BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > Bootmod3 Gas/Map Question
      07-13-2018, 07:02 PM   #1
M2Rush
Drives: 2014 BSM 335i x-drive
Just got my BM3 licence and torn between which map to run...
Anyone in Toronto running BM3?
Where do you get your gas and which version of map do you run, 91 or 93 octane? I usually run Shell V-Power(91) as it has no ethanol but is ethanol really that bad? Is it worth going to Petro or Esso for the 93 map or should I just stick with Shell vpower?
      07-13-2018, 07:05 PM   #2
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
Run 93ots and use Petro 94.
I visit Toronto and Montreal every summer and Petro 94 gives the best timing. Never use 91 for 93 tune.
M2Rush82.50
      07-13-2018, 09:50 PM   #3
M2Rush
Damn nice mods!
Thanks for your input, I just wanted to see what everybody's using in Toronto, just not sure if I should stay with Shell 91 vs going with a 94 ethanol blend. I would definitely use the right octane to match the tune once I've decided.
      07-13-2018, 10:57 PM   #4
lens
lens's Avatar
2070
Damn nice mods!
Yeah, normally I would always use Petro 94 when available, I use shell 91 only when there is no 93/94 octane. I even go out of my way by stopping at a petro canada with 94 oct on the way to toronto from montreal.
      07-14-2018, 12:49 PM   #5
the dope steez
Drives: F30 335i M-Sport
Damn nice mods!
For what it's worth I've had good experience with Shell 91 as well as Petro 94 in western Canada, but power is noticeably stronger on 94 with the 93 tune. Logs look just as good on each with their respective tunes.
M2Rush82.50
      07-18-2018, 10:40 PM   #6
matsu
Drives: 2018 440xi gran coupe
petro 94 for sure!
M2Rush82.50
      07-19-2018, 12:26 PM   #7
mark_tdot
mark_tdot's Avatar
Drives: 2015 335xi - M-Performance
Running the BM3 OTS Stage 2 93 OCT (AGG) map and I only fill up with 94 Petro.
M2Rush82.50
      07-19-2018, 02:07 PM   #8
M2Rush
Originally Posted by matsu View Post
petro 94 for sure!
Thanks guys! This helps out a lot.
For the first time ever, I just ran the tank past 1/4(usually like to stay above 1/4 tank to keep the HPFP cool) all the way down to 10 kms left and filled her up with Petro 94 to keep my options open but I think I'm leaning towards the 93 map now. I may just try M2 map tonight and wait until I install the NGK 97506's before going to 93, just one more day in transit until new plugs arrive...
      07-20-2018, 01:30 AM   #9
Fat Panda
Drives: 14' 435i xDrive M Sport
petro 94 for sure!
Hi, where did you order the plugs from?
Thanks!
2014 BMW 435i xDrive M-Sport "Elphie" | Mineral Grey Metallic | Coral Red Interior | M Performance Package I | Premium Package | ConnectedDrive | bootmod3 OTS Stage 1 93 Octane Tune | M Performance Exhaust | M Performance Stainless Steel Pedal Covers | Dinan Performance Spring Set | Dinan Supplemental Ride Quality | Precision Raceworks N55 Ignition Kit
      07-20-2018, 02:44 PM   #10
M2Rush
Thanks!
Clubplug.ca has the cheapest prices but takes a week to arrive, if you need right away, Napa has them for $23-24 bucks each and I think there's 15% discount until July 31st.
      07-28-2018, 09:14 AM   #11
alopolo
alopolo's Avatar
Drives: 14 BMW 328xi BM3 StgII
BM3 STG1 93 with esso 93 or petro 94. F30 N20 stock other than straight pipe.
