job guys i love it although have a few questions please
what's reverse cam alternative
it doesn't recognise the bimmertec mcu
i need a password to connect to the wifi? can't use autolink
it's not showing any bluetooth connection to the mmi ?
what's reverse cam alternative - no idea (didn't see to change anything when I tried it)
it doesn't recognise the bimmertec mcu - it does, do not rename it, they name it upgrade_mmi.bin for a reason
i need a password to connect to the wifi? can't use autolink - don't need it with carplay but iirc the password for the wifi is 12345678
it's not showing any bluetooth connection to the mmi - no idea don't have an android
thanks for the answers dude
i paired the bluetooth in the end
thanks for the password
i didn't change the filename of the mcu mate
the mcu file lost it's data somehow so i dloaded again and it worked
all problems resolved apart from still not being able to screen mirror with android and autolink
love the fact i can have full screen reverse cam with the pdc sensors graphics overlay
thanks again guys , epic job !
      08-04-2020, 09:29 PM   #3981
thestimp
Drives: F80 M3 - X3M
Flashed 2.0, everythings perfect. The revisions I made for myself seem to work as well. With 2.0 lost the ability to do a custom boot logo via the menu.
This muthafuka got the RONA!
2016 YMB FBO
      08-04-2020, 10:19 PM   #3982
frviana
Drives: F36
Is there a way to have AA not changing to Night mode when lights turns on? I don't like the dark mode. Running Custom 2 btw.
andream, android, android auto, apple, carplay, mmi, retrofit
