05-30-2021, 04:44 PM | #1 |
Rep 46
N55 checkup
Hey guys,
So I was cruising last night in my M performance 435i 2014 FBO with no tune for now and the oil temperature jumped to 250F and the check engine light came on. before saying it's normal to have the engine oil temperature at 250F... I always had it around 200~220F even on WOT. So about the check engine light checked for codes using the MHD and it gave me the following list : - DME active codes - -10BA48 - Intake air temperature - charge air temperature, comparison: Intake air temperature too high. -122004 - Blow-offvalve. activation: Line disconnection . -180001 - Catalytic converter: Efficiency below limit value. -201101 - DME, protection against tampering: Program or data manipulation detected. - DME shadow (inactive) codes - 108932 unknown - Transmission active codes - None My only 2 concerns are the first dme code and the shadow code. Anyone bumped into these codes ? and what could they be? Thank you in advance! |
05-30-2021, 04:49 PM | #2 |
1296
Rep 3,529
temp is normal regardless where it was at before. regardless what you think, the car will tell you if it's over heating.
besides the codes etc.. is it running okay?
05-30-2021, 05:04 PM | #3 | |
Rep 46
So now everytime I drive the car one eye on the road and the other eye on the oil temperature |
05-30-2021, 06:29 PM | #4 | ||
Rep 1,148
You should see oil temps on n54 cars without an oil cooler. Lol Mine sits between 220 and 250, oil temp at 250 doesn't cause damage to rods, those numbers are normal and the car should not be turning off because of oil temps, fan not kicking on and high coolant temps can. |
n55david1295.50 |
05-31-2021, 02:04 PM | #5 | |
Rep 7,591
The first and 2nd code seem like either a wiring issue or a sensor issue. Very possible if you just had your engine out/rebuilt. The cat code is probably for a DP, since you said FBO. The DME code might be because you had a tune and removed it? |
05-31-2021, 02:14 PM | #6 | |
Rep 416
What probably happened: - changed bottom end - Engine not primed - Spun bearing - Garage blaming it on something else I can see the coolant going to high if the sensor is bad, but oil in your case? Nope.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
06-04-2021, 04:23 AM | #7 | ||
Rep 46
so yes it was a sensor issue. For the cat code, yes i have a dp and for the dme as you said it's about the tune. |
06-04-2021, 04:30 AM | #8 | ||
Rep 46
When the engine jammed he said he'll be taking care of it since he was the one fixing my car. But when he did his research he told that the problem was from a bad sensor (engine oil temperature sensor) so i had to pay for a set of bearings, a crankshaft and the sensor. My bill went straight to the sky |
06-04-2021, 06:21 AM | #9 | |
Rep 416
'16 M4 bone stock
06-04-2021, 01:21 PM | #10 | ||
Rep 46
Now I'm in my car and there's a small misfire barley noticeable but no check engine light is on and nothing on MHD. Can't get rid of this car. new injectors new sparkplugs new ignition coils new oil full tank of gas and still have a misfire :') probably from the first dme code, it's still on. |
12-17-2022, 07:48 PM | #11 | |
Rep 35
Drives: F30 n55, e70 diesel
12-17-2022, 09:41 PM | #12 |
Rep 2,354
You need to get above 297F before any sort of warnings start to pop up. And even then performance is not limited, car will just limit AC function. I believe not until 306F power is limited. AND EVEN THEN BMW obviously built in some safety margin...
(A Dane in China) |
01-18-2023, 06:08 AM | #13 |
Rep 46
Sorry for my late reply.
Welllll, I sold the car 🤣. But before that I had it on the dyno and we were taking logs of 19 different files, and after 3 consecutive days of working on it and changing ignition coils/spark plugs/ injectors/ hpfp, it turned out to be from the lpfp. Looks like even if your lpfp is having issues, there's no f-ing way to find out because it never shows on the scanner nor on the logs. I think there's a special tools that reads the graph of the lpfp and it turned out that when I'm hitting high speed WOT my lpfp is kinda turning off of not doing its proper job. So I sold it the next day and got an S55 F82. Mods update about my 435i: Dp/cp Intercooler 6.5" M2 ignition coils Ngk 97506 spark plugs M2 2018 turbo M2 hpfp Cts turbo intake Turbo inlet/outlet Dv+ Acl bearings Stage 2+ custom ECU tune via MHD Stage 3 tcu xhp And some work on the exhaust. Pictures attached |
01-18-2023, 07:12 AM | #14 | |
Rep 35
01-26-2023, 05:13 AM | #15 | |
Rep 46
I'm happy with my F82 tho. |
AmuroRay2264.50 |
