06-30-2018, 07:15 PM | #1 |
Rep 216
Brake pads shifting?
Hi all, don't know if this belongs in the service section, but mods feel free to move it if necessary.
A few days ago, I started to hear a clanking noise everytime I pressed the brakes first thing in the morning, it wouldn't do it after the first time in the morning. Took it to the dealer and they replaced the pads after I insisted that the noise couldn't be normal as they wanted me to believe. Apparently, they put some paste behind the pads. Haven't heard the noise so far. After researching for a little bit, it seems that this happens to other manufacturers as well. Surprised as I had Mercedes and they have never done this, is this an annoyance that this BMWs suffer from? The pads according to the IDrive had 39,000 miles left. |
06-30-2018, 07:48 PM | #2 |
Rep 242
Drives: 2013 328i 6mt
Did they not apply the pad lubricant to the last set?
F30 328i 6mt
Injen, ER, BM3, Solowerks, IND, BMS, BBS E46 M3 smg2 Bimmerworld, H |
06-30-2018, 09:07 PM | #3 |
Rep 16,065
A slight noise is normal. When you park at night the pads shift when you come to a stop. The next morning you're probably going to drive in the opposite direction, causing them to shift in the opposite direction, creating the noise. If the noise is slight it means the pads are floating freely in the pad carrier, as they're supposed to. Excessive noise could mean the pads or carriers are worn, or they just need grease. I back my car into my garage, the next morning I drive forward out of the garage, and there's almost always a slight groan from the brakes the first time I release the brake pedal, but only that first time.
07-01-2018, 07:46 AM | #4 | |
Rep 49
07-01-2018, 05:08 PM | #5 |
Rep 298
Exactly same here. Comes during first regular braking after braking in reverse. No sound after that. The sound is so loud that I think the pads must somehow stick in their position and then shoot from one end to another only when enough friction is applied. I need to take the pads out and grease them according to the BMW instructions.
07-02-2018, 06:32 AM | #6 | |
Rep 216
07-02-2018, 10:26 AM | #7 |
Rep 16,065
They're going to shift with the change in the driving direction when braking. If they're not adequately greased they'll groan more than they should when they make that directional shift.
07-02-2018, 05:09 PM | #8 |
Rep 298
Yes that is my assumption, with (new) paste the pad movement would be smoother. I will report the outcome once I have a chance to do this, easy and cheap if it works.
07-02-2018, 06:19 PM | #9 |
Rep 216
They put new pads in the front and a paste or a glue on the back of the pad. Haven't heard the noise in a couple of days. Will keep my ears open, so to speak. lol
07-06-2018, 07:26 PM | #11 |
Rep 27
Had similar thing after brakes were changed on my E90. Was told it was the pads moving ever so slightly in their holders. Stopped doing it after a few months I presume due to build up of dust around the pads.
