BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
      08-08-2020, 09:23 AM   #4071
Mollyran
Drives: 220i
You should connect your BT to OEM for calls. Before we had to disable it.
      08-08-2020, 09:41 AM   #4072
xDHC
Netherlands
91
Drives: F20 116i
Originally Posted by Moto749r View Post
I've updated to the custom V2 firmware, and AA connects wireless without the need to select the phone, which is excellent!.
However I am now having problems with phone calls, although AA shows the phone call the sound does not come through the car OEM or AA.
Any ideas what I should try guys.
Because V2 added new ways to select source output for calls. On the call screen there is an icon somewhere in the middle to select source. By default mine was set to phone so all audio was passed to phone instead. I selected bluetooth and it was solved.
This and connect your phone to BMW bluetooth.
      08-08-2020, 11:03 AM   #4073
623baller
Drives: 2015 F80
Anyone got a good eq setting for custom v2 version? Lol
      08-08-2020, 11:06 AM   #4074
mbonus
Drives: 2015 BMW 335i
where and how do you get one of these units in August 2020? nbt
      08-08-2020, 11:10 AM   #4075
chambo622
Drives: F31 LCI 328i M Sport EBII
Anyone else having clipping/static with the navigation voice? Music sounds fine. Happens with Google Maps and Waze, both on my previous Carlinkit fw and the custom 2.0.
      08-08-2020, 11:44 AM   #4076
muniz_ri
Drives: BMA 320I
https://www.android-car-dvd.com/
      08-08-2020, 05:53 PM   #4077
BzsBimmer
BzsBimmer's Avatar
Drives: 2015 F80 M3 & 2019 X7
For clarity,
I have version 2.1.0.7.gpe.b with MCU 20.6.2.0
Using USB drive with FAT32, unzipped folder from v2.0.B0.mod and placed ISPBOOOT.bin in root
Inserted USB and used pin 2863 to get into software upgrade menu.
When I select either system upgrade or MCU upgrade, the pop up says that it canít find the ISPBOOOT.bin file even though I can see it in my computer.
Does this mean I have the newer B units and itís not upgradable, OR do I need to update the version to the Bimmertech version v2.0.2.7t0.mmi.b first?
      08-08-2020, 05:55 PM   #4078
cossie1
Drives: 2015 F82 M4
No it means that the MMI does not like your usb stick.
Use a different one.
      08-08-2020, 06:20 PM   #4079
BzsBimmer
BzsBimmer's Avatar
Got it. Formatted to FAT but without using Master Boot Record. Thanks 🙏
      08-08-2020, 08:02 PM   #4080
mbonus
thanks, do you know if this is the latest version and whether android auto widescreen fix is implemented?
      08-08-2020, 09:11 PM   #4081
muniz_ri
Drives: BMA 320I
They seem to be selling two versions, one with wide-screen support and one without.
I would ask them about that before placing your order to make certain that you receive the one with wide-screen support. That version can also be flashed with the custom versions in this thread. The custom versions fix the dpi.
      08-08-2020, 11:05 PM   #4082
Unspec
Unspec's Avatar
Drives: 2015 BMW 535xi
As in, you formatted it to FAT32 but with GPT as the partition style? I'm not sure if these boxes are running a version of linux compatible with GPT
2015 BMW 535xi
Bootmod3 Stage 2 | ER Catted DP | Remus Exhaust | Gplus FMIC
      08-09-2020, 12:11 AM   #4083
masa52
Drives: F86
Andream
guys how to check which unit I have and also what the difference between old/new unit
thank you
      08-09-2020, 12:16 AM   #4084
BzsBimmer
BzsBimmer's Avatar
Formatted with MacBook. Rushed through it.
      08-09-2020, 12:53 AM   #4085
muniz_ri
Drives: BMA 320I
thank you
Post a pic of your sw version screen.
      08-09-2020, 12:58 AM   #4086
masa52
Drives: F86
image ru
      08-09-2020, 01:29 AM   #4087
muniz_ri
Drives: BMA 320I
That's a RoadTop unit. You can use either v2.1.0.6.lt.b or v2.1.0.6.gpe.b or the custom v2 from the sw section of the thread. The Pin Codes are 8032 or 2863.
x-m4n136.50
masa520.00
      08-09-2020, 03:36 AM   #4088
masa52
Drives: F86
unit is originally from andream shop
I have latest custom software installed
Just curious about which version is it ,as heard new model been released and also on the first page software is attached
thanks
      08-09-2020, 05:48 AM   #4089
cossie1
Drives: 2015 F82 M4
lc is Andream (early unit's that RoadTop sold were Andream units).
muniz_ri167.50
      08-09-2020, 06:07 AM   #4090
bmwaddictt
bmwaddictt's Avatar
Australia
22
Drives: BMW 428i F33 M Sport, 320D F30
Has anyone figured out how to code out the annoying AUX error message that appears on the KOMBI when using steering wheel controls on CarPlay? It's super annoying and just want it removed.
2016 428i F33 Estoril Blue | BM3 Stage 1 OTS 98RON | xHP Stage 3 | VRSF Ceramic Coated Catless Dp | MST Intake | GFB DV+ | M4 V2 M Perf Steering Wheel | M Perf Diffuser | M Perf Floor Mats | M Perf Side Skirt Decal | Adaptive M Suspension | Ceramic Coated | LCI Radio Trim Retrofit | M4 ASD | Speed Limit Info Retrofit | Wireless Charger Retrofit | Mods4Cars SmartTOP Module | M Blue Calipers | Michelin PS3 RFT | Andream CarPlay | All bulbs LED
      08-09-2020, 11:02 AM   #4091
Molinetti
Drives: BMW 428i
Yes, it could be great removed it, I tried to ignore it but is not good...
      08-09-2020, 11:21 AM   #4092
cerij101
Drives: BMW 520d F11
I'm still having issues connecting to AA using V2 of the custom firmware. Tried doing it through Carplay devices, it could find my phone, so I used Bluetooth which does work, but it won't auto start AA. And if I pair to the OEM BT connection for phone calls, it seems to only connect to the MMI or the OEM, not both.
Could anyone post the Bimmertech instructions for connecting your device?
andream, android, android auto, apple, carplay, mmi, retrofit
