10-03-2020, 08:23 AM | #23 | |
Rep 3,699
And, I have to say that scenario sounds like a total PITA and waste of time. Good customer service would have identified that issue and corrected it before throwing parts at it. At least Dorch is pretty clear on what selections need to be made so the car starts. BM3 has a simple toggle for Spool (and Dorch and XDI), so it’s pretty hard to mess that up. Install HPFP, toggle on, 20sec flash, and start the car is all I had to do. Last edited by ZM2; 10-03-2020 at 08:40 AM.. |
10-03-2020, 10:14 AM | #24 | ||
Rep 325
10-03-2020, 10:15 AM | #25 |
Rep 1,288
10-03-2020, 10:16 AM | #26 | |
Rep 325
Dorch stg2 hpfp it is. Thanks man |
10-03-2020, 10:24 AM | #27 | |
Rep 325
I emailed MHD a few weeks ago and they couldn't give me a date on when they would include spool hpfp option. It's a shame because with spool I could probably get away with the fx-150 and even if not I'd still save 100 going with the fx-180 verse dorch stg2. So basically unless someone with a spool hpfp and MHD has tried the pump with MHD option of dorch or xdi and can say it ran fine. Then I'm stuck with dorch or xdi as an option which is a shame since spools pump fits my needs a bit better. |
10-03-2020, 10:26 AM | #28 | |
Rep 1,288
Bowenpuref3p92.50 |
10-03-2020, 10:30 AM | #29 | |
Rep 325
10-03-2020, 10:33 AM | #30 | |
Rep 1,288
10-03-2020, 10:36 AM | #31 | ||
Rep 325
10-03-2020, 10:38 AM | #32 | ||
Rep 325
10-03-2020, 10:44 AM | #33 | |
Rep 3,699
The soon to be released OTS Stg 2+ 93, E30-40, Race Gas maps from Halim at BM3 are maxing out the stock, Dinan, PS2, and TTE turbos without needing to get an expensive custom tune, and has the typical OTS flexibility and safeties built in. It blows away the map Cary did for my car (and for other guys testing it right now) on the same hardware and fuel, and guys with the larger turbos are getting >540whp on a Dynojet. The BM3 Stg 2+ OTS tunes are being released soon, so all these custom tuners who think they’re bad ass (like Cary) are about to get their butts handed to them. Last edited by ZM2; 10-03-2020 at 10:52 AM.. |
10-03-2020, 10:44 AM | #34 | |
Rep 1,288
10-03-2020, 10:52 AM | #35 | |
Rep 1,288
10-03-2020, 11:32 AM | #36 | |
Rep 3,699
And, unless you have a flex fuel sensor with instant map switching, tuning for E85 with US flex fuel is pretty dumb and one low E content flex fuel fill up from imploding your motor. Going with half E85 you lose maybe 5-10whp, but it’s much safer for the motor and lot less corrosive and water absorbing. Plus, no slow cranking or having to hit the start button twice to fire up. Last edited by ZM2; 10-03-2020 at 11:38 AM.. |
10-03-2020, 11:36 AM | #37 | |
Rep 1,288
E47.... gotta calculate every-time you go to the pump... even with an inline sensor still gotta calculate... So why is E85 harder than E47..... seems easier no??????????????? as you said... you do you... |
10-03-2020, 11:41 AM | #38 | |
Rep 3,699
If you’re in the US, we don’t have pure E85, we have flex fuel ethanol which can be E55-85. If you tune to the edge for E85 and a different flex fuel station has lower E content you’ll get super knock and blow your motor. E47 is simply half E85 and half 93 octane. No math needed, especially for the number challenged like you. JK. |
10-03-2020, 11:57 AM | #39 |
Rep 4,166
You can crash on 93 octane. There is one person making 440whp on 93 - stock Turbo. Results aren’t typical I can imagine, but there is power beyond the stock fuel pumps range.
10-03-2020, 12:03 PM | #40 | |
Rep 1,288
10-03-2020, 12:19 PM | #41 |
Rep 1,288
Interesting... Been running 93/boostane for a few years now and no issues... but I can only run 2 gallons of E85 when mixed with 93/boostane per tank or it crashes my fuel pump... still trying to empty my tank to see if the boostane is limiting me from running more E85 on stock pump...
10-03-2020, 12:31 PM | #42 | |
Rep 1,288
there is only two scenarios I've heard... 1) running to much E85 crashes stock fuel pump (I've done this already) 2) running less E85 only pulls timing and boost... (guess I'm doing this now since I diluted it since the crashing of stock fuel pump and logs show it) Haven't heard anybody blowing their engine up... Last edited by FastF30; 10-03-2020 at 12:51 PM.. |
10-03-2020, 12:58 PM | #43 | |
Rep 3,699
The flex fuel situation is another reason Halim’s new Stg 2+ E30-40 map is better than most all custom tunes for E85. His tune is more than just log, advance timing and boost, log, and keeping doing that to find a limit until the car stops making power or runs rough, and then dial it back a little bit. His new map works with E30 but also adds more power the more E you put in the tank, while also being safer than a custom tune bc it adapts better and works no matter how hard you’re driving or ambient temps/IATs. The guy really is on a level by himself with these new OTS maps, and like I said, it blows away the map Cary did for me. The main point I’m trying to make is now that we all have access to affordable fueling solutions for our cars, there’s all these people out there saying “oh man, I’m going Stage 2, running full E85, getting a custom tune, and I’m going to make a zillion horsepower!”, when they don’t have a clue about E85 running and living with E85 in a daily driver. This is all new territory for the N55 masses, so there will no doubt be more head to head comparisons bn E30-E85 tunes, but it will more than likely play out as I’ve learned so far = running half E85 on the next gen OTS Stg 2+ tunes will be safer, more flexible, and provide as much or more power than most “full E85” custom tunes. Last edited by ZM2; 10-03-2020 at 01:23 PM.. |
imperfectluck428.00 |
10-03-2020, 01:11 PM | #44 | |
Rep 1,288
ZM22824.00 |
