BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
      05-03-2020, 01:12 PM   #1783
cossie1
Drives: 2015 F82 M4
Originally Posted by Racerboat View Post
HI everyone,
@Cossie1, can you say me where did you find the lastest update of the CUST and MCU for Andream, because the first page of this forum still not update, so I'm little lost now lol.
It's too complicated to read 80 pages of forum to know what is working or not on the andream unit
thanks in advance for your help ;-)
racerboat
The latest ones they have given out are 2.0.2.7.gpe.b and MCU 19.12.12
But you can use the carlinkit 20.1.4 MCU that is posted on the 1st page and it will work fine.
Still no reply from Andream with the actual latest updates.
x-m4n136.50
      05-03-2020, 01:27 PM   #1784
Racerboat
Drives: BMW 530D Xdrive F11
OK so need to use the mcu 20.4.2.14) and 2.1.0.1.lc.b software ?
      05-03-2020, 01:29 PM   #1785
cossie1
Drives: 2015 F82 M4
If that is what is on your unit, then it's newer than anything Andream have released to us as an update.
      05-03-2020, 01:32 PM   #1786
Racerboat
Oups sorry not at all I was asking if this updates are necessary ?
      05-03-2020, 01:34 PM   #1787
cossie1
Drives: 2015 F82 M4
We don't have them yet, so no idea.
2.0.2.7.gpe.b works fine with 20.1.4 though.
x-m4n136.50
      05-03-2020, 01:40 PM   #1788
Racerboat
OK perfect thanks a lot
      05-03-2020, 01:41 PM   #1789
TA020
Netherlands
Drives: BMW F30 320D
Originally Posted by Unspec View Post
Jacks on the quad lock? I'm pretty sure the normal quad lock doesn't have jacks, post a picture. Sounds like you're confusing the wiring.
Yea there is a male and female jack on the quadlock that andream sended with the carplay box
      05-03-2020, 02:03 PM   #1790
Unspec
Unspec's Avatar
Drives: 2015 BMW 535xi
Like as in a RCA jack?
2015 BMW 535xi
Bootmod3 Stage 2 | ER Catted DP | Remus Exhaust | Gplus FMIC
      05-03-2020, 02:08 PM   #1791
TA020
Netherlands
No its like a female 3.5jack ande a male 3.5 jack
      05-03-2020, 02:20 PM   #1792
muniz_ri
Drives: BMA 320I
Here is a diagram of the AV Harness with descriptions. If you received something different from the seller for an NBT system you want to contact the seller:
      05-03-2020, 03:09 PM   #1793
TA020
Netherlands
Thanks for info but its not de av harness its on the quadlock harness the male e.5jack and female 3.5jack
      05-03-2020, 03:33 PM   #1794
Unspec
Unspec's Avatar
The current units don't come with anything of the sort that you're describing. The CAN cable that contains the quadlock ONLY has a male and female quad lock. No 3.5 jacks. Post the link where you bought the unit, I have a feeling you are not using the device that this thread is for.
Edit:
It sounds like you have either the Joyeauto or Unique-AD version. This thread is not for those devices. Seek help in their respective threads:
Joyeauto:
https://f30.bimmerpost.com/forums/sh....php?t=1622013
Unique-AD:
https://f30.bimmerpost.com/forums/sh....php?t=1597999
2015 BMW 535xi
      05-03-2020, 03:42 PM   #1795
cossie1
Drives: 2015 F82 M4
Edit:
Joyeauto:
Unique-AD:
I think the latest units come with an additional aux cable so it will work with CIC-High and NBT
      05-03-2020, 04:26 PM   #1796
Unspec
Unspec's Avatar
Why would NBT need an aux cable?
2015 BMW 535xi
      05-03-2020, 04:29 PM   #1797
cossie1
Drives: 2015 F82 M4
It doesn't but I think CIC-High does.
Unspec320.50
      05-03-2020, 05:14 PM   #1798
TA020
Netherlands
Edit:
Joyeauto:
Unique-AD:
I orderd it from andream.eu so its wierd i will look at it in the morning and post after.
      05-03-2020, 05:24 PM   #1799
Len_Beach
Drives: E92 M3
My unit also came with a 3.5mm male which from memory ran from a loom that intercepted the stock microphone. I didn't need to use this.
There's also a 3.5mm female as part of the CANpower loom, again I didn't need to use this.
      05-03-2020, 08:33 PM   #1800
TA020
Netherlands
Did you also got a spare male jack with wierd connaction cable?
      05-03-2020, 08:59 PM   #1801
muniz_ri
Drives: BMA 320I
That looks like an external mic harness.
      05-04-2020, 02:56 AM   #1802
Len_Beach
Drives: E92 M3
Yep, mine had 3 connectors. The 3.5mm male and a male and female that sat inline of the stock microphone. I didn't need to use this one.
There were also the female 3.5mm and 90 degree 3.5mm thinking back which again I didn't need to use.
I watched a video of an Android headunit install, he plugged the 90 degree 3.5mm into the Aux socket in the centre console which gave sound as his quad lock didn't work for some reason.
      05-04-2020, 03:55 AM   #1803
Tina*
Drives: BMW F30
Has anyone managed to get AirPlay to work ?
1). Click 'Airplay' icon first. Then a dialog box will pop up prompting to connect to wifi.
2). Turn on wifi on your iPhone. Search the wifi signal of the Carplay on your iPhone, then connect.
      05-04-2020, 04:01 AM   #1804
Tina*
Drives: BMW F30
Originally Posted by drejcof View Post
Hello.
I also have Andream MMI box with one big problem. There is no sound from carplay system. Everything other works, except audio. Any idea, what could be wrong?
Hello,do you transfer the optic fiber?
andream, android, android auto, apple, carplay, mmi, retrofit
