10-19-2023, 07:25 AM | #1 |
Rep 3
Noisy Center speaker after Amp upgrade
Hello,
I have a '19 F34. recently upgraded the amp to Match UP 7BMW. It was installed by an authorized installer recommended by Audiotec Fischer themselves. However after the install -- on turning on the ignition there is this strange whizzing noise heard only on the dash speaker. It stops if/when other tones in the car plays. Ex: any alarm from any sensor etc. but continues to whizz after that. attaching link with the video for reference. https://easyupload.io/i46j9h Any suggestions on this? Tx |
10-21-2023, 08:56 AM | #2 | |
Rep 487
If that does not work, remove amp and re-install the stock one to verify the noise goes away. If it does - return the aftermarket amp for replacement/repair. Good luck.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
10-23-2023, 04:20 AM | #3 | |
Rep 3
Tweeter
I had mistaken it for a noise coming from the center speaker. It's actually the tweeters that's making that noise at start-up Had taken the vehicle to the installer over the weekend. He did all the above steps. checked connections. reconnected. (didn't tweak the tune/reduce gain etc) He even installed a URC.3 to check if noise persists etc. He said this is the first time ever he's encountering such an issue - Ran out of ideas - wanted me to take the "workaround" --> Buy the URC.3 -- which I flatly refused. The only thing left is to write to Audiotec Fischer with the details and see what they got to say about this. It's annoying to say the least! |
