BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > rear alignment specs
      09-10-2020, 06:38 AM   #1
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
my shop adjusted my rear camber and toe bars to neg 2.5 deg camber so my tires did not rub and the toe at 1/8" rear toe in. Is the rear toe too much cause my rear tires wore out on the inside way faster than the outside?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      09-11-2020, 02:07 PM   #2
52172
52172's Avatar
After some more research rear toe is perfect. We're installing 30 series tires monday then we're gonna dial bk the camber to back to neg 1.5. Should make the rear tire wear better.
